Tom Posted April 30, 2021 Posted April 30, 2021 Hi all - does anyone have any recommendations for triple glazed sliders? We need narrow sightlines, so are looking for an aluminium system, and we need a 4m run and 6m run meeting at a moving corner. So far I have come across Sieger and Reynaers that will do 3G, and Ultraline and Schuco that are 2G. Any suggestions would be very welcome! Â
Thorfun Posted April 30, 2021 Posted April 30, 2021 when we were looking at a corner opening sliders we went to take a look at Solarlux Cero range. they are stunning! but also extremely expensive. Â We also looked at Reynaers, or rather we looked at rebadged Raynaers from ODC (https://www.odcglass.co.uk), and they are also very nice but I had concerns about the PAS24 compliance iirc. ODC also do Solarlux so it was great for us to visit their showroom as we could see both next to each other. Â in the end we decided that the cost for the corner opening just wasn't worth it for us and we ended up with having a corner support pole. it will save us many thousands of pounds and I'm sure it will still be lovely.
Eric Posted April 30, 2021 Posted April 30, 2021 Internorm might be worth a look? I believe they can do a 6m slider but not sure about aluminium.
Tom Posted May 1, 2021 Author Posted May 1, 2021 Thanks both. Internorm is an option I believe Eric (we're going for their windows) but the composite frames are quite chunky compared to the aluminium profiles of the others. Thanks for the heads up re ODC Thorfun. Reynaers don't seem to be replying to my emails so I might check them out. Poole isn't a million miles from here either.
Bitpipe Posted May 1, 2021 Posted May 1, 2021 We have Gaulhoffer - the slimline 92 profile. May not be slim enough for your requirements but much less chunky than Internorm.
ToughButterCup Posted May 2, 2021 Posted May 2, 2021 Ditto Gaulhofer.  Tell me @Tom, what's a narrow sightline ?
Tom Posted May 2, 2021 Author Posted May 2, 2021 *thin frame  Are you not down with glazing salesman speak?!
SuperJohnG Posted May 2, 2021 Posted May 2, 2021 I have zyle fenster coming. Doing 4.6m slider in two leafs. 3g Aluclad wood.Â
craig Posted May 7, 2021 Posted May 7, 2021 You’ll struggle to get one in timber/alu with a corner opening.  Solarlux Cero III and Reynaers Hi-Finity is what you’re looking for but they ain’t cheap options. On 02/05/2021 at 19:19, ToughButterCup said: what's a narrow sightline ? Different for everyone but the mullions in the two above are approx 35mm.
Tom Posted May 8, 2021 Author Posted May 8, 2021 Thanks Craig, we're not looking at alu clad as too chunky. Will look at solarlux though, as per Thorfun above too. Fyi, looks like seiger are rebadged Cortizo.Â
bob the builder 2 Posted November 5, 2023 Posted November 5, 2023 avoid odc at all costs - quick search on google / trust pilot confirms the many issue people have had - wish i had read before going with them it has been a nightmare on terms of quality / air  tightness and thermal performance - and that before customer services get involved ! Â
