1 hour ago, Onoff said:
Are you changing the whole lot or just the head?
looks like he is doing / has done it all, @BotusBuild FYI you can just change the head unit, or even just the motor
Edited by Moonshine
Unfortunately, you can no longer get a replacement actuator for the Switchmaster VA1 mid-position valve ? It all has to be replaced.
surely you can take the head unit off, rather than having to drain down the whole system!
Nope. Tomorrow I will provide some pictures to show why not - basically the head unit (the silver coloured part in the pic) of this will not fit on the valve (the brass part) of the current fitted valve and you cannot buy a replacement head unit for the current fitted valve
Can you buy the replacement motor (assuming that is faulty) for the head unit?
not trying to be a smart arse, just trying to save you the job of having to drain down the system / plumb and wire it in.
23 minutes ago, BotusBuild said:
I've looked at that option too. The SwitchMaster VA1 has been obsolete for years, and now even the internals cannot be found ?
The motor should be a standard geared synchronous motor, as these valve companies don't make their own motors, they buy them in, and pretty much every valve uses a very similar motor (most seem to be similar enough to interchange with those from other makes).  This is a pretty standard universal valve motor: https://www.ebay.co.uk/itm/SYNCHRON-MOTOR-UNIVERSAL-SYNCHRONOUS-MOTORISED-VALVE-TSSYN/392273178813?hash=item5b554db0bd:g:94EAAOSwwJJcqg-c
I've read the Switchmaster has 6 wires whereas a standard say Honeywell has only 5. Found this:
sm=====honeywell
earth===earth
neutral===meutral
yellow===white
white===grey
red, join to orange===orange
Thanks @Onoff I found that one too ?
I have now changed the valve, but now have another problem, more later.
In the meantime some pics, first the old valve and head
and then the new
The new head was never going to fit on the old valve ?
and finally inside the old head to see the motor.
Might take it apart more later on.
But now I have to locate  one of these
Anyone know what that piece of brass is called
FYI - the brass piece fits into the side of the hot water tank near the bottom (the larger thread), and the cold feed comes in the other (22mm compression), and obviously the other bit is the drain tap and you can see the need to replace in the first pic
Edited by BotusBuild
WHY does the drain cock need replacing?  there is not much to go wrong.  If the drain tap won't seal it just needs a new washer.
@ProDave, take a close look at the 3-part "washer" ?. It was part of the piece directly above it. This is a really old style drain trap/cold inlet I think from the early/mid 80's
I am sure I could find a washer to replace that.
2 alternatives.
Take that drain cock to a plumber merchant and see if the "tap" bit from another drain cock will fit into yours. (take a small adjustable spanner)
Or re plumb for a single inlet drain cock and a separate tee.
Made by J E Adams.
Can you give the exact numbers off the side please. Can't quite make them out.
Thanks, just popping into B&Q to see if I can find a BS2879 compliant drain tap to cannibalize (they are controlling numbers in the store)
