Russell griffiths Posted June 19, 2020 Posted June 19, 2020 Can anybody @Onoff @PeterW recommend a glue for fitting. Brown underground drainage pipe to grey solvent weld. Ta very much.
Onoff Posted June 19, 2020 Posted June 19, 2020 I've done it but it stemmed from my ignorance really. I built in a length of brown soil in the wall from the wc instead of specific black/grey solvent weld. Imo the brown doesn't melt as well as the black/grey. The black grey also feels a bit more brittle. Get both surfaces clean with IPA or similar. I roughed up the brown to get the shiny surface "glaze" off and give the solvent something to key to. Tbh I had a few sleepless nights over it so backed it up with CT1. Anyway, I used this instead of the standard brush on solvent as it was also a bit loose for my liking being two different makes. https://plasticsuppliesdirect.co.uk/polypipe-gap-filling-cement-clear-140g.html 1
Pocster Posted June 19, 2020 Posted June 19, 2020 (edited) 57 minutes ago, Onoff said: I think @pocster just used the same stuff too? Bought it but never used it for some reason . Tiger seal seems to of done the job ; think @nod said to go that route . Edited June 19, 2020 by pocster
PeterW Posted June 19, 2020 Posted June 19, 2020 1 hour ago, Russell griffiths said: Can anybody @Onoff @PeterW recommend a glue for fitting. Brown underground drainage pipe to grey solvent weld. Ta very much. This stuff that @Onoff suggested https://plasticsuppliesdirect.co.uk/polypipe-gap-filling-cement-clear-140g.html Is this horizontal or vertical joins and how much pipe do you have showing..?? 1
Russell griffiths Posted June 19, 2020 Author Posted June 19, 2020 Cool, it’s ordered and on its way, I was probably worrying unnecessarily as it will never have water sitting in it, just whooshing past at 100mph. Would probably never leak even if I didn’t glue it at all.
scottishjohn Posted June 19, 2020 Posted June 19, 2020 (edited) using tigerseal will be a good test on if you can remove nitrile glooves in a manner that would keep @Jeremy Harris happy if it was a virus and not black glue get it on your hands or anything its there for a long time if not permanently It would be my go to adhesive for anything virtually stuck car body panels and door skins on windscreens in with it and everything else you can imagine repaired rubber engine mountings +exhaust bobbins if its clean it will stick it if using on glass you need a primer first ,cos glass is so smooth it curesfully at about 3mm per 24hrs --so if its something you need a big thickness on,like a 10mm thick gasket (webber carb mtgs) --then you must give it time to fully cure - Edited June 19, 2020 by scottishjohn 2
