albert Posted September 9, 2019 Posted September 9, 2019 I have permission for a holiday cabin 250 from my treatment pant and I can find any details on pipe size , chamber spacing's and fall for that distance of run. (max occupancy 4 persons) I have plenty of fall but i cant find any details in building regs. Any advice appreciated.
ProDave Posted September 9, 2019 Posted September 9, 2019 There is a requirement for inspection chambers at intervals so you don't end up with 10 sets of drain rods trying to rod a 250M run with no access.
Russell griffiths Posted September 9, 2019 Posted September 9, 2019 I have two holiday cabins and they both have their own treatment systems. Is there a reason to go that distance I can see it being a pain. Materials to connect it will be in excess of £800, that’s without digging the trench. You can pick up a small plant for a £1000. Is there a 3m height difference between the cabin and treatment plant. I have just installed 260m of fence and I’m visualising how long your pipe run will be.
ProDave Posted September 9, 2019 Posted September 9, 2019 One I stumbled upon, made for this market is the PortaPura https://portapura.com/ If you do investigate these and get a price for one I would be interested to know. I am not connected in any way with them.
Bitpipe Posted September 9, 2019 Posted September 9, 2019 23 minutes ago, ProDave said: There is a requirement for inspection chambers at intervals so you don't end up with 10 sets of drain rods trying to rod a 250M run with no access. Yep - we have a chamber every 9m or so as a set of rods is 10m and you have to allow for the drop into the chamber etc.. In practice I normally need 11 or 12 rods to do a proper job.
albert Posted September 9, 2019 Author Posted September 9, 2019 I have no water course to outlet into nearby and ground is solid clay hence the long run. what falls do you think work best on long runs as i am aware the solids can be left behind if its too steep.I was thinking 1:60 - 1:80
Mr Punter Posted September 9, 2019 Posted September 9, 2019 7 minutes ago, albert said: i am aware the solids can be left behind if its too steep That is not the case, it was a bit of an old wives tale and never proven. Between 1:20 and 1:60 seems to work well. I assume there is a downhill slope, so I would go with this and have the drain fairly shallow all the way, providing enough cover for whatever is above. I think you can go 45m between inspection chambers and if the drain run is shallow you can use the small ones.
