Hi all.
Im looking to self build a frame for a concrete base. I will then call in a company to pump the required pour for the job.
It will need to sustain the weight of heavy ex Army tanks around 60Tons. With the ability to build a workshop on top at a later date.
What depth sub base? Thickness of rebar for base. And depth of pour would I need??
Am am I thinking way out my ability on this project??
regards
Paul.
Edited by Paul211
I've done a maintainance yard for tanks for the Army a right few years back, the yard slab was 300mm thick with 3 layers of A393 mesh and had a 450mm build up underneath. BUT obviously the build up would be ground dependant, I can't be positive now as it's 10 years plus but I think the build up was dependant on CBR results on formation of greater than 5%
Edited by Ronan 1
Missed off mesh size
Don't tank track spread the load, this is partly why they can traverse rougher ground than wheeled vehicles (there are other reasons as well).
True and so the point loading needs careful thought as the transition on and off the slab offers a challenge and you can watch the load spread on a simulation tool but the essential point is that the point loading is actually quite low. 30T per track, and that spread across the area of the track in contact with the slab, but the track format is important as the tread type used also spread the loads differently.
Yeah your correct but if I remember conversations at the time the big pressure came from the slewing movement from the tracks as oppose to point loads
Edited by Ronan 1
Bleeping auto correct
Just now, Ronan 1 said:
sleeping movement
Not sure what that is, sounds like dynamic loads.
Being single and living on my own, I have no understand about what happens when I sleep, other than, I cease to exist.
1 minute ago, Ronan 1 said:
slewing
I prefer sleeping at the moment.
400,000 extra people in Cornwall this week, I and have fed at 1000 if them.
Sounds like there will be plenty of slewing about Cornwall this week too...
Edited by Ronan 1
My journey to work is going to have to be in escorted convoy apparently. We have not heard too much more this last week.
Still, I can write slogans on the side of the car.
Edited by SteamyTea
Why do you need to put it on concrete? What about stone and gravel?  Then build a workshop around it on normal foundations ...
  • 5 weeks later...
From my office window in Berlin years ago I regularly saw the devastating effect of tank tracks on well maintained German roads.  It was the slewing at the roundabouts that caused the most aggro.
The local Tankies exercised their right of passage through Berlin every month. They were always followed by a road repair crew. I watched bemused at a protester who enraged by their passage,  stopped infront of the column, threw her bike at the lead tank. Whereupon the whole column about-faced and buggered off. AS all four tanks turned-tail,  400 meters of the road was shredded as if by a huge grater. The mess was a sight to behold.
The surface of your tank park will need to be very tough indeed  - and I should think the tanks'll need rubberised tracks too.
