Gone West Posted August 19, 2020 Posted August 19, 2020 I have an air blown sewage treatment plant with a Secoh EL-100 air pump that had been installed for ten years. The air pump stopped working the other day and when I opened it up the inside was covered in metal dust. The magnet had obviously stopped running centrally and had been rubbing against the metal surrounding the coils. I don't know why it did that but I've replaced it with a Secoh JDK-100 and hopefully it will last at least ten years as well. It has run continuously for all that time so not too bad. The new one uses a lot less electricity so one bonus. 1
joe90 Posted August 19, 2020 Posted August 19, 2020 Wow, ten years is good, hope mine lasts that long, can’t remember what pump I have but secoh sound familiar. 1
ToughButterCup Posted August 19, 2020 Posted August 19, 2020 From the title I thought you meant your hip...... You've sent me scurrying to find out what my pump rating is.
Gone West Posted August 19, 2020 Author Posted August 19, 2020 2 hours ago, ToughButterCup said: From the title I thought you meant your hip...... Don't say that, just don't. I'm at that age when it's not a joke anymore. 2
scottishjohn Posted August 19, 2020 Posted August 19, 2020 knees and right ankle are my sore points --but hope once i stiop being onthese damn bankings at 40 degrees they might stop complaining easy week on the body --hired a 3t digger --but major brain fade problems getting used to the controls and moving 3 things at one time -first time working a digger for me a lot harder than flying a plane its a new takiuchi 230 --very mouse powered is my impression of it - and the blade is not wide enough --tracks are slightly wider so if you are trying to flatten uneven ground the tracks can end on a high bit and that will tilt the blade and dig in more at one side,so you have to have 3 goes at same bit ot get it flat -middle -then left and right bit of a gimmick really I,m trying to scrape off all the old crap and roots of my roads down to old tarmac etc you would have thought by now they would have an auto dig or level function like set the depth and it keeps doing it all you have to is close the bucket and lift it out
ProDave Posted August 19, 2020 Posted August 19, 2020 Keep at it, you will soon get the hang of it. The Dozer blade on mine was wider than the tracks.
Pete Posted August 20, 2020 Posted August 20, 2020 10 hours ago, ProDave said: Keep at it, you will soon get the hang of it. The Dozer blade on mine was wider than the tracks. +1 to that, my wife, son and me are all self taught. It's good fun, especially when your turn it in its side
