To adapt the words of  the song "Some girls do, some girls don't ", some days the grease gun lets me, and some days it won't.
Today, it won't. Pump grease that is.
The number of times I have used a grease gun successfully is far outweighed by the slippery-fingered-fulminating-damned-awful-annoyance-ridden efforts at loading and getting any out of the end of the connecting hose.
 'S Friday innit. Off to the gym (to watch a load of stick insects commune with their iPhones) and then the pub.
Sod it.
I too have had problems with grease guns and was recommended a “Wanner grease gun”, bought one on Ebay, second hand for £7, works every time ?
you using grease cartridges or manual fill ?
or is it just not getting on the nipples at  correct angle
SNAP
Edited by scottishjohn
I second this!
4 minutes ago, dpmiller said:
best thing I ever did was get a clip-on coupler.
not handy if you are tight for space
eg slide on right angle one with flexible pipe is  good -- but no doubt there will be some that you need to get at straight on
Sod it.
Does your grease gun have an air bleeder? Air pockets in the packed grease will basically stop it from working.
It won't pump grease?
You know it's full of grease but the handle's all floppy and offers no resistance when you pump?
You need to bleed the gun:
Whilst pumping stick a small screwdriver in to depress the little ball bearing on the lid. This to let the air out.
If that doesn't work:
1) Undo the top of the grease gun by 2,3,4 turns until it's nearly coming off.
2) Pump the handle until grease comes out where the top joins the body.
3) Whilst grease is pi$$ing out keep the pressure on and screw the lid on. Grease should now come out of the end  coupler where it's supposed to.
Save the grease that comes out of the lid in a jam jar etc
Send pics of gym bunnies please!
I'm good at latching on to nipples ; my gun needs a small nozzle to fit into the recessed nipples - that's not the problem.
@Onoff, Thanks for the clear set of instructions. I will have a try on Monday.
This weekend is OFFFFFFFski. Lie in. Breakfast in bed. Gym. Gym swim swim. Sleep sleep. Eat eat. Doze Rugby.
