bellski Posted November 26, 2021 Share Posted November 26, 2021 Hi Group We are starting a new build but after buying Nudura blocks were a going back to Block and brick. Unfortunate but we have not had the best start. Lots of blocks needing a new home. Thanks Norm Link to comment Share on other sites More sharing options...
Russell griffiths Posted November 26, 2021 Share Posted November 26, 2021 Why?? i found it very straight forward and wouldn’t consider block over it. Wont this cost you thousands in finding a new home for the blocks. What is the problem, let us know there’s a lot on here using icf, I’m sure we will have a cure. Link to comment Share on other sites More sharing options...
bellski Posted November 26, 2021 Author Share Posted November 26, 2021 Builder issues are the main problem. Plan A was wayyyyyyyyyyyyy over budget. Also builders/contractors in my area are not so familiar with the method so looking at moving on with the build another way. If I am honest the loss on the blocks will be nothing compared to the saving we will make compared to the ICF builders proposed cost. I was very much looking forward to this build concept but so far costs are over budget. Thanks Norm Link to comment Share on other sites More sharing options...
Russell griffiths Posted November 26, 2021 Share Posted November 26, 2021 Where are you. Link to comment Share on other sites More sharing options...
willbish Posted November 26, 2021 Share Posted November 26, 2021 Putting the shell up is a surprisingly small part of the whole project. You still need groundworks, foundations, roof etc etc. Im an amateur thats built a 4 bed cottage with ICF on my own. If I can do it any half decent builder can too. What exterior finish do you have planning permission for? As you mention brick... Link to comment Share on other sites More sharing options...
rh2205 Posted November 26, 2021 Share Posted November 26, 2021 Hmm builders are pretty expensive right now there’s COVID & inflation but also tonnes of demand they can pick & choose, especially the ones who package up the work leaving less to you in terms of sourcing sub contractors. But if you have found a cheaper one that can ACTUALLY deliver at that price giving you a saving and making it within budget then go for it. There may be no easy answer or just downgrading spec, its a lot luck as to how time consuming the sub contractor route can be right now and thus how long it takes to get the job done. Link to comment Share on other sites More sharing options...
bellski Posted November 26, 2021 Author Share Posted November 26, 2021 1 hour ago, Russell griffiths said: Where are you. St Neots Cambridgeshire. Link to comment Share on other sites More sharing options...
bellski Posted November 26, 2021 Author Share Posted November 26, 2021 1 hour ago, willbish said: Putting the shell up is a surprisingly small part of the whole project. You still need groundworks, foundations, roof etc etc. Im an amateur thats built a 4 bed cottage with ICF on my own. If I can do it any half decent builder can too. What exterior finish do you have planning permission for? As you mention brick... The plan was render and a brick/stone cladding like z-clad. Builders locally are not so keen on what they see as a new method and quite honestly letting he practice on our house is not my idea of fun. We await a quote for a traditional block and brick alternative but wanted to see if we have any interest in the block was purchase earlier this year. First builder, no developer, was simply charging soo much we had to put the brakes on this, hence the reason to join the forum. Link to comment Share on other sites More sharing options...
bellski Posted November 26, 2021 Author Share Posted November 26, 2021 1 hour ago, rh2205 said: Hmm builders are pretty expensive right now there’s COVID & inflation but also tonnes of demand they can pick & choose, especially the ones who package up the work leaving less to you in terms of sourcing sub contractors. But if you have found a cheaper one that can ACTUALLY deliver at that price giving you a saving and making it within budget then go for it. There may be no easy answer or just downgrading spec, its a lot luck as to how time consuming the sub contractor route can be right now and thus how long it takes to get the job done. Agreed. Local builder of 30 years + seems happy to work towards Plan B. and is offering a degree of confidence in approach if nothing else. Whilst ICF was a clear favourite for all the known reasons we need to keep an eye on final cost. Link to comment Share on other sites More sharing options...
rh2205 Posted November 26, 2021 Share Posted November 26, 2021 (edited) You are mere miles from us by the way! We did try finding a st Neots builders as thought they’d be cheaper than Cambridge but ultimately got fobbed off. Honestly it’s an expensive business round here if you can only get an estimate from a builder, be warned! Just to add we didn’t see any new build estimates come in under 300k for 160sqm for block/brick, so we refurbed the existing place which is 220sqm for a lot less, but we made compromises too & still had a VAT exemption for that refurb route. Edited November 26, 2021 by rh2205 Link to comment Share on other sites More sharing options...
freshy Posted November 26, 2021 Share Posted November 26, 2021 3 hours ago, bellski said: Builder issues are the main problem. Plan A was wayyyyyyyyyyyyy over budget. Also builders/contractors in my area are not so familiar with the method so looking at moving on with the build another way. If I am honest the loss on the blocks will be nothing compared to the saving we will make compared to the ICF builders proposed cost. I was very much looking forward to this build concept but so far costs are over budget. Thanks Norm Sad to hear that you are not progressing with ICF and going to Brick/Block, I took my prospective builder to the isotex course earlier this month. He was pushing me down the traditional brick/block route but now is convinced that he can do ICF for me. Link to comment Share on other sites More sharing options...
bellski Posted November 26, 2021 Author Share Posted November 26, 2021 20 minutes ago, freshy said: Sad to hear that you are not progressing with ICF and going to Brick/Block, I took my prospective builder to the isotex course earlier this month. He was pushing me down the traditional brick/block route but now is convinced that he can do ICF for me. We actually hunted down this builder because he had experience with ICF so a no brainer, however his final budget was out of the question. It is sad as I know this would have been a better finished product. Link to comment Share on other sites More sharing options...
bellski Posted November 26, 2021 Author Share Posted November 26, 2021 1 hour ago, rh2205 said: You are mere miles from us by the way! We did try finding a st Neots builders as thought they’d be cheaper than Cambridge but ultimately got fobbed off. Honestly it’s an expensive business round here if you can only get an estimate from a builder, be warned! Just to add we didn’t see any new build estimates come in under 300k for 160sqm for block/brick, so we refurbed the existing place which is 220sqm for a lot less, but we made compromises too & still had a VAT exemption for that refurb route. Building on site now demolished was 1870 something, no heating no damp proof, poor extensions so a nightmare to refurb. Opting for this gives us a clean slate to get what we believe we want. Link to comment Share on other sites More sharing options...
Russell griffiths Posted November 26, 2021 Share Posted November 26, 2021 Have you spoken with the icf supplier to find a builder. Link to comment Share on other sites More sharing options...
bellski Posted November 26, 2021 Author Share Posted November 26, 2021 yes he was the source for our builder in the first instance, Additional suggestions are south of the M25, and South West. Even asked if the supplier would buy it back, and no surprise deadly silence. The decision on which way we jump will be based on the quote when we get it probably in a few weeks time. Link to comment Share on other sites More sharing options...
freshy Posted November 26, 2021 Share Posted November 26, 2021 43 minutes ago, bellski said: The decision on which way we jump will be based on the quote when we get it probably in a few weeks time. Fingers crossed for you, good luck. Link to comment Share on other sites More sharing options...
willbish Posted November 26, 2021 Share Posted November 26, 2021 (edited) 1 hour ago, bellski said: We actually hunted down this builder because he had experience with ICF so a no brainer, however his final budget was out of the question. It is sad as I know this would have been a better finished product. I dont really understand. If your builder is experienced with ICF he should know the efficiencies that ICF can bring. How much cheaper does he think block and brick will be? Or are you reducing the size of the build as well as changing the build method? Do a quick search on the forum for bricklayers. You will read stories of teams disappearing to other jobs for better money and not returning Edited November 26, 2021 by willbish Link to comment Share on other sites More sharing options...
Mr Punter Posted November 26, 2021 Share Posted November 26, 2021 +1 and even more so if you have the SE design based on the system. Can't you get someone to quote just to build the structure? Link to comment Share on other sites More sharing options...
Sandybay Posted November 26, 2021 Share Posted November 26, 2021 Hi, Agreed Icf builders are thin on the ground, did you think of looking for one in Ireland there seems to be quite a few there. Link to comment Share on other sites More sharing options...
bellski Posted November 26, 2021 Author Share Posted November 26, 2021 1 hour ago, willbish said: I dont really understand. If your builder is experienced with ICF he should know the efficiencies that ICF can bring. How much cheaper does he think block and brick will be? Or are you reducing the size of the build as well as changing the build method? Do a quick search on the forum for bricklayers. You will read stories of teams disappearing to other jobs for better money and not returning Sorry to confuse. Builder No. 1 ICF experienced was charging way over the top. Builder No. 2 is proposing Block and brick. Link to comment Share on other sites More sharing options...
bellski Posted November 26, 2021 Author Share Posted November 26, 2021 1 hour ago, Mr Punter said: +1 and even more so if you have the SE design based on the system. Can't you get someone to quote just to build the structure? Yes we have that as well but it not working out smoothly between new concept and traditional thinking. We await costs to understand where traditional build comes in against what we have for ICF. Link to comment Share on other sites More sharing options...
Russell griffiths Posted November 27, 2021 Share Posted November 27, 2021 18 hours ago, bellski said: yes he was the source for our builder in the first instance, Additional suggestions are south of the M25, and South West. Even asked if the supplier would buy it back, and no surprise deadly silence. The decision on which way we jump will be based on the quote when we get it probably in a few weeks time. My supplier offered to take back any unused blocks, and then passed my details onto another bloke down the road who came and collected them, at the price I paid. Who have you used. Link to comment Share on other sites More sharing options...
bellski Posted November 27, 2021 Author Share Posted November 27, 2021 ICF Southern West Sussex Link to comment Share on other sites More sharing options...
Russell griffiths Posted November 27, 2021 Share Posted November 27, 2021 I would talk to icf supplies in Essex, they will sort you out a contractor. 1 Link to comment Share on other sites More sharing options...
Nkoru Posted November 27, 2021 Share Posted November 27, 2021 On 26/11/2021 at 14:44, rh2205 said: You are mere miles from us by the way! We did try finding a st Neots builders as thought they’d be cheaper than Cambridge but ultimately got fobbed off. Honestly it’s an expensive business round here if you can only get an estimate from a builder, be warned! Just to add we didn’t see any new build estimates come in under 300k for 160sqm for block/brick, so we refurbed the existing place which is 220sqm for a lot less, but we made compromises too & still had a VAT exemption for that refurb route. Hi , we are looking to refurb our bungalow rather than build up due to cost and interested in how you got your VAT exemption? Link to comment Share on other sites More sharing options...
