readiescards Posted February 19, 2017 Posted February 19, 2017 I wish to detect when the bath/shower plastic drain pipe has warm waste water running through it. I don't need to accurately know the temperature of the water simple that it is present/not present. My first thoughts are to attach a DS18B20 temperature probe to the underside of the white plastic waste pipe using some sort of thermally conductive glue (any glue recommendations?) and look for a temperature change with a RPi. Maybe that is over kill, any better ideas please Oh and do metal waste water pipes exist?
PeterW Posted February 19, 2017 Posted February 19, 2017 55 minutes ago, readiescards said: Oh and do metal waste water pipes exist? Yep - waste used to be done in Copper and JTM still do it in some big sizes. If you just want a short length of it though eBay is probably cheaper
Triassic Posted February 19, 2017 Posted February 19, 2017 (edited) Usually the heat recovery pipework is connected to say a shower outlet, the cold feed to the shower passes through the heat recovery system. So using the shower operates the heat recovery. In that way you don't need and sensors or valves, other than the user operated shower valves. Edited February 19, 2017 by Triassic
SteamyTea Posted February 19, 2017 Posted February 19, 2017 1 hour ago, readiescards said: My first thoughts are to attach a DS18B20 temperature probe to the underside of the white plastic waste pipe using some sort of thermally conductive glue (any glue recommendations?) and look for a temperature change with a RPi. That seems the easy approach, silicone should bond it. You can get them already pre-wired and waterproof. There is code to sense when the temperature changes too.
daiking Posted February 19, 2017 Posted February 19, 2017 54 minutes ago, PeterW said: Yep - waste used to be done in Copper and JTM still do it in some big sizes. If you just want a short length of it though eBay is probably cheaper I was in a pub recently, taking a leak, and noticed all the 40-50mm sized waste pipes were in copper. Not something you see very often. ill take a picture next time if anyone is interested
readiescards Posted February 19, 2017 Author Posted February 19, 2017 The reason for doing this is log a bath/shower event occurred and maybe drive the mvhr to boost mode. Fyi I definitely don't want boost mode until the bath is draining -ruins the thinking time
Onoff Posted February 19, 2017 Posted February 19, 2017 1 hour ago, daiking said: "40-50mm sized waste pipe" ill take a picture next time if anyone is interested Boasting again? I trust that's diameter not length?
SteamyTea Posted February 19, 2017 Posted February 19, 2017 I am so tempted to say something, but we now have a 'special' thread for all that sort of thing.
Triassic Posted February 19, 2017 Posted February 19, 2017 2 hours ago, readiescards said: The reason for doing this is log a bath/shower event occurred and maybe drive the mvhr to boost mode. Fyi I definitely don't want boost mode until the bath is draining -ruins the thinking time Why not use a Humidity sensor ?
SteamyTea Posted February 19, 2017 Posted February 19, 2017 It will hit 100% RH very quickly I would think. Probably before the bath is full.
Jeremy Harris Posted February 19, 2017 Posted February 19, 2017 (edited) The simplest way to do this might be to use a cheap thermal switch bonded to the waste pipe and fed to the MVHR dry contact boost connection. Something like this: http://www.ebay.co.uk/itm/KSD-9700-Temperature-Switch-Thermostat-Thermal-Protectors-20-and-25-degrees-/281790336437?var=&hash=item419c034db5:m:mQq9kyBHVG4C7euaGe1_h1g They are out of stock of the normally open ones you would want, but a 25 deg C normally open thermal switch should do the job OK. Edited to add: Alternatively, if you don't mind running a 12V supply nearby and want adjustment, then the cheap thermostat units from China are pretty versatile, have dry contacts and are adjustable over a wide range: http://www.ebay.co.uk/itm/Hot-DC-12V-Digital-LED-Thermostat-Temperature-Control-Switch-Module-XH-W1209-TC-/391659881408?hash=item5b30bf83c0:g:95sAAOSwA3dYXVNl Edited February 19, 2017 by JSHarris added more info 1
readiescards Posted February 20, 2017 Author Posted February 20, 2017 Would epoxy resin make a suitable thermal conductive bond?
Jeremy Harris Posted February 20, 2017 Posted February 20, 2017 39 minutes ago, readiescards said: Would epoxy resin make a suitable thermal conductive bond? It would, but it doesn't bond well to PVC, whereas stuff like neutral cure silicone does (most acetoxy cure silicones don't bond that well, I've found). Some neutral cure silicones, and modified silicone polymers (like CT1) will bond well to almost anything. I've been impressed with the way Dow Corning 799 bonds to PVC in particular, as it's a fairly cheap and readily available sealant/adhesive that seems to be a good all-rounder, despite being primarily intended as a glazing sealant. 1
Onoff Posted February 20, 2017 Posted February 20, 2017 If you're really worried.....and rich: http://uk.rs-online.com/web/p/products/1558320/?grossPrice=Y&cm_mmc=UK-PLA-_-google-_-PLA_UK_EN_Adhesives_And_Sealants_And_Tapes-_-Adhesives_And_Glues&mkwid=s0L91DEDC_dc|pcrid|88057075443|pkw||pmt||prd|1558320&gclid=CLGPvvuPntICFe0V0wod-h4Bxg I thought you were going to introduce a section of copper? Btw, what dia copper pipe would you need? 1
Gone West Posted February 20, 2017 Posted February 20, 2017 When building PCs I've used Arctic to glue CPUs to the heatsinks. 1
readiescards Posted February 22, 2017 Author Posted February 22, 2017 On 20/02/2017 at 07:18, Onoff said: Btw, what dia copper pipe would you need? Currently 43mm white plastic...
Trw144 Posted February 22, 2017 Posted February 22, 2017 Why not use some heat transfer paste and a jubilee clip 1
