PeterW Posted March 24, 2017 Posted March 24, 2017 You can buy pharma grade propylene glycol for about £20 for 5 litres. At 20% it's good to -10c so in a normal circuit of 50 litres you could get away with £40 worth.
Jeremy Harris Posted March 24, 2017 Posted March 24, 2017 Corrosion resistance is an issue with just using glycols, so usually additives are needed to prevent corrosion in any system with a mixture of metals. In theory it shouldn't be a significant issue, as most heat pumps use a stainless PHE, and that's fine with copper pipework. The other thing that would make me want to have a look in more detail is whether or not the flexible hoses and rubber seals are OK with just plain glycol.
Alexphd1 Posted March 28, 2017 Posted March 28, 2017 slight off topic but this may be a interest to some people on this topic. they have some other interesting thermal stores/buffer tanks for sale as well. http://www.ebay.co.uk/itm/122413851641?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT PS i have no connection to this company and have personally ruled out the above as i would like a stainless steel thermal store.
DeeJunFan Posted March 30, 2017 Author Posted March 30, 2017 Hi Guys, Quick update. Plumber #1 - Has gone fully dark. Not a word Plumber #2 - has had my plans for 2 weeks and says there is quite a bit of work in getting a proposal done, will need another few days. (I'm guessing that means he hasn't looked at them yet and doesn't want me bothering him for another week or 2) Plumber #3 - Referred by a mate, sent me 1 text and hasn't responded to anything else. Plumber #4 - Even my Da was getting pissed off so rang around hopefully meeting him some night this week (Hopefully) Other than that i'm none the wiser, except to say i'm sure my quote when i eventually get one will reflect the couldn't give 2 shites attitude i've had so far from the local guys. Thanks Damian
Guest Alphonsox Posted March 30, 2017 Posted March 30, 2017 It sounds like you are having exactly the same problem we had - there seems to be a big lack of plumbers in NI at the moment. We eventually got plumber #4 to turn up but I can't say I'm happy with the amount we are having to pay.
Barney12 Posted March 30, 2017 Posted March 30, 2017 4 minutes ago, Alphonsox said: It sounds like you are having exactly the same problem we had - there seems to be a big lack of plumbers in NI at the moment. We eventually got plumber #4 to turn up but I can't say I'm happy with the amount we are having to pay. Same issue in Devon
DeeJunFan Posted March 30, 2017 Author Posted March 30, 2017 @Nickfromwales hows things in your neck of the woods? Dont suppose i could get you on the Ferry?
Nickfromwales Posted March 30, 2017 Posted March 30, 2017 Right now I'm just about to secure work which will take me beyond June . What's your schedule ? PM or give me a buzz, you still got my mobile number ?
Nickfromwales Posted March 30, 2017 Posted March 30, 2017 Would be a good trip though as I've never seen a hot press before ! 2
Calvinmiddle Posted March 30, 2017 Posted March 30, 2017 1 hour ago, Nickfromwales said: Would be a good trip though as I've never seen a hot press before ! Your guys from the mainland don't know what your are missing
Calvinmiddle Posted March 30, 2017 Posted March 30, 2017 1 hour ago, Nickfromwales said: Would be a good trip though as I've never seen a hot press before ! The cupboard where we have all the spare beds clothes and towels etc should be the hot press. But the problem is that we have a combi boiler, so no hot water tank and at the top of the cupboard (it's 3.6m high) is the MVHR and its manifolds, so in actual fact it's the coldest room in the house with the cold air from out side So calling it a hot press just doesn't seem right....
vfrdave Posted March 30, 2017 Posted March 30, 2017 2 hours ago, Nickfromwales said: Right now I'm just about to secure work which will take me beyond June . What's your schedule ? PM or give me a buzz, you still got my mobile number ? If @DeeJunFan delays by about 4 months (ever the optimist I am) you could swing up through co. down and do mine also!!
Barney12 Posted March 30, 2017 Posted March 30, 2017 (edited) 1 hour ago, vfrdave said: If @DeeJunFan delays by about 4 months (ever the optimist I am) you could swing up through co. down and do mine also!! No, No, No. He needs to come to Devon first! I'm closer! And.....my job comes with free 'Live In' accommodation. A nice cosy 1 bed flat above the garage. And.............An outside toilet with hot and cold running water. (There is one inside the flat too ) And..........................An outside "doggy" shower. Thermostatically controlled. Just saying. Edited March 30, 2017 by Barney12
Barney12 Posted March 30, 2017 Posted March 30, 2017 14 minutes ago, Nickfromwales said: Let the bidding commence ???? Just put yourself on eBay. I'd recommend a 99p start 1
DeeJunFan Posted March 30, 2017 Author Posted March 30, 2017 16 minutes ago, Nickfromwales said: Let the bidding commence ???? This could get ugly
Nickfromwales Posted March 30, 2017 Posted March 30, 2017 6 minutes ago, Barney12 said: Just put yourself on eBay. I'd recommend a 99p start Ok folks, looks like @Barney12 is out of the running ✌️?
Jeremy Harris Posted March 30, 2017 Posted March 30, 2017 FWIW, I think the shortage of decent plumbers is pretty widespread. I rang around when we were putting the schedule together and plumbers were the one trade that were fully booked up for months ahead (they were also the most expensive). This was the main reason I ended up doing all the plumbing and heating system installation, and the reason I did things in what was (at that time) a slightly unusual way. It's also the reason the majority of our plumbing is in plastic, as it was easier to DIY, with a lower risk of having a leak in an inaccessible location.
DeeJunFan Posted March 30, 2017 Author Posted March 30, 2017 1 minute ago, JSHarris said: FWIW, I think the shortage of decent plumbers is pretty widespread. I rang around when we were putting the schedule together and plumbers were the one trade that were fully booked up for months ahead (they were also the most expensive). This was the main reason I ended up doing all the plumbing and heating system installation, and the reason I did things in what was (at that time) a slightly unusual way. It's also the reason the majority of our plumbing is in plastic, as it was easier to DIY, with a lower risk of having a leak in an inaccessible location. Are you throwing your name in the hat for a trip to Sunny Northern Ireland? @JSHarris
DeeJunFan Posted March 30, 2017 Author Posted March 30, 2017 and just out of interest what package did you use for your plumbing layout drawings @JSHarris
Jeremy Harris Posted March 30, 2017 Posted March 30, 2017 Sadly I don't have time for another trip to NI in the near future, although my other half would leap at the opportunity to have another holiday there, I'm sure! I used AutoCad to do all the house drawings and just added the main plumbing and heating system layouts as layers on the master drawings, so I could print off plans that focussed on just one system at a time. I did the same with the electrical installation layout, the MVHR ducting and even the kitchen cabinets and the major items of furniture, which made planning where things could fit a fair bit easier. 1
DeeJunFan Posted March 30, 2017 Author Posted March 30, 2017 Thanks for that. I don't think i'll be able to go down the CAD route at this stage. Hopefully there is some sort of basic tool that is freely available. Thanks
DeeJunFan Posted March 30, 2017 Author Posted March 30, 2017 Just a quick question @Nickfromwales in the small buffer, plate heat exchanger plan are you still talking about using the W Plan to deliver higher heat water from the ASHP to the UVC for DHW? Thanks Damian
PeterW Posted March 30, 2017 Posted March 30, 2017 2 hours ago, DeeJunFan said: This could get ugly Anyone bidding over 50p for his good looks may be disappointed anyway....
PeterW Posted March 30, 2017 Posted March 30, 2017 1 hour ago, DeeJunFan said: Just a quick question @Nickfromwales in the small buffer, plate heat exchanger plan are you still talking about using the W Plan to deliver higher heat water from the ASHP to the UVC for DHW? Thanks Damian So this is mine less the PHE which I don't need. Buffer at 0.5Bar/atmospheric pressure. Use a 3 channel timer - one for DHW, one for buffer and one for circ pump and the stat to control the valve to the buffer. W-Plan modified to allow change over of the pipe stats needed to control the ASHP temp (47/35) And last one with power/neutral removed for clarity 1
