A few builders interested, each suggesting a different approach to the contract.
A. Main contractor fixed price
B. Main contractor till water-tight shell, with airtightness preliminary test. Then individual trades for the rest, or main contractor hired for the rest
C. Labour only guaranteed maximum price including profit till water-tight shell with preliminary airtightness tested, materials purchased by us using trade account set up by builder in our name (hopefully with their discounts applying to us). Others contracted to supply and fit the rest
D. Main contractor agreeing to use Estimators Online quantities & prices, 10% profit, 5% overheads, 5% builder contingencies
E. Main contractor with target cost, guaranteed minimum profit for them, plus incentive payable if target cost met, plus half share in any cost savings
All seem reasonably reputable. Option D does not have regular staff or regular subbies. Others do.
Context: No time or skills for DIY.
Which of the approaches would you choose, and why?
Which figures are you using from Estimators Online? as there is already profit and contingencies build into the 'client' quote, make sure you aren't double counting.
Yes, no double counting. The spreadsheet allows profit/overheads/contingencies to be set to zero if desired.
Whats more important to you ? Someone to manage the risk or cost .
Would option D be on site every day during the build Managing the sub contractors or would he just slice the job up and book the trades meet on day one and give me a call when your done and I'll come.and check your work.
Whats the difference in price between A and D .%.
All will use subcontractors
Up to roof and individual trades will work out cheaper than main contractor
But you will need to know what you are looking at As individual trades won’t follow drawings unless they have to
Yes, D likely to be hands-on. Might even take on the site foreman role.
Price from A awaited
That's my hunch.
Airtightness 4.0 preliminary test at watertight stage is main safeguard. If they get that, SAP pass assured.
Architect will supervise & give CML certificate.
26 minutes ago, WWilts said:
That's my hunch.
You should be aiming much lower than a 4. It's not that hard to get that which means very little effort on their behalf.
So a hands on contracts manager for 10% of the build cost ?
assuming the on line estimator is not under or over by a large % on each step and  if you haven't the time to self manage or the skills to diy large parts of the build this could be a sensible option .
I agree
we were 2.2 Block and block
Though I’ve little faith in air testers
Yes, and if we aim for 4.0 we're bound to get 6.0. So aiming lower is a good idea
Neat way of looking at it. Had not occurred to me.
Main contractor/builder who project manages trades, supervises & maintains standards, & is happy to accept an independent estimate of quantities.
They normally buy plots & build to sell off plan. Probably going through a lull at the moment, so available for this.
I offered them a share in cost savings too. Already they proposed some ways of saving costs.
Getting the plasterboard junctions well taped seems to be the critical point, as well as sealing windows/doors.
Will aim for as low as possible, then might well achieve better than 4.0
It's more a case of they get a 5 and go sure that's not really much of a difference and convince you 5 is the result of hours of meticulous work. If you push for a 2 or 3 then your looking it done right and at the end of you score a 5 then that's a mile out.
What type of build are you going for.
We'll fail SAP with 5.0, so they won't convince us
4 minutes ago, WWilts said:
How so?
You will pay all the VAT on materials at 20% and only able to do one claim at the end. Builder can claim monthly and zero rate the supply to you.
Most lenders will loan on stage basis and assume no VAT so you need to find 20% extra each time yourself.
It is and around and under windows and doors
Get that right and you have no need to worry about airtightness
I took this photo when I started plastering ours
My trusted helper also Mixed every bag of plaster and 250 bags of render
I’ve got her a battery mixer for our next build
10 minutes ago, Moonshine said:
Those dabs around sockets, beautiful
Yeah it’s not rocket science
But everything must be sealed
Good practice to run a line of acoustic sealant around all ceiling angles also
