13 minutes ago, pocster said:
Oh I see ? I’ll get the company to do that also ! . Presume just 2 recessed hooks near the top is sufficient?
Yep - one each corner
then use a blob of silicone under each bottom corner to stop it moving
I’m actually quite excited by this . Although the designer version had ‘ click for pricing ‘ - we know it would of been ridiculously expensive. So to have made something very similar for ( I guess ) a few hundred quid is awesome ! . The practicality of recessed flipable hooks is largely pointless as coats will always be hanging on them ?
35 minutes ago, pocster said:
So this type of thing ?
https://www.direct-fittingsuk.com/keyhole-hangers-round-metal-recessed-mount-insert-bed-connector-picture-mirror-frame-bracket-30mm-x-6739-p.asp
So presumably I cut the plaster back to the osb and mount them recessed ?
Work better with the plate mounted on the item and screw in the wall, although I can’t see and reason why you can’t do it other way a round, just be aware which way up the slot needs to be.
Got a rough price for the timber and machining ( 160cm x 50cm ) at around £220 + vat . Notice on the quote they’ve put walnut mdf veneer ?
Quickly looked at their website “ real “ walnut will be maybe 400 before machining !!! Ouch ! . Will anyone be able to tell the difference? . Also weight wise ; is real walnut going to be considerably heavier ??
I’ve just done a kitchen in solid oak worktops. To buy new would have been around £2K
bought used off eBay, had to do some repair and jointing but worked out very well … cost £150.00 plus a few hours extra time
6 minutes ago, PeterW said:
Walnut MDF veneer is real walnut on a very stable base. Are they edging it for you too..?
Yes they can do . Is “ real “ walnut worth the extra cost ?? . Will it look different/ feel different??
Veneered is real walnut so looks the same, just doesn’t crack or warp like solid timber can … does! Bloody overpriced, pain in the arse table that was.
Think I'll go for the veneer . Cheaper; also at the width I want they would have to biscuit join 3 pieces.
49 minutes ago, pocster said:
Rather than 36 quid each. I found some quite nice ones for 7 quid each ?
Come on then, show.
From real timber to veneered wood and £36 down to £7.
All mouth and no trousers...nothing new there!
How does veneered MDF do underwater then?
Cut backs due to brexit , Covid , climate change . Sign of the times
3 minutes ago, Onoff said:
Stainless steel "effect"...nice! ?
Tight arse.
To match the walnut ‘effect’ .
I bet it still looks awesome
He has 4 spares in the attic and saved £1.
The cheaper hooks turned up. Seem pretty decent. The 'lip' around them is maybe half a mm. So it's just as well I'm getting the walnut supplier to cut the holes accurately!
