Ferdinand Posted December 9, 2020 Share Posted December 9, 2020 After 7 or 8 years, my front door needs an adjustment. The symptom is that it no longer closes snugly, and bounces open again if closed gently with no hand on the handle. To shut it properly the handle ahs to be held in open position and the latch closed carefully. The latch can be made to shut with an almost slam + hold. The only thing I have done recently has been to remove and reinsert the Euro-Barrel as I needed to check the dimensions. Can any knowledgeable cove tell me what aspect of the door is likely to need adjusting? Do I need, for example, to tighten the door in towards the hinges. Thanks Ferdinand Link to comment Share on other sites More sharing options...
Declan52 Posted December 9, 2020 Share Posted December 9, 2020 Have you tried to adjust the barrels so it's out at its max and then turn and check each time until it won't close properly. Link to comment Share on other sites More sharing options...
Hobbiniho Posted December 9, 2020 Share Posted December 9, 2020 Sounds like you need to adjust the keeper slightly, should be able to slacken the screws and move it slightly. Also worth checking thatbthe frame hasnt twisted slightly Link to comment Share on other sites More sharing options...
Ferdinand Posted December 9, 2020 Author Share Posted December 9, 2020 I haven't tried adjusting anything yet ? . Try one has been to spray some WD40 on the latch. It looks as though it wasn't springing back out again when closing the door. Cause may be that I disturbed some gunge when playing with the cylinder. Will see after a day or two. Potentially it may be worth cleaning it with a toothbrush. F Link to comment Share on other sites More sharing options...
dangti6 Posted December 9, 2020 Share Posted December 9, 2020 One of my UPVC doors has started to do exactly the same thing. Not sure if it’s got anything to do with the temperature dropping - only say that as another of my doors drops slightly on a really hot day. Link to comment Share on other sites More sharing options...
tonyshouse Posted December 9, 2020 Share Posted December 9, 2020 In the last couple of years the DraughtBusters have adjusted quite a fe upvc doors to realign the striker, some needed to be raised at the hinge side to lift the whole door. They do drop, warp and deform. a few needed adjustment of the latch plate and two needed replacement latch plate /keep 1 Link to comment Share on other sites More sharing options...
dangti6 Posted December 9, 2020 Share Posted December 9, 2020 Just sorted mine, there is a screw missing in the central catch plate and the plate was at an angle. You may be lucky and find yours has moved also. Pushed it square and it’s sorted. Can’t see the screw anywhere annoyingly so will have to rummage for a countersunk screw and cut it down to length - they are only tiny. Link to comment Share on other sites More sharing options...
newhome Posted December 9, 2020 Share Posted December 9, 2020 1 hour ago, tonyshouse said: In the last couple of years the DraughtBusters have adjusted quite a fe upvc doors to realign the striker, some needed to be raised at the hinge side to lift the whole door. They do drop, warp and deform. Where do you find a DraughtBuster? Sounds like something my door needs. I’ve fiddled with the striker / keeper but it only serves to make the door difficult to close. I can feel a draught when the wind gets up. Link to comment Share on other sites More sharing options...
tonyshouse Posted December 9, 2020 Share Posted December 9, 2020 https://readinguk.org/draughtbusters/ 1 Link to comment Share on other sites More sharing options...
dpmiller Posted December 9, 2020 Share Posted December 9, 2020 business? Link to comment Share on other sites More sharing options...
tonyshouse Posted December 9, 2020 Share Posted December 9, 2020 No, philanthropic - plenty of info on the website Link to comment Share on other sites More sharing options...
Ferdinand Posted December 10, 2020 Author Share Posted December 10, 2020 WD40 seems to have fixed mine ?. Thanks all. 1 Link to comment Share on other sites More sharing options...
