Russell griffiths Posted November 5, 2020 Author Posted November 5, 2020 14 hours ago, Nickfromwales said: Hepworth for HRC needs to be temperature capped so a TMV is required in every instance. I’ve been using the same TMV that goes on the SA units as they’re decent reliable units. I set those to 50oC nominal and happy days. The question of how much of an arse your BCO is, whether or not they make you drop the bath to 46oC as “god intended” ( some BCO’s think they’re ‘up there’ for sure, and some are just massive bell-ends ). ??. Best to check before assuming that 50oC everywhere is acceptable. Can you not just set the TMV to 46 for sign off, then turn it up afterwards. 1
Thorfun Posted November 7, 2020 Posted November 7, 2020 I have another question about using manifolds. does using them preclude the need for a hot return circuit or can you use an HRC with a manifold setup? and if the later, is it recommended to use the HRC with the manifold setup or not?
Russell griffiths Posted November 7, 2020 Author Posted November 7, 2020 1 hour ago, Thorfun said: I have another question about using manifolds. does using them preclude the need for a hot return circuit or can you use an HRC with a manifold setup? and if the later, is it recommended to use the HRC with the manifold setup or not? I asked this question long ago as I was confused, mine are going in this week, 3 manifolds in total cold hot hot return. The hot return is for the hots that have a distance to travel the kitchen and one bathroom are right next to the plant room so just a normal hot feed to them. 1
LA3222 Posted November 7, 2020 Posted November 7, 2020 10 minutes ago, Russell griffiths said: I asked this question long ago as I was confused, mine are going in this week, 3 manifolds in total cold hot hot return. The hot return is for the hots that have a distance to travel the kitchen and one bathroom are right next to the plant room so just a normal hot feed to them. Don't suppose you've drawn a schematic that we can have a nosy at? Everyone loves a good drawing to plagarise?? 2
PeterW Posted November 7, 2020 Posted November 7, 2020 No issue with HRC and manifolds - just return the hot return back to the top of the UVC as per the return port. 1
Russell griffiths Posted November 8, 2020 Author Posted November 8, 2020 (edited) 10 hours ago, LA3222 said: Don't suppose you've drawn a schematic that we can have a nosy at? Everyone loves a good drawing to plagarise?? Nope. ?? Its all in the plumbers head, I just do as he says, as he gets all grumpy when I ask too many questions. Edited November 8, 2020 by Russell griffiths
Dan F Posted December 18, 2020 Posted December 18, 2020 Does this approach make any sense? - 4-port manifold in plant room (one port for each bathroom/kitchen) - 3-port manifold in each bathroom for WC/basin/shower. Seems it would use less pipe than using a single central manifold for all outlets, and still give you the isolation benefits. For any bathrooms not close to the plant room, you can then implement a return loop from satellite manifold couldn't you? If you want wanted to limit flow rates (to comply with building regs), without buying special 9l/min showers, where would the best place be to do this if using satellite manifolds?
Russell griffiths Posted December 18, 2020 Author Posted December 18, 2020 3 hours ago, Dan F said: Does this approach make any sense? - 4-port manifold in plant room (one port for each bathroom/kitchen) - 3-port manifold in each bathroom for WC/basin/shower. Seems it would use less pipe than using a single central manifold for all outlets, and still give you the isolation benefits. For any bathrooms not close to the plant room, you can then implement a return loop from satellite manifold couldn't you? If you want wanted to limit flow rates (to comply with building regs), without buying special 9l/min showers, where would the best place be to do this if using satellite manifolds? Pipe is cheap, I’ve just done the entire house 4 bathrooms, kitchen and utility room with 400m of pipe, about £500. Single pipe to every cold, hot return loop to hots. Took two days to run it all and another two to tidy it lag the hots and clip it all up. Your way if you flush the the toilet and then go to clean your teeth you are robbing the basin cold until the toilet has re filled.
Thorfun Posted December 18, 2020 Posted December 18, 2020 49 minutes ago, Russell griffiths said: 400m of pipe, about £500 I apologise if this has been mentioned before but was that hep2o?
Dan F Posted December 18, 2020 Posted December 18, 2020 1 hour ago, Russell griffiths said: Your way if you flush the the toilet and then go to clean your teeth you are robbing the basin cold until the toilet has re filled. Not in pipes/manifold are sized correctly surely. Assume that muitlple satellite manifolds plumbed direct is still better than a loop? (e.g. for using two showers at the same time)
Nickfromwales Posted December 19, 2020 Posted December 19, 2020 1 hour ago, Dan F said: Not in pipes/manifold are sized correctly surely. Assume that muitlple satellite manifolds plumbed direct is still better than a loop? (e.g. for using two showers at the same time) One manifold per outlet, eg do NOT stream manifold to manifold if they have isolations as you’ll start to eat into flow rates. A single centralised hot manifold with the HRC to that only is quite economical, and a hot manifold means even long hot runs have to be very long before needing a dedicated HRC.
Nickfromwales Posted December 19, 2020 Posted December 19, 2020 2 hours ago, Thorfun said: I apologise if this has been mentioned before but was that hep2o? Yup. 1 1
