ToughButterCup Posted July 18, 2019 Posted July 18, 2019 Morning all. I'm looking for standard PB water pipe: 10mm and 15mm. And I want Hep2O. Straight and coiled. You can't read this forum and disregard all the well-qualified advice. Yes, little bits of copper just in case @PeterW, @Onoff or @Nickfromwales turn up and look in the cupboards. Maybe my research hasn't been wide enough. Or careful enough. But I can't help but think that there's some confusion between barrier and standard Hep2O. Why, for example, does Screwfix only supply Barrier pipe (not available in the catalogue). Same with Toolstation Standard Pipe isn't listed. Why for example do local BMs appear to stock Barrier only? I am beginning to suspect that, yet again, local isn't best. Any suggestions for online suppliers? @Pete, @Triassic, @nod did you buy yours locally?
PeterW Posted July 18, 2019 Posted July 18, 2019 Always use JTM Plumbing for bulk online orders, and Screwfix for bits. https://www.jtmplumbing.co.uk/ Is this DHW etc..?? Anything non heating related you can use non barrier. Oh, and when running it through walls, buy some lengths of 21.5mm overflow pipe and drill 22mm holes - sleeve the pipe through with this. Don't forget some decent cutters ... 1 1
Nickfromwales Posted July 18, 2019 Posted July 18, 2019 JTM have good prices so +1. I still use my local merchant wherever possible as I like to support smaller businesses whenever it isn't daft to do so. I just carry barrier, so I'm not constantly double-checking which type of pipe to fit ( or then fitting the wrong one without realising ), and also less waste / stock to carry.
MrMagic Posted July 18, 2019 Posted July 18, 2019 Inserts... buy a boat load of inserts! The packet always runs out just when you need them... 2
ToughButterCup Posted July 18, 2019 Author Posted July 18, 2019 55 minutes ago, PeterW said: (...) Don't forget some decent cutters ... Code for German? Make (Hersteller)?
Pete Posted July 18, 2019 Posted July 18, 2019 2 hours ago, AnonymousBosch said: Morning all. I'm looking for standard PB water pipe: 10mm and 15mm. And I want Hep2O. Straight and coiled. You can't read this forum and disregard all the well-qualified advice. Yes, little bits of copper just in case @PeterW, @Onoff or @Nickfromwales turn up and look in the cupboards. Maybe my research hasn't been wide enough. Or careful enough. But I can't help but think that there's some confusion between barrier and standard Hep2O. Why, for example, does Screwfix only supply Barrier pipe (not available in the catalogue). Same with Toolstation Standard Pipe isn't listed. Why for example do local BMs appear to stock Barrier only? I am beginning to suspect that, yet again, local isn't best. Any suggestions for online suppliers? @Pete, @Triassic, @nod did you buy yours locally? Ebay
Triassic Posted July 18, 2019 Posted July 18, 2019 The barrier is there to stop oxygen permeation through the pipe, which in turn can cause corrosion of metal within the system.
