2 minutes ago, pocster said:
Yeah but I want a proper beast of a cane .
Was at school with a lad from your neck of the woods, he liked it so much that he held the school record for beatings.
You probably know him, name is Tim Simpson.
Edited by SteamyTea
Yes ; I remember him well . He was a right (expletive deleted)
His sister was fit though...
We called him Brick.
Not because he was solid, but because he was dense.
There is a story, after I had been told to leave, about him being tied to a bed and pleasured. No idea if it is true or not.
Good Lord the fermenting bucket of nettle based fertiliser don't arf chuck up! The whole garden stinks.
The garlic spray seems to be working.
Egg shells.....I'd like to use them but I've read to wash them or they can attract predators that eat eggs. The last thing I want is a badger traipsing through the beans.
I've washed the egg shells, they're quite slimy inside. Once that's gone it leaves like a membrane you can peel off. I wonder does that need to be removed?
The shells just to deter the slugs and snails.
Also read they add calcium to the ground. Is that necessary given the chalk I have here?
there are about 20,000 varieties available
Looks like a recent variegated one as the flowers are bigger than the original and bi-coloured.
30 minutes ago, Onoff said:
Can anyone advise what that plant is, second from the left in the border
Did I leave my webcam in again.
Really should cover it over to stop the peeping toms and slutty thongs.
Only fair I should show my poor display of beans.
And I had the cheek to give advice. In fairness to self, I have been away a lot at the project.
from the left:
2 inch high from bean pushed into the ground 3 weeks ago.
3 inch high stem, denuded of all leaves and just sprouting some more: planted in pots 2 months ago
ditto but kept some leaves so is growing
A proper bean, a foot high and multi stemmed. it might be enough on its own. Planted in pot 2 months ago and escaped the snails somehow.
as '1',  but growing ok
sweet peas to encourage insects if ever there is a bean flower.
Far left sacrificial salad plant to delay the snails . Behind a couple of garlic plants to confuse the snails.  and a courgette growing nicely at last.
All other green is weeds....carrying no-mow May into not much  weeding  June.
You may notice irrigation pipes. That will work when we are at 'the project' until the batteries or machine fail.
Garlic water also applied....so easy I just broke cloves and chucked them in a bucket of water and they keep emanating into the water.
I know, I probably shouldn't be allowed access to a pen...
As you water the plot it'll charge the earth battery. Enough mV to deter slugs / snails?
I should not be allowed access to the interweb.
ELECTRO ESTIM TENS STEEL BALL TESTICLE STRETCHER ENLARGER WITH 2MM ...
Is it a worry I had an inkling to what that was? I do miss going to the Erotica show.
Can make you drive faster.
Mainly as it is a 5V unit, not 12V.
Well...what to do after a beer and Thai box meal?
Take a Zilt stick and bit of 15mm copper. That's my electrodes sorted. Lad's meter:
IMG_20220629_200509176
Push into dwarf bean pot:
IMG_20220629_195031665
0.8VDC:
IMG_20220629_195312403
Same again with the runner pot, link the two "earth batteries" together and we get 1.6VDC:
Wonder if it's enough of a deterrent if I put two copper strips around the pot? That's for another night/month/year as I work at a.....snails pace!
You can get self adhesive copper foil used for stained glass work. Thinking about the meagre 0.8V, If you used that to charge a capacitor, then repetitively dumped that charge into an inductor, the back emf could be much higher (boost circuit) and give the wildlife something much more serious to deal with.
You draw it, I'll make it! Eventually 😂
7 hours ago, SteamyTea said:
It is so tempting to go out and stick voltage probes into slugs and snails.
I suspect there is a law against it.
BRIAN THE SNAIL UNBOXED *NEW IN* SOLD
Probably, in a roundabout way.
Did you copy the same photo by mistake, both multimeter shots look the same (0.826V)
I was wondering about getting a bit more voltage to begin with, although I think I can get a simple two-transistor oscilator running off of 0.8V.
I always liked astable multi vibrator
Introduction To Astable Multivibrator - YouTube
