Pocster Posted July 13, 2021 Posted July 13, 2021 I need to order these up. So have 2 core + earth to each location. 6 fire, 1 heat required Looked at https://www.safelincs.co.uk/radio-interlinked-smoke-alarms/ But they are like £70+ each!! ( with wireless comms between them ) Any other recommendations??? Also need a carbon monoxide detector ( for log fire ) assume this does not need to trigger the others for an alarm ....
Pocster Posted July 13, 2021 Author Posted July 13, 2021 Cheapest one https://www.safelincs.co.uk/fireangel-pro-connected-mains-radio-interlinked-smoke-and-heat-alarms/ Can't seem to find any mains/wireless comms ones cheaper. Just a case of suck it up then ?
Pocster Posted July 13, 2021 Author Posted July 13, 2021 (edited) I see safelincs have some Ultrafire alarms at 30quid each on ebay!! AH! B*LLS not mains Edited July 13, 2021 by pocster
Temp Posted July 13, 2021 Posted July 13, 2021 (edited) Can you use the earth wire for the interlink? I mean is that be allowed? Edited July 13, 2021 by Temp
Temp Posted July 13, 2021 Posted July 13, 2021 4 minutes ago, Temp said: Can you use the earth wire for the interlink? I mean is that be allowed? Ah Google say not allowed. 1
Pocster Posted July 31, 2021 Author Posted July 31, 2021 Thinking about this . Can I just have battery powered wireless interlinked alarms ? Much cheaper . Doesn’t require a sparky to install them . I can just ignore my power cable to each alarm point then . Regs in a domestic new build aren’t it *has* to be mains powered are they ??
ProDave Posted July 31, 2021 Posted July 31, 2021 The time to ask was before you plasterboarded. 2 core & earth to first alarm, then 3 core and earth from that to the next, and the next and the next etc. No need for radio linking. The radio linking bit costs more than the basic alarms. Another vote for Aico. If they are too expensive look on ebay but CHECK the "replace by" date if buying from ebay, lots of old stock about. 1
Onoff Posted July 31, 2021 Posted July 31, 2021 Aico or at a push Aico. Saying that I have once fitted Kidde when I couldn't get Aico in a rush. Wired which were OK tbh if a bit bulky. You can with most get a little test station from where you can test your alarms or in the event of a trigger hush all those except the ones going off. Aico do really good installer/specifier pocket book guides for the sake of a 5 minute sign up.
Pocster Posted August 1, 2021 Author Posted August 1, 2021 So do they HAVE to be mains ? Can I have battery but wirelessly connected ?
Pocster Posted August 1, 2021 Author Posted August 1, 2021 This seems to say yes https://www.aico.co.uk/standard_regulation/fire-building-regulations/ The wireless aspect isn’t the real cost . As you can get battery fed wireless ones for 30 quid a pop
dpmiller Posted August 1, 2021 Posted August 1, 2021 plus you can go hybrid- cable the easy ones, then wireless off them too. I chose to go wireless and to add the fancy test button and a relay box to integrate MVHR control and CO sensing. 1
Pocster Posted August 1, 2021 Author Posted August 1, 2021 39 minutes ago, ProDave said: 3 core cable is cheaper than wireless modules. Sure .
Mr Punter Posted August 1, 2021 Posted August 1, 2021 2 hours ago, pocster said: Can I have battery but wirelessly connected ? No. They need to be mains operated. Buy the Aico ones.
Pocster Posted August 1, 2021 Author Posted August 1, 2021 13 minutes ago, Mr Punter said: No. They need to be mains operated. Buy the Aico ones. Yes , yes ! You buy me the Aico ones ?
tanneja Posted August 24, 2021 Posted August 24, 2021 Is there any way at all of getting black smoke and heat alarms for a residential house without needing to go industrial with panels etc? I saw so many when I did an initial look but after calling a few online stores none know of any domestic sensors that will meet UK regs (i.e. mains powered with battery backup)
