gwebstech Posted March 25, 2020 Posted March 25, 2020 Hi Ive been shown guidance from WRAS that says radiator pipes have to be chased into a wall in a new build. But is this what building regs says - ie do the regs supersede what this says? Surely on new builds all big house makers just put plastic behind the dot and dab and they dont chase pipes into the wall? What has happened with you guys new builds? thanks
Russell griffiths Posted March 25, 2020 Posted March 25, 2020 Will you really have any pipes in a wall, surely they will be in the floor void and come up through the floor boards.
nod Posted March 25, 2020 Posted March 25, 2020 Yes on the ground floor of most new builds the radiator pipes come down from the ceiling and are clipped to the face of the block work Then covered by the dot and dab
MJNewton Posted March 26, 2020 Posted March 26, 2020 11 hours ago, nod said: Yes on the ground floor of most new builds the radiator pipes come down from the ceiling and are clipped to the face of the block work Then covered by the dot and dab ...same for upstairs too but up from the floor and out from behind. I really like the method as it means you have hardly any pipework on show at all, nothing to hit with the hoover, and replacing radiators is easy given the flexibility it gives regarding positioning and width. Radiators can also be easily pulled away from the wall to decorate behind without any plumbing and draining down.
ProDave Posted March 26, 2020 Posted March 26, 2020 12 hours ago, nod said: Yes on the ground floor of most new builds the radiator pipes come down from the ceiling and are clipped to the face of the block work Then covered by the dot and dab That's some damned thick dot and dab then. The only D&D house I ever had, there was barely any gap between the block and the plasterboard.
PeterW Posted March 26, 2020 Posted March 26, 2020 Not really. Most is done using 10mm pipe these days so that’s not a very thick bed. 1
nod Posted March 26, 2020 Posted March 26, 2020 43 minutes ago, ProDave said: That's some damned thick dot and dab then. The only D&D house I ever had, there was barely any gap between the block and the plasterboard. As Peter says most are in 10 mil But we do regularly dab over 15 mil We allow 30 mil just to get over the triangular fitting behind the rad
nod Posted March 26, 2020 Posted March 26, 2020 2 hours ago, MJNewton said: ...same for upstairs too but up from the floor and out from behind. I really like the method as it means you have hardly any pipework on show at all, nothing to hit with the hoover, and replacing radiators is easy given the flexibility it gives regarding positioning and width. Radiators can also be easily pulled away from the wall to decorate behind without any plumbing and draining down. While you have only a bit of pipe coming out of the floor you still need about a 18 mil void behind the board Much neater than in the past I can remember the days when copper pipe for run down the finished walls and a cover clipped over on all new builds The ones that had central heating
MJNewton Posted March 26, 2020 Posted March 26, 2020 4 minutes ago, nod said: While you have only a bit of pipe coming out of the floor There's no visible pipes coming out of the floor with this method - the pipes come out of the wall behind the radiator.
nod Posted March 26, 2020 Posted March 26, 2020 56 minutes ago, ProDave said: That's some damned thick dot and dab then. The only D&D house I ever had, there was barely any gap between the block and the plasterboard. I wish Regulations onsite mean we have to encase the gas pipe Usually in the longe or kitchen These are never channeled in and are 22 mil I think 30 mil dabs Often on a wall that run the full length of the property
