Adam2 Posted May 11, 2020 Share Posted May 11, 2020 Hi - am about to press the button on rebar purchase (>40 ton) and thought to check in here first. Would appreciate info on price ranges for rebar inc bending on a loose bar per ton basis which seems to be how it gets priced up. I'm on south coast so accept prices may be bit higher down here that outside Port Talbot steel works - assuming it is still running! cheers Link to comment Share on other sites More sharing options...
Russell griffiths Posted May 11, 2020 Share Posted May 11, 2020 Bare steel barb £650 tonne fabricated cages £750 tonne. 1 Link to comment Share on other sites More sharing options...
Miek Posted May 11, 2020 Share Posted May 11, 2020 1 hour ago, Adam2 said: Hi - am about to press the button on rebar purchase (>40 ton) and thought to check in here first. Would appreciate info on price ranges for rebar inc bending on a loose bar per ton basis which seems to be how it gets priced up. I'm on south coast so accept prices may be bit higher down here that outside Port Talbot steel works - assuming it is still running! cheers Your house has over 40 tons of rebar in it? Holy S#*t ! Link to comment Share on other sites More sharing options...
Adam2 Posted May 12, 2020 Author Share Posted May 12, 2020 Yes hell of a lot, ICF on a hill so walls have a lot in them as well. Link to comment Share on other sites More sharing options...
scottishjohn Posted May 12, 2020 Share Posted May 12, 2020 (edited) 37 minutes ago, Adam2 said: Yes hell of a lot, ICF on a hill so walls have a lot in them as well. how many cubic meters of concrete in the house? Edited May 12, 2020 by scottishjohn Link to comment Share on other sites More sharing options...
Adam2 Posted May 12, 2020 Author Share Posted May 12, 2020 7 minutes ago, scottishjohn said: how many cubic meters of concrete in the house? about 260 Link to comment Share on other sites More sharing options...
Mr Punter Posted May 12, 2020 Share Posted May 12, 2020 Nice and lightweight then at about 700 tonnes! Probably over 1000 when finished. Link to comment Share on other sites More sharing options...
Miek Posted May 12, 2020 Share Posted May 12, 2020 Must be a big'un. Link to comment Share on other sites More sharing options...
Adam2 Posted May 12, 2020 Author Share Posted May 12, 2020 Not crazy large but on a hill with 2 floors having slabs that are 300mm thick with 450 edges, a few thickenings under interior walls and a 1.5m deep toe. That and the walls are 200mm thick concrete. All seems to add up to a lot of concrete and steel - should last a long time ? Link to comment Share on other sites More sharing options...
Mr Punter Posted May 12, 2020 Share Posted May 12, 2020 A bit off topic but how are you organising the construction? That amount of concrete and steel you would normally have a specialist in to do it, or do you have a main contractor? Just wondered why you were shopping around for materials? Link to comment Share on other sites More sharing options...
ToughButterCup Posted May 12, 2020 Share Posted May 12, 2020 @Adam, who's the SE? Is the SE a specialist in designing for you ICF? I ask because when I consulted the specialist SE for my ICF, he halved (or more) the amount of rebar that had been suggested by the original SE. If your ICF is Durisol, I may be able to point you to a specialist SE. (If he is still practising) Link to comment Share on other sites More sharing options...
Adam2 Posted May 12, 2020 Author Share Posted May 12, 2020 34 minutes ago, Mr Punter said: A bit off topic but how are you organising the construction? That amount of concrete and steel you would normally have a specialist in to do it, or do you have a main contractor? Just wondered why you were shopping around for materials? Using a co that specialises in ICF building for all concrete pours, wall build, steel install, concrete plank floor install and waterproof product install - they have priced for the build I'm sorting materials - no matter what people say they never seem to get prices as good as the person that actually has to pay can (if they have the time of course). Ground workers are doing rebar install. Link to comment Share on other sites More sharing options...
Adam2 Posted May 12, 2020 Author Share Posted May 12, 2020 14 minutes ago, AnonymousBosch said: Is the SE a specialist in designing for you ICF? They've done some before - but maybe guilty of being over cautious, hard to tell - it is a challenging site. Thanks for the offer (EPS BTW) but at this stage, even if steel requirement was reduced considerably it would cost time + another SE cost and just image the drama over liability if you get 2 x SE firms involved ? Link to comment Share on other sites More sharing options...
Alan Ambrose Posted August 14, 2024 Share Posted August 14, 2024 Maybe I can ressurect this thread... Anyone have rough costs per ton for budgeting rebar in 2024? This is 12.2T, all simple bar, no mesh, 10 forms, 3 of those just off the shelf bar, H10 to H16. Link to comment Share on other sites More sharing options...
