Lo! The narrow bucket on my digger runneth over!
It has had it's fill with clay, and when it has had it's fill with clay , it doth make a mess of the trench.
I can't be the only person really fed up with clearing out a bucket full of clay - in my case it needs a crow bar to get it out.
What I need is a cheek-less bucket. Is there such a thing?
Or do I get going with a grinder?
I too have been there, "digging out" the narrow bucket. It must be a feature if a narrow bucket, never happened with the 2ft bucket.
I found I didn't use the narrow bucket often, a) because it was a pain to change over (no quick hitch in mine) and b) it tended to clog as you have found.
The MBC lads said the the secret of digging clay is to dip your spade in a bucket of water between each shovel load.  Maybe you need a pond somewhere where you can leave the bucket i for 30 mins at the end of the days or at breaks, and a old sleeper or equiv to knock the bucket out one.
Just a thought.
Don't dig the bucket in and take out big lumps. Scrape it back in 100mm passes so you end up with a pile of loose material up against the blade. When there is enough there lift it and put it wherever is going. It's slower going but you don't have to get the hands dirty using a spade.
When I bought my JCB I asked for a narrow bucket and they asked me where I was going to use it, when I told them they virtually refused to sell me anything less than 400mm as the clay would make it unusable. Yes my 400mm bucket has teeth and like above if you can " rake" it you don't end up with a lump that won't come out. I have some very stout angle iron and was tempted to bodge up a thin spade type adapter bolted to a bucket to scrape a narrow trench for pipes etc.
The other thing I was told to do to stop clay sticking is spray the bucket with diesel before you start but it does not last long before you need to do it again.
Edited by joe90
