Bonkers idea or a great idea?
I like his style :)
log store that doubles up as an air raid or earthquake shelter
  • Replies 125
  • Views 19.2k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • canalsiderenovation
    canalsiderenovation
    Yesterday we worked so hard - all panels painted back and front and fixed on now. It's looking so good and I took some pics from towpath side too. The planting on the bank is looking good now too, kin
    canalsiderenovation
    Ok so about half done and here's a glimpse of what we have done today and what they will look like with the fence panels bracketed on. The wooden posts are fixed onto the barriers/posts, not concreted
    canalsiderenovation
    Finally finished the woodstore, so far roughly moved about 7 tonne bags of wood into it. And yes, those corner bits are leftover bits from the cladding. It's just outside our utility door so convenien
Posted Images
1 hour ago, markc said:
I like his style :)
We said exactly the same thing. The chickens quite liked it too so potential chicken coop if we run out of wood.
I won’t show you mine (wood store that is ?) made from old pallets and left over roofing from my garage (and it’s hid round the back so you can’t see it ).
I think pallets would have worked fine too and probably cheaper! I'm sure I'll be thankful it's close by our utility door in winter!
Edited by canalsiderenovation
2 minutes ago, Ferdinand said:
There's currently a shortage of pallets.
But I don't know if you can yet dismantle them and sell off for more than the price of a new shed.
I'm quids in then as we have half a dozen knocking about....
So you now have some wood to store in your woodstore !
We have too much, still got another 3 tonne bags plus stuff we need to split. Some is quite small so we may be burning it on the narrowboat in winter.
4 hours ago, canalsiderenovation said:
Yep, dad got lengths and then cut them and welded them to build the frame and galvanised sheet mesh, again a sheet which we cut three sides from and fixed into the frame. It's cost a small fortune but dad doesn't do anything by halves.
Like getting an answer from SWMBO! ?
Did he buy the lengths of steel "mill finish", weld them together then get the whole assembly galvanised at a place that specialises in hot dip galvanising?
Did he weld on plain finish mesh and send the whole lot to the galvanisers or did he get the galv frame back etc?
Is your Dad on here, can I ask him??? ??
So they need to be used to build a woodstore like @joe90's from them to keep the other wood in.
Which I was planning to find a picture of but it seems he has never uploaded one.
Full of good ideas, me.
Bin store is another thing I've seen pallets used for.....
Time for a 1970s joke about pallets.
There was a boat load of Vietnamese people that arrived in Calais, the French refused to take them. "Go to England" they said.
When they arrived at Dover, the English refused to take them "Try Ireland" they suggested.
When they arrived at Dublin the Irish said. "Are they on pallets".
Edited by SteamyTea
Then why don't the builders merchants offer to collect them for free and re use them?
I thought so, not worth the cost.
Oh go on then, includes compost heap as well (the steel mesh is to stop my terrier pulling logs out to get to mice/rats in the log pile)
1 minute ago, Ferdinand said:
Pallet Timber Price Index
Ribbed for extra sensitivity.
I've watched a jack burrow through a bag of feed to get to the rat's nest behind.
The mesh was bought already galvanised then cut to size. The steel frame were second hand fence post again ready galvanised with fence brackets on (took 6 posts with off cuts left over). Dad made it all up and welded up in situ then just silver can car spray on weld joints, mesh screw on inside frame to secure, then all bolted in and fixed.
I love the smell of galvanised steel being welded, gives me time take a few steps back before I take in a deep breath.
Haha, once spent a whole day flame cutting halved steel structure … that evenings “hot and cold shakes” zincpoisioning wasn’t pleasant ?
Similar to a night on the piss, except it lasts a lifetime.
If it doesn't kill you!
Gotcha! It did look "sprayed" around the plates etc. Würth Zinc Light is an excellent "silver" cold galvanising paint.  For a darker zinc then their Zinc Dark.
The term "cold galvanising" is a bit misleading tbh - they all come in a can but some are better than others. Zinga is very good. Galvafroid is the old favourite.
