8 minutes ago, pocster said:
 No advice from uncle Nick ? ?
Not much you can say about those, other than put up and shut up or yank them off and change direction ( tile )?
It would drive me nuts, but once it’s on you’ll just adjust and move on with your life. I have stuff in my bathroom that I did a less-than-perfect way, but I did do it over Xmas, and I was pissed most of the time I was tiling.
But I’m sober Uncle Nick !
Tbh Mummy says your best work is when you’re pissed . Back to Texas chainsaw then I guess - some lite relief ...
All work and no play ;)  go watch a film :)
2 hours ago, pocster said:
B*llocks !
You know that if you hadn’t done that, one of us would have come there and done it for you.
See, a night off, and now some clarity.
Buy some new tiles and make peace with your inner grouting line self.
And breathe.......
And breathe.......
F rocking protagonistic vandals !
I hope all your showers piss water through your ceiling tonight !
Edited by pocster
Not going to happen. My pissed tiling is better than your sober ones ✌️??
  • Sad 1
Doing ok today .
Don’t like the gap between tile and ceiling . Sometimes just on the width of the tile ( 30cm ) the ceiling can be a good 5mm out - bloody plasterer ! . Assume there’s no shame in some simple white beading along the top to hide all this ...
On 30/10/2020 at 11:54, pocster said:
Feel almost like a pro today !
Those non-grout grout lines look loads better than before. ?
That looks a fair bit neater than the first one you did.  Less adhesive in the grout gap.  Can you promise not to use piss yellow grout this time?
It that a very big l-shape to the left of the mirror or did you cheat?
Lol ! Grey grout already here !
How dare you sir ! How dare you suggest a cheat ! Not on my watch !!!
40 minutes ago, pocster said:
Hope there’s more of a tip than last time
"It's not cheating if only the tip goes in, any more than that is cheating".
  • Haha 2
More and more ....
Notice that though my wall was spirit level straight it is a bit out . So to keep tiles flat I simply beef up the adhesive behind them . Was worried about following a bendy wall ( max deviation about 5mm ) . , so don’t ?
Struggling today !
First a snapped tile . ??
These recesses are a real pain !
I’ve done the tile cuts around them rough - so either spend hours dremelling them straight or much easier would be to find tile profile with a lip - so it ‘over hangs’ the tile edges - would make life much simpler !!
19 minutes ago, pocster said:
Struggling today !
FFS, the poshest tile cutter money can buy....are you not marking those tiles and cutting free hand to a marked line?
Thank you, I feel so much better about my bathroom now.
Some of those cuts are dogs . So getting everything to line up just not going to happen . Also the recess boxes appear not to be as accurate as perhaps I would hope . Hence why a tile bead profile that covers the edges solves all the problems . This one in the ensuite took ages to get right with a dremel !!!
