gc100 Posted March 11, 2020 Share Posted March 11, 2020 (edited) So I'm about to embark on putting the PIR inbetween the studs, I have a debate happening with the builders about the best way we are going to do this. Basically the option is either cut to size as best as possible and fit in hoping we get it tight everywhere and the cuts are straight (depth wise) as possible. Or we cut 5mm short and foam all around. The advantage of using the foam is we would be guaranteed an air tight fit. However u value / W/mk of foam is about double of PIR so you lose there. Any thoughts? Edited March 11, 2020 by gc100 Link to comment Share on other sites More sharing options...
ArtyWoodworker Posted March 11, 2020 Share Posted March 11, 2020 (edited) Hi, Having a tight fit is very doable by competent and patient builders - foam should be reserved for really hard parts e.g. when a joist is close to an uneven brick wall like in old Victorian houses, for example. I feel like the approach should be to aim for cut-to-fit, and use the foam in the (hopefully) rare occasions you get gaps. Just my opinion based on what I have seen getting done in the past. Edit: I remembered this video I saw recently, showing how getting a tight fit is possible Edited March 11, 2020 by ArtyWoodworker Link to comment Share on other sites More sharing options...
gc100 Posted March 11, 2020 Author Share Posted March 11, 2020 26 minutes ago, ArtyWoodworker said: I feel like the approach should be to aim for cut-to-fit, and use the foam in the (hopefully) rare occasions you get gaps Yes thats my feeling as well, but wanted to get any other opinions on this. Thanks Link to comment Share on other sites More sharing options...
Onoff Posted March 11, 2020 Share Posted March 11, 2020 Cutting square is the key imo. A bfo table saw with dust extraction is good. 2 Link to comment Share on other sites More sharing options...
Russell griffiths Posted March 11, 2020 Share Posted March 11, 2020 If you are worried about u value of foam, then buy better foam i have just started using products by ILLBRUCK, 10 times better than the normal stuff. It’s got a tighter cell so drys to form a far more compact blob. Link to comment Share on other sites More sharing options...
gc100 Posted March 11, 2020 Author Share Posted March 11, 2020 26 minutes ago, Russell griffiths said: If you are worried about u value of foam, then buy better foam i have just started using products by ILLBRUCK, 10 times better than the normal stuff. It’s got a tighter cell so drys to form a far more compact blob. the foams I was looking at are equivalent mW/mk as ILLBRUCK Link to comment Share on other sites More sharing options...
Roundtuit Posted March 11, 2020 Share Posted March 11, 2020 What thickness? I think up to 100mm is relatively easy to cut accurately to get a tight fit (then just foam any 'errors'). I did mine with a hand saw; after the first few cuts, you get pretty good pretty quick. Anything thicker, and I think I'd have struggled keeping the saw square and there's a lot of friction on the sides of the saw. Link to comment Share on other sites More sharing options...
gc100 Posted March 11, 2020 Author Share Posted March 11, 2020 I’ve got 120mm for the stud walls. Link to comment Share on other sites More sharing options...
Vijay Posted March 11, 2020 Share Posted March 11, 2020 If you have loads to do, make a hot wire cutter? Link to comment Share on other sites More sharing options...
Onoff Posted March 11, 2020 Share Posted March 11, 2020 20 minutes ago, Vijay said: If you have loads to do, make a hot wire cutter? The one I made with kanthal/nichrome wire worked well enough / got hot enough to burn through the foil either side as well as the pir. Had issues with it keep breaking though. It's much harder to cut thru than eps. Thin wire offers lower mechanical resistance but obviously less strength. The psu which was just a wall watt crapped out in the end. Link to comment Share on other sites More sharing options...
MikeGrahamT21 Posted March 12, 2020 Share Posted March 12, 2020 (edited) I spotted this in the latest toolstation catalog, looks interesting: https://www.toolstation.com/smart-trade-insulation-blade/p62092 Smooth sided 100mm long blade for a oscillator, not used one, but considering getting one to try for £9 Probably beats what I do at the minute, disposable stanley knife with blade at full stretch, doesn't quite get through 100mm, and can veer off course a bit! Edited March 12, 2020 by MikeGrahamT21 Link to comment Share on other sites More sharing options...
Onoff Posted March 12, 2020 Share Posted March 12, 2020 16 minutes ago, MikeGrahamT21 said: I spotted this in the latest toolstation catalog, looks interesting: https://www.toolstation.com/smart-trade-insulation-blade/p62092 Smooth sided 100mm long blade for a oscillator, not used one, but considering getting one to try for £9 Probably beats what I do at the minute, disposable stanley knife with blade at full stretch, doesn't quite get through 100mm, and can veer off course a bit! I reckon for squareness you might be better with a Bosch or Milwaukee "wave" blade in a jigsaw. Holding a multitool square over 100mm deep cut...good luck! Anything "powered" will also create more dust I imagine. I still like the pink Celotex saw held against a length of square timber. Gives a pretty square cut tbh. Link to comment Share on other sites More sharing options...
Jenni Posted March 12, 2020 Share Posted March 12, 2020 We tried jigsaw blades. The slower you take it the straighter the cut, very clean but they blunt very quickly then stink as they struggle. In the end went back to normal toothed hand saw, fast and straight, sadly very messy. Link to comment Share on other sites More sharing options...
