Advice please... I have a Calor tank where the feed pipe splits with a T joint. I need one of the two off- feed pipes terminated and was hoping there is a butt fitting that can be used to do this. Ive had had two engineers around this week to give me a quote and they were both uncertain and felt the only option was to heat weld a fitting on the one of the two pipes that needs terminating.
They did mention the exact name of the heat device to do this, though I forget what it’s called. One did say there maybe an easier way of sealing the end without this electrical heating device.
Could anyone advise me if me if there is a cheaper alternative to terminating the pipe and sealing it using the heat weld device as hiring
it would be quite expensive.
adnold9801
1 hour ago, Russell griffiths said:
Can they not take the t out and install a straight joint.
Or I suppose that’s a welded connection as well.
Yes that would mean a welded connection.
Is it going to be buried or visible ..?? You can cap MDPE with copper compression fittings but it’s not advisable underground.
It’s a “fusion weld” fitting that you want ( need ).
If it was me, I’d not fit anything else, especially on higher pressure ( if LPG ? ). The last thing you want is a tank of gas gone to an undetected leak.
No short cuts with gas in my world sorry.
Edited by Nickfromwales
adnold9801
Not sure what size pipe you use, but as a very quick search:
https://www.bes.co.uk/25-mm-end-cap-yellow-mdpe-philmac-16074/?gclid=Cj0KCQjwiYL3BRDVARIsAF9E4Gd8ja3UKQHm0s4h9UrGSCJTPVOQZlx-Ne9dG78OiTNqkiKX1cJLgIcaAnT1EALw_wcB
As @Nickfromwales said - certain installations require different rules.
Also depends on where the join needs to be - pre or post regulators, above or below ground etc as the rules for LPG are different. You need a GSR engineer with a ticket for LPG to work on this.
