Polished Concrete Worktops: Snog, Marry , Avoid: and why?
2 minutes ago, Construction Channel said:
Faye's not as available to lift things anymore and I really haven't got time to do "prototypes" at the moment.
??? You think you haven't got time now!
  • Replies 61
  • Views 12.8k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • Construction Channel
    Just waiting for the silicone to go off..... The big pour will commence shortly.    The base ply has been sbr'd as I want it to stick to the mortar. The outside formwork had been silicone re
    Well tip of the day is to buy more cement than you think you need. ? Only just had enough for the big section so the little one will be done another day
  • scottishjohn
    scottishjohn
    I do not know  if it applicable to this use , but but when our workshop was laid we specified one that was good enough for tracked  diggers to move on - after it was laid and still softthere
Posted Images
21 minutes ago, Construction Channel said:
I should also come clean that I didn't film pouring them. One day I will explain why I haven't got the time to be messing about with cameras and editing suits right now. In short the rush to get it livable recently got a lot more poinient
Have you done a "Grand Designs"?
I thought I'd have more time once our life changed 3 months ago, what time I did have is now much less!
Edited by j_s
7 hours ago, Construction Channel said:
My question is how does resin deal with hot pants?
Faye would look good in resin hot pants methinks. She's make you proud(er)
Clear resin?
23 minutes ago, AnonymousBosch said:
Using your post as a starting point , Clive, I found this resource : the training resources of the concrete coutner top institute  (all free )
As has been said it's more of an American thing. At least you should be well versed when you do yours!
A (good?) Pinterest link that really goes into the ingredients for a mix. Mentions fibres, plasticisers etc and an interesting "mineral" additive. I imagine that might give it a "glisten". Of course you can buy it pre mixed. I wonder if ground / crushed glass could be used?
This is the basic recipe:
https://pin.it/5mb7y2gg3le72c
