CotswoldDoItUpper Posted September 30, 2021 Posted September 30, 2021 I’m looking to buy an electric saw thingymigiggy for cutting mitres on skirtings amongst other things after a chippy quoted £30/m to attach the 30m of skirtings I already have. (Nearly had a heart attack at that quote!) any recommendations or things to watch out for? Skirtings are 194mm tall and 18mm thick, will do other things too but skirtings are the primary thing for the moment.
TonyT Posted September 30, 2021 Posted September 30, 2021 Have a look in screwfix, everyone’s budget and preference is different
ProDave Posted September 30, 2021 Posted September 30, 2021 I have a cheap compound chop saw. While it works well for general cutting bits of wood up, I found it did not work very well for getting an accurate clean mitre joint for the corner of skirting board. I ended up making a cutting jig and cutting them by hand with a nice new fresh sharp hand panel saw.
James94 Posted September 30, 2021 Posted September 30, 2021 Got an evolution mitre saw a little while ago from screwfix not to bad, just remember to scribe internal and not mitre. Regards James
CotswoldDoItUpper Posted September 30, 2021 Author Posted September 30, 2021 26 minutes ago, James94 said: Got an evolution mitre saw a little while ago from screwfix not to bad, just remember to scribe internal and not mitre. Regards James Thanks James, what do you mean by scribe the internal not mitre? Noobie here!
Declan52 Posted September 30, 2021 Posted September 30, 2021 2 minutes ago, CotswoldDoItUpper said: Thanks James, what do you mean by scribe the internal not mitre? Noobie here! means you end you with a nice fit even if the corner is not 90 degrees.
CotswoldDoItUpper Posted September 30, 2021 Author Posted September 30, 2021 Jeez, but sure I have the time/patience/skill for that!! I was just going to measure each joint and adjust the mitre to suit…. Is this terrible?!?
nod Posted September 30, 2021 Posted September 30, 2021 Look at secondhand FB eBay Most of the sites are banning corded tools There are joiners parting with some really good kit In favor of battery saw etc 1
Declan52 Posted September 30, 2021 Posted September 30, 2021 44 minutes ago, CotswoldDoItUpper said: Jeez, but sure I have the time/patience/skill for that!! I was just going to measure each joint and adjust the mitre to suit…. Is this terrible?!? It doesn't take that long. You can cut the straight bit with the chop saw so it's only the top curved section you use a coping saw on. I've seen guys use a jigsaw to do it but its a quick way to loose your fingers.
CotswoldDoItUpper Posted September 30, 2021 Author Posted September 30, 2021 13 minutes ago, Declan52 said: It doesn't take that long. You can cut the straight bit with the chop saw so it's only the top curved section you use a coping saw on. I've seen guys use a jigsaw to do it but its a quick way to loose your fingers. Ok, so stupid question time, the external corners are still mitred? I can’t see this method working on externals!
MJNewton Posted September 30, 2021 Posted September 30, 2021 (edited) 8 minutes ago, CotswoldDoItUpper said: Ok, so stupid question time, the external corners are still mitred? I can’t see this method working on externals! Correct - scribing only works for internal joins. Edited September 30, 2021 by MJNewton
TonyT Posted September 30, 2021 Posted September 30, 2021 Get some mitre fix adhesive, handy stuff how are you fixing the skirting to the walls?
CotswoldDoItUpper Posted October 1, 2021 Author Posted October 1, 2021 8 hours ago, TonyT said: Get some mitre fix adhesive, handy stuff how are you fixing the skirting to the walls? Sticks like sh*t mostly, the occasional nail if really needed.
Declan52 Posted October 1, 2021 Posted October 1, 2021 If you use mitre fix on the external corners it's much easier to get a perfect finish. Apply the glue and activator and push the 2 bits together and wait a minute till it's set then move into place and nail home. As they are glued together they won't move about so you won't end up with a gap along the front edge.
