Stones Posted December 21, 2021 Posted December 21, 2021 Following on from the excellent post by @DOIGAN where he replaced the bearings in one of the fans from his MVHR, this is a short post to detail the steps to replace the bearings in the extract fan in my Vent Axia Sentinel Kinetic Plus B (being a slightly different model and fan to that of the link below) The process I followed is basically the same as laid out by @DOIGAN in his original post. I've added a couple more pictures and descriptions below. To get at the fans, the unit has to be stripped down. First the duct spigots and blanking plates are removed. Both the back and front covers are then removed, allowing the top and side panels to be taken off - the side panels slide/interlock with the top and bottom panels. You should then have access to the fans on either side which are bolted to the poly core: I then disconnected the power connector to avoid having to try and unplug from the motherboard / cause any other issues. From this point I followed the process as per @DOIGAN Removing the circlip was a bit challenging, as for some reason the hub assembly would not depress, it turns out because the spring beneath wasn't seated properly. I managed to get the circlip off, but naturally it pinged up into the air and I spent several minutes searching for it until finally finding it some distance away. The bearings themselves (one on either end of the hub) popped out easily. I used the same bearings as @DOIGAN Reassembled and back into the MVHR unit. Cost - my time and £7.99 for a pack of 10 bearings vs £298.43 + VAT + shipping charge for a replacement fan from Vent Axia. Vent Axia were unable to give me any detail of the bearings used when I emailed to ask. 2
Stones Posted March 21, 2022 Author Posted March 21, 2022 Short update to this. The replacement bearings seem to have failed, as the fan has been getting noisier and noiser. This may simply be the fact the bearings were cheap and poor quality, but nonetheless annoying. I have therefore replaced them again but there doesn't seem to be much in the way of improvement (same batch of bearings). I really don't want to have to replace the fans themselves given the cost, but other than getting some different bearings there's not much I can do or think of doing. Given the cost of replacement fans, and the fact the other fan is now making a little noise, if new (better quality?) bearings don't work, I'd be as well replacing the whole unit given the cost of the controller/control board (also known to fail) runs to several hundreds as well. While nothing lasts forever, and I accept that bearings costing less than £1 fall into that category, its still frustrating. Having looked online, there are several suppliers from which I can buy the right size bearing. Can anyone suggest a quality bearing brand to go for (rather than the no name ones I've tried)?
joe90 Posted March 21, 2022 Posted March 21, 2022 Most decent bearing suppliers can supply good ones, I once replaced my motorcycle wheel bearings (with decent ones ) for a tenth of the cost of BMW ones. SKF and Timken are the two top bearing manufacturers. 1
PeterW Posted March 21, 2022 Posted March 21, 2022 @Stones as @joe90 said, SKF are a good brand and they come with decent longevity. This is your same bearing in a sealed for life unit but £2.35 each https://www.bearing-king.co.uk/bearing/626-2z-skf-shielded-deep-groove-ball-bearing-6mm-bore/ 3
Conor Posted March 21, 2022 Posted March 21, 2022 Spent years replacing various "sealed" bearings in my mountain bikes. From large bottom bracket and headsets to small suspension linkage bearings. Found huge differences in quality and always went back to SKF. Was hard spending £120 on a handful of sealed bearings but they always lasted longer.
Stones Posted March 30, 2022 Author Posted March 30, 2022 A further update to this, replaced the bearings with SKF as recommended. So far so good - a real difference, whisper quiet. 2 2
LeeV Posted July 24, 2023 Posted July 24, 2023 (edited) Sorry to revive an old thread, but I think I may be having bearing issues on my Ventaxia Sentinel Kinetic too. How loud is your unit on normal running? Before/after the new bearings. I've been having noise issues at the vents since I installed the system, I've since installed silencers which helped, but I was just in the loft working on the next round of silencers. I've not been up there in a while and thought to myself that it's actually the unit that seems quite loud/noisy, even in the low 15% setting. Which reminded me of this thread. It seems odd as the unit has few runtime hours on the display. Edited July 24, 2023 by LeeV Clarify my question and a tidy up.
MP25 Posted March 23, 2024 Posted March 23, 2024 Many thanks to those who’ve contributed to this thread. I’ve just replaced the bearings in my Vent Axia Kinetic MHVR following the directions above. Unit is 6 years old and had become more noisy with some louder squeaking which sounded like a bearing being tortured. I encountered two issues: when disconnecting the motor cover the circuit board was left on the motor - there are a number of pins connecting it to the motor holding it in place, though was fairly easy to lift off and carefully put to one side. The second was that the bearings were a different size than those above! I’ve shown the motor number and bearing measurements from my unit, so a bit of a setback though quick enough to come from Bearing King - I ordered some high efficiency SKF bearings, more expensive though still only £24 for four. Enclosed are some photos of the process - including one of the poor old bearing that had clearly failed (one of the motors was much less free spinning than the other). While I had the unit off the wall, we took the opportunity to clean the vent pipes using a pull tape and home made microfibre “sweep” - photo included for those interested. 4 2
MattHiscock Posted May 13, 2024 Posted May 13, 2024 Hi All Firstly thanks to all which have helped me. I had the same issue, our 10 year old Kenetic Plus B was making a noise, so followed the above, and it was the extract fan. - Took off shell - Left everything in, including heat exchanger - so not to disturb anything - Removed connector carefully (I work with computers, so fairly normal for me) - Took out fan - Removed Clip (which I lost and spent 20 mins finding!) - Replace bearings - Put back together (but didnt close it all up so to test) I cant get the fan to spin at all. I found that when pushing in the connector the circuit board gets pushed back, so put in the connector before reassmbling, to make sure. I do have a red led flashing by control unit, but no fault codes on screen Anyone got any ideas? I am missing something / being an idiot (quite likely) PS - ive taken pictures to give a full walk through from first screw to last screw - just for a compelte idiots guide. Thanks
Christie Posted March 13, 2025 Posted March 13, 2025 On 13/05/2024 at 11:00, MattHiscock said: Hi All Firstly thanks to all which have helped me. I had the same issue, our 10 year old Kenetic Plus B was making a noise, so followed the above, and it was the extract fan. - Took off shell - Left everything in, including heat exchanger - so not to disturb anything - Removed connector carefully (I work with computers, so fairly normal for me) - Took out fan - Removed Clip (which I lost and spent 20 mins finding!) - Replace bearings - Put back together (but didnt close it all up so to test) I cant get the fan to spin at all. I found that when pushing in the connector the circuit board gets pushed back, so put in the connector before reassmbling, to make sure. I do have a red led flashing by control unit, but no fault codes on screen Anyone got any ideas? I am missing something / being an idiot (quite likely) PS - ive taken pictures to give a full walk through from first screw to last screw - just for a compelte idiots guide. Thanks Hi MattHiscock, did you resolve your problem? My unit has started to make more noise and I’m intending to replace the bearings soon just wondering if you figured out your problem and whether I need to watch out for anything else whilst replacing them. Also, does anybody have a link to the bearings or size of bearings used? Thanks
Chris_BE Posted November 2, 2025 Posted November 2, 2025 (edited) Hi everyone, Thank you @Stones for this very helpful post! I ordered the SKF ones to be sure. Since my unit is wall-mounted, I would like to ask if I have to unmount it to be able to access the fans? Or can I remove enough panels while the unit remains on the wall? I cannot find any clear information on this. Thank you! Edited November 2, 2025 by Chris_BE
thomas Posted November 22, 2025 Posted November 22, 2025 Mine have just started to fail on one of the fans, thank you everyone for displaying the process I did take mine appart to see if I could see the bearing but put it all back together as I could not see an easy way. Unit is about 7 years old. So it seems they fail around this time.
KineticBuser Posted December 5, 2025 Posted December 5, 2025 On 02/11/2025 at 07:12, Chris_BE said: Hi everyone, Thank you @Stones for this very helpful post! I ordered the SKF ones to be sure. Since my unit is wall-mounted, I would like to ask if I have to unmount it to be able to access the fans? Or can I remove enough panels while the unit remains on the wall? I cannot find any clear information on this. Thank you! Did you manage to do this? Getting a whining from the left hand side so suspect i have the same bearing issue although not taken front case off My unit is installed in a tight location and so impossible to get the side panels off - Can i do this by just removing the front plate or does the whole thing need to come off? Is there any spray i could use to just give it some life for 6 months until i can be bothered to do the job?
