Just had a price for 25mm insulated plasterboard @ £27.00 a sheet
Is there any reason why we can't just fix 25mm Recitcel to our rafters, tape all the joints with foil tape and then screw the plasterboard through the insulation onto the rafters?
Will BC accept that or is there a condensation risk because it's not bonded seamlessly?
There is 100mm Recitcel between the rafters as well.
The way you are proposing looks better to me, you are taping all the joints then covering and going to tape and joint or skim the plasterboard.
I can never understand how they think insulated plasterboard is any good, how do you join all the foil faces together.?
Exactly how I am going to do it.
You do that
The reason why it’s not usually done that way is the ceilings can finish quite Wayney
You will also get a lot of screw pops when the heating goes on
Just checked what I’ve been paying
G tech 22 mil insulated PB
&14.09  2.4x1.2 sheet
That's EPS not Foil faced polyurethane ?
Jewsons wanted £28.00 a sheet for that sort of stuff - GYPROC ThermaLine 38mm
