Triassic Posted January 19, 2017 Posted January 19, 2017 My cheap and cheerful Nu-Tools 240v drill has died after a long hard life. It's the drill I tend to use then all the battery drill batteries have been exhausted and are on charge. I need a drill with a tradition chuck, I already have an SDS drill. So, what would you recommend?
ProDave Posted January 19, 2017 Posted January 19, 2017 Before you chuck it, check the brushes. Almost certainly what's wrong and almost certainly replacable. 1
Construction Channel Posted January 19, 2017 Posted January 19, 2017 +1 to dave, but if not I bought a cheap draper one, £20 IIRC works fine for the amount i use it (virtually never)
Triassic Posted January 19, 2017 Author Posted January 19, 2017 I've had the drill at in bits before I posted, the gears are worn out. To be honest I rarely used a mains drill, it's my fall back when my battery drills are flat. So cheap is good!
Construction Channel Posted January 19, 2017 Posted January 19, 2017 Unfortunately i can't find the invoice, so I must not have bought it from eBay but it was something along these lines http://www.ebay.co.uk/itm/HEAVY-DUTY-DRAPER-20498-600W-ELECTRIC-HAMMER-DRILL-VARIABLE-SPEED-IMPACT-DRIVER-/262389170560?hash=item3d179d0180:g:-YEAAOSw9j1XEU96 maybe it was £30..... maybe it was on offer but i essentially bought the cheapest 240v drill i could find,
Simplysimon Posted January 19, 2017 Posted January 19, 2017 https://www.aldi.co.uk/c/specialbuys/diy?q=%3Apopular&page=0 drill and compressor, perhaps more than you're wanting to spend but with the compressor other items can be added as req. simon
Onoff Posted January 19, 2017 Posted January 19, 2017 (edited) You wanted cheap & traditional chuck, how does £15 delivered sound: Pro User: 500W http://www.ebay.co.uk/itm/500W-Electronic-Hammer-Normal-Drill-Front-Handle-Spare-Carbon-Brushes-/322281831500?hash=item4b097e7c4c:g:q~IAAOSwKtVWuMWb or Silverline: 500W with 3 year g'tee for a couple of quid more: http://www.ebay.co.uk/itm/500W-230V-Electric-Power-Tool-Hammer-Drill-3-YR-Warranty-Concrete-Wood-Steel-/221836065643?hash=item33a675bb6b:g:QDoAAOSwNSxVC1Le or Sealey 750W: http://www.ebay.co.uk/itm/Sealey-S0686-Electric-Hammer-Drill-13mm-750w-230v-Comes-with-extra-products-/272375303408?hash=item3f6ad54cf0:g:rgcAAOSw8w1X2GPo Edited January 19, 2017 by Onoff
Steptoe Posted January 19, 2017 Posted January 19, 2017 siegen make some reasonable decent hand tools, spanners etc, so if thats anything like them, then prob not bad at that price, then again, that silverline is probably the same generic stuff as all the other cheap stuff so not a bad buy either, just treat it as a consumable,
Onoff Posted January 20, 2017 Posted January 20, 2017 Don't forget Gumtree & Preloved etc if you don't mind second hand. There's a few "used only about 4 times" etc for £20 ish. Better of course if you're local to the seller. There's plenty of power tools get bought by/for non diy'ers then sit under the stairs until someone has a clear out. Equally some think they no longer need it as they've gone cordless. Thinking that way you might get a better make. My first Bosch lasted me 20+ years and two houses.
Guest Alphonsox Posted January 20, 2017 Posted January 20, 2017 How about a bosch hammer drill https://www.amazon.co.uk/Bosch-PSB-750-Hammer-Drill-x/dp/B003UES78K/ref=lp_7613916031_1_9?srs=7613916031&ie=UTF8&qid=1484905034&sr=8-9 Use code BIGTHANKS (today only) and get £10 off taking it down to £44
Nickfromwales Posted January 20, 2017 Posted January 20, 2017 Buy one of these and stick it in your sds drill which you already own
Nickfromwales Posted January 20, 2017 Posted January 20, 2017 I tried the auger bits with sds but bloody clutch kicks in. My old 3-speed makita 18v sends them through like a knife through butter. I have considers trying these but just worried about how much harm I can do to myself with it.
Construction Channel Posted January 20, 2017 Posted January 20, 2017 3 hours ago, Nickfromwales said: My old 3-speed makita 18v when you fancy an "upgrade" ill take that off your hands. Some bstard stole mine and they don't make them anymore
Triassic Posted January 20, 2017 Author Posted January 20, 2017 I had a quick look in B&Q, Bunnings, Aldi and Argos, the cheapest main drill I could find was £12.95 in Argos.
Nickfromwales Posted January 20, 2017 Posted January 20, 2017 Shall I change the title of the thread to "how cheap a drill can I buy?"
Nickfromwales Posted January 20, 2017 Posted January 20, 2017 32 minutes ago, Construction Channel said: when you fancy an "upgrade" ill take that off your hands. Some bstard stole mine and they don't make them anymore ✌️️ I sold mine on eBay a couple of years back for no reason whatsoever other than I had just bought the 2014 twin pack ( with the less than impressive 2-speed ) and wanted to put the money back in the pot rather than own 2 combi drills. WHAT A BAD MOVE Ive been scouring the usual places for one ever since, and then my sparky chirps up that he doesn't want his anymore and did I want it for £20. SOLD! ? ( so basically, in answer to your question ) NO CHANCE ?
Steptoe Posted January 20, 2017 Posted January 20, 2017 4 hours ago, Nickfromwales said: I tried the auger bits with sds but bloody clutch kicks in. My old 3-speed makita 18v sends them through like a knife through butter. I have considers trying these but just worried about how much harm I can do to myself with it. yep, one surefire way of destroying your sds, half of one hole and I went to the van and got the combi out, [oh, just read that back, so it does appear that you actually can have HALF of a hole,,,,, ]
Onoff Posted January 20, 2017 Posted January 20, 2017 1 hour ago, Triassic said: I had a quick look in B&Q, Bunnings, Aldi and Argos, the cheapest main drill I could find was £12.95 in Argos. I think we have a winner with that! Might be a better bet going for their £13.99 on as in don't go for the cheapest? http://www.argos.co.uk/product/7106062 I went through a phase of buying I think Nu-tool tat from Makro as they were dead cheap, got a: dead cordless drill, dead mains sabre saw, dead 24V sabre saw working circular saw working mains delta sander I use NONE of them! 3/8" router from Aldi - working save for an irreplaceable broken piece dead mains brad stapler from Aldi I use neither of them Got 9.6V Bosch and 12V Makita drills with no batteries etc. Could probably fill a couple of filing cabinet draws with duff power tools!
Onoff Posted January 20, 2017 Posted January 20, 2017 2 minutes ago, Nickfromwales said: ? Throw them out, maybe? Can't, crap magent / pikey genes. I can't even pass a skip without braking!
