I am about to order some lead flashing and cannot decide on the best code for load soakers to be fitted at a pitched roof abutment.
The online guides say soakers can be made from code 3 or 4 but there is no indication of a preference. My roof has a 30 degree pitch with a natural slate covering.
Code 3 is 1.32mm thick and Code 4 is 36% thicker at 1.8mm. Some say code 4 might kick the slate up a bit more.
My greatest concern is that a code-3 soaker might tear at the upstand bend if the roof structure flexed away from the wall abutment during a storm force gust.
If the roof moves that much during a storm you’re going to have bigger issues than lead tearing ..!
I use lead clips and leadmate rather than mortar these days to remove any issues with minor movement cracking mortar.
My take on this is if the soakers are under the slates (as I prefer not to see too much lead) then code 3 is fine. If the lead is open to being “picked up by the wind” then I would use code 4.
15 hours ago, Conor said:
Our excellent roofers used code 4 for everything. Think it cost me about £500 ?
You only spend it once
I bought a roll of code 4, 2 years ago, told to go and just take it from the pallet, oh how I laughed when I thought they had stuck it down, they hadn’t, it was just a lot heavier than I thought it was going to be, if my memory is correct I think it was 40kg.
A 6m x 210mm roll of code-4 lead flashing about be 26kg according to this page.
https://www.roofgiant.com/code-4-lead-flashing/midland-lead-code-4-roofing-lead-flashing-roll-6m/
And in my case a 6m x 450mm wide roll for the ridges & hips in code 5 is 68kg. That is 2.5 bags of cement in a small package.
I assume the slates will be cut to within 5 or 10mm of the abutment facing brick wall and the stepped cover flashing will protect some of this joint, so there will be very little of the soakers exposed.
I was only thinking of a few mm of movement and was concerned this might tear paper thin code-3 soakers that would be constrained a little by the code-4 stepped cover flashing.
During in the Boxing Day storm of 2020 I was working on the ridge of the main roof tying down the temporary tarps, as the storm built up I was surprised to feel the (incomplete) hipped truss structure moving a bit.
I plan to use home-made lead roll clips but I need to point up in a light sandy colour mortar to match the rest of the brickwork. That leadmate seems like a simpler material to use but think it only comes in a mid grey colour.
Lead rolls are pointless - just buy a bag of clips and forget about it forever. You can point up but consider finding a pale cream external silicone in that case as it’s more stable.
Doesn't silicone rot lead? Hence leadmate. Honestly @epsilonGreedy your worrying too much about the colour. Just use lead mate it looks fine when done. Particularly 3 winters later when half the compo isn't missing.
Code 3 is not paper thin, it’s 0.5mm thinner than code 4.
What is Code 3 lead?
Code 3 lead is the thinnest gauge of lead used in commercial roofing and is suitable for light applications such as soakers at the abutment..
Definitely advice I will take seriously for the chimney flashing on the main 2 storey roof. However this particular abutment which is the first challenge will be just above the principal house entrance.
Yes fair point, as I mentioned in the opening post "Code 3 is 1.32mm thick and Code 4 is 36% thicker at 1.8mm. Some say code 4 might kick the slate up a bit more.".
1.32mm does sound paper thin to me but I have not actually handled lead flashing before. The fact that the industry equally approves of materials with a 36% difference is something I cannot reconcile in my head. Neither would be a mistake it seems. There is always the breather membrane if the soaker fails!
