Your local builders merchants will do you a bill of quantity for around £200
Just hand them your drawings
There are online services (www.estimators-online.com) as well, which i am looking to use, come in a bit cheaper for a house (£180 inc VAT)
200 ish
Its easy to do it yourself
29 minutes ago, Moonshine said:
I would be interested to know other than basing to on the m2 rules of thumb.
A house is very easy to estimate
Only a case of counting up
and m2 also
Id very little over But mist things can be returned to the supplier for a refund
If you get a QS in they often round things up knowing that
On 03/02/2020 at 19:57, Thedreamer said:
What are you wanting the QS to do?
I've done some rough costing myself. But there are still a lot of unknowns- groundwork, roof etc.
Am hoping the QS can give me estimates for Labour and not just materials. Is this something that a QS would do ?
Yes.
The biggest unknown is typically your foundations. I had trial hole dug and was then able to work out how much concrete was going to be required.
I produced a list of the materials and our QS did a review of this for £180 and then wrote to the building society confirming that the build costs were feasible within my budget. Really it was his qualification and PI insurance that I was paying for.
A QS can do quite a lot but it can get expensive if you hire them to do everything. They can...
* Estimate total build cost.
* Check and adjust builders quotes so they are based on same assumptions/place holders otherwise they can't be compared. One of our builders allowed too much for steels and accepted QS figures.
* Value work done to ensure builder is entitled to a stage payment and perhaps what that payment should be.  Ours pointed out we should retain 5% of stage payment until snagging was done.
* Check cost of changes you may want is reasonable, agree amended total price. Possibly argue for you if there is a dissagrement with the builder.
Overall we found our QS better value than the Architect during the construction phase but now I have done a house I know quite a bit more than I did at the outset.
  • 7 months later...
I guess if you then say you are looking to purchase all the materials from them they will do that no problem
