2.3 should be fine, 2.4 used to be the base minimum but now there is no minimum and 2.3 is only 100mm less. The room shapes with be something of a factor. A large room with a low ceiling is more of a problem than a small room with a low ceiling because of the way it feels.
  • Like 3
I think that you can go as low as you like except at the top of the stairs where in needs to be 2m  once saw 1.5m high bedroom ceiling
got all excited as I thought we might be talking U-valves
Personally I would go 2.45 downstairs and 2.4 upstairs.
Our house is a little unusual that we have 2.4 downstairs and the two main upstairs bedrooms have vaulted ceilings going up to the ridge, and I like it.  The small, spare bedroom has a 2.3M ceiling to give more height on the mezanine but it is only a small room.  I think it would be oppressive in a larger room.
  • Like 2
Did the vaulted ceiling upstairs add much cost compared to the usual trusses?
3 hours ago, Dave Jones said:
2600 down 2400 up
Ridge height permission for 6700 from ffl. Hipped roof 19 degree slope. Trying to squeeze in what is possible. Perhaps vaulted ceiling in master bedroom. Open to imaginative ideas that don't cost too much more.
To keep our ridge height down we had skeilings at 2000mm and a 2300mm ceiling height, neither of which are really noticeable.
Edited by Russdl
those are oppressively low. Better planning at the outset can help with this.
should be workable,  2500 min downstairs 2400 up gives you 1800 to ridge .
It was a vaulted roof design supported on ridge beams anyway, deliberately so designed to give maximum usable space in a room in roof design using 3 additional gable ends to further add to the usable space.
So the choice came down to vaulted ceilings, or put a ceiling in at any height you wanted to give a bit of loft storage space.
mockup of bedroom ceiling heights
2300mm
2400
2500
Trying to keep some attic storage space too, with enough for a low chair to allow browsing when needed
Edited by WWilts
?. It was planned from the outset. To get the ridge a bit lower.
Nothing oppressive about it, as I said neither feature is noticeable and the combination achieved the aim - but thanks for your input all the same.
don't be silly. you cant fit architrave above a door with a 2m ceiling.
2300 is the absolute bare minimum for NHBC.
I suspect you’re right. That’s why the door is on the opposite side of the room to the skeiling. Bloody lucky I planned it that way I guess...
But thanks for your input.
Incase I didn’t make it clear, the ceiling is 2300mm
Edited by Russdl
  • Haha 1
2300 is still too low for me.
What was you build up to FFL ? Could 200mm not have been squeezed out of it ?
