What is the negative effect of too much mortar plasticiser??
The other week I complimented a building pro on the consistency of his mortar mix. It was not sloppy but still had nice pliable bounce.
As the conversation developed I realized he was using about 80% more plasticiser than recommended on the bottle which got me thinking about why there is a limit.
Is it:
  1. The chemicals in plasticiser are detrimental to the strength of mortar?
  2. Excess plasticiser results in too many bubbles trapped in the mortar and above a certain threshold the percentage of permanently trapped air in the mortar will compromise its strength?
  3. Mortar with an excess of trapped air is susceptible to accelerated weathering?
Edited by epsilonGreedy
It puts to much air into the mix which makes it go like fluff. Once it's hard you end up with voids in the motar so it's not as strong as it should be. With voids then frost can get into it and it will crumble.
I always used this type where you have the small bit at the top to measure it out. Squeeze the main bottle to fill the small bit and drop it into a bucket of water then into the mixer.
https://www.amazon.co.uk/Multicrete-One-Shot-Plasticiser-Concentrated/dp/B07BBJRT2C/ref=mp_s_a_1_1?_encoding=UTF8&qid=1567361968&s=gateway&sr=8-1&srs=5309686031
To get a good motar the secret is just to let it mix and mix and mix. If you just lash water in till it looks right but not properly mixed then it dries out to quick.
We used to be able to tell when we were last drop on the readymix run vs first - mortar that has spent 4 hours on the wagon was much smoother and less watery.
You’ll also see,when people have resorted to using washing up liquid instead of the real deal,pitted mortar deteriorating within a few years. And you know the hoddy was patting himself on the back as the compliments rolled in for his ‘lovely creamy mix.’
  • Haha 1
That optimix is good but still not that clear on amounts. Between 5-10ml per 50kg cement. So that's max 5ml a bag, 2.5ml per mixer full. I squeeze bit into top then just put a tiny dash into bucket of water swish round before mixer.
I understood plasticiser in right amount improves frost resistance as the air voids prevent frost attack like an airated block.
On 01/09/2019 at 20:47, Mr Punter said:
I prefer hydrated lime to plasticiser.
Does it also promote air entrapment in a mixed mortar or just change its consistency without air bubbles?
Lot of wisdom in that advice, I must be more patient.
Anyone care to offer a minimum mixing duration?
No but it does apparently help the mortar heal small cracks over its lifetime.
It will take as long as it will take. Just get all the sand cement and water in quick then walk away and let it mix. Go and stack blocks or clean up just Don't stand and stare into the mixer like your watching TV. It will never mix with you watching it.
I used to think my builder was wasting my electricity running the mixer fir ages with mortar in it but he explained the mix was a lot better after along mix.
What's the min you would let it mix for 10, 20 minutes?
It will depend on the size of the mixer for a start. A small belle mixer that just about fills a barrow will be 5 mins of mixing once it's filled. Then you have a proper site mixer that will fill maybe 5 barrows at least then your up to maybe 10-15 mins. It will all depend on things like how wet the sand is and how quick you are at getting the sand and cement into the mixer. Then it will all come to experience.
Mine is a middle sized electric Belle, a 150 litres I think.
My visible que for a good mix is when the mortar develops a reptilian looking surface as the drum turns which I take to mean a decent amount of air churned into the mix.
