So as I understand the building regs, with an integrated garage there has to be either a 100mm step down from house to garage, or a level access with the garage floor sloping away from the garage/house access.
Does anyone know what is the minimum gradient for the slope. It doesn't seem to get a mention anywhere.
I'd hazard a guess fumes also play a part,
In a commercial garage with a pit , that pit becomes an explovsive atmospherere due to fumes gathering there,
You definitely need a fire door. In Scotland there is no option for a level threshold, you must have a step. A single garage does not need vents, but a double one will, I forget what size triggers that need.
Thanks for the replies.
Yes, I know the adjoining door has to be a fire door.
I hadn't picked up on the air vent so will look into that.
As for gradient I was thinking more of a 2 degree at most, with a 10 degree I have visions of jet washers /  compressors etc etc all rolling out every time I open the garage door :D
2 degrees is fine - just watch where you put your door and threshold drain as it needs to be aligned or you can get rain running down the front of the door and under the edge.
Thanks for the input.
Just done a bit of working out and even it I only put approx 0.6 degree fall onto a floor slab of 8.7m it will still be a differential of 87mm. I may as well just go with the 100mm step and a level floor.
Does anyone know where the air vent to garage gets a mention in building regs, English version??
Edit
Thinking about it a bit more. The build will be in ICF with a render finish and so I don't want to put in an air grate.
If I was to put in an extract from the MVHR unit surely that would satisfy building regs.
Edited by RichS
Guest Alphonsox
That would potentially pull fuel vapour into the house which doesn't sound like a good idea. I doubt building control would go with this as a solution - you are trying to isolate the garage from the rest of the building.
How about a vent in the garage door if you need one ?
would totally agree with that,
I'd be fairly sure the vent has to be low level, the idea is to vent noxious fumes, (which are heavier than air), out,
Ok, can see your point on this.
So does anyone know where this air vent is mentioned in the regs please??
Presumably somewhere in Part F.
Edited by RichS
16 minutes ago, ProDave said:
Scottish regs says in a garage large enough to need vents, it needs two at low level and two at high level.
At what size???
I've just been through Part F and can't find any mention of garage ventilation in the English regs :S
