Toppers Posted June 27, 2019 Author Posted June 27, 2019 I think I'm going to stick with what I've started which is the pipework clipping directly to the top of the celotex 25mm below joist top.
Toppers Posted July 5, 2019 Author Posted July 5, 2019 On 27/06/2019 at 13:44, Toppers said: I was going for this method: I was talking to a heating engineer and he didn't rate the method above as being effective enough, has anyone any experience of installing/using this?
ProDave Posted July 5, 2019 Posted July 5, 2019 4 minutes ago, PeterW said: Looks similar to what @ProDave has done If you mean using a biscuit mix as the heat spreader, yes that is exactly what I have done, only mine was above the joists and battens on top of the joists (with notches where needed for pipes to pass through) My pipes are at 200mm centres with the biscuit mix and working very well. Engineered oak floorboards over the top. But the house is well insulated so it doesn't need much heat anyway, but we did use the same system in the previous house with less insulation and it worked there as well.
Toppers Posted July 5, 2019 Author Posted July 5, 2019 5 minutes ago, ProDave said: If you mean using a biscuit mix as the heat spreader, yes that is exactly what I have done, only mine was above the joists and battens on top of the joists (with notches where needed for pipes to pass through) My pipes are at 200mm centres with the biscuit mix and working very well. Engineered oak floorboards over the top. But the house is well insulated so it doesn't need much heat anyway, but we did use the same system in the previous house with less insulation and it worked there as well. So to clarify on top of the biscuit mix do you have chipboard or is the oak straight to the joists? My construction will be biscuit mix, 18mm caber board, tile backer board, tiles.
ProDave Posted July 5, 2019 Posted July 5, 2019 1 minute ago, Toppers said: So to clarify on top of the biscuit mix do you have chipboard or is the oak straight to the joists? My construction will be biscuit mix, 18mm caber board, tile backer board, tiles. 20mm engineered oak flooring directly on the battens. the gap between the battens filled with biscuit mix.
Toppers Posted July 5, 2019 Author Posted July 5, 2019 8 minutes ago, ProDave said: 20mm engineered oak flooring directly on the battens. the gap between the battens filled with biscuit mix. Do you think the heat will generate through the chipboard and tiles ok?
PeterW Posted July 5, 2019 Posted July 5, 2019 14 minutes ago, Toppers said: Do you think the heat will generate through the chipboard and tiles ok? Yes it’s fine. With this build up I would just be going with a hardiebacker type board straight on the joists. 15mm stuff would be more than enough assuming your putting a good 50mm pug around the pipes.
Toppers Posted July 5, 2019 Author Posted July 5, 2019 50 minutes ago, PeterW said: Yes it’s fine. With this build up I would just be going with a hardiebacker type board straight on the joists. 15mm stuff would be more than enough assuming your putting a good 50mm pug around the pipes. Had a quick look and they only seem to do 12mm in hardiebacker I've already set the joists to accept 18mm chipboard (I'm matching up to an existing floor) so this could be a problem.
Toppers Posted July 5, 2019 Author Posted July 5, 2019 18 minutes ago, PeterW said: 6mm ply then 12mm Hardiebacker would work then. Yes that could work I'm not that familiar with hardiebacker is it a fairly strong material?
PeterW Posted July 5, 2019 Posted July 5, 2019 It’s a cement board that is hard as nails. There are others, you can tile straight over it.
Carrerahill Posted July 11, 2019 Posted July 11, 2019 On 27/06/2019 at 13:33, ProDave said: Okay as someone who did this (a little different) I wanted to be clear that you are putting battens along the top of the joists to support the floor, with the biscuot mix filling in between as a heat spreader, but not supporting the floor. This solves the problem of how the UFH pipes cross the joists, you leave a small gap in the battons. and it means you don't need much support for the celotex. I take it the joists have been specified taking into account the extra dead load they have to support. Did you just batten out on top of the joists and then screed or did you cover the joists first with ply or something then pipes with batten supports directly over joist positions and screed infill?
ProDave Posted July 11, 2019 Posted July 11, 2019 1 hour ago, Carrerahill said: Did you just batten out on top of the joists and then screed or did you cover the joists first with ply or something then pipes with batten supports directly over joist positions and screed infill? OSB over the joists, battens on top following the joists, UFH in between filled with biscuit mix 1
LA3222 Posted July 12, 2019 Posted July 12, 2019 13 hours ago, ProDave said: OSB over the joists, battens on top following the joists, UFH in between filled with biscuit mix This is how I intend to do my first floor UFH. 18mm OSB on the pozi joists, batten out 50mm for the pug and pipes then 18mm caberdeck on top. Final floor finishes on top of that.
Carrerahill Posted July 12, 2019 Posted July 12, 2019 (edited) 14 hours ago, ProDave said: OSB over the joists, battens on top following the joists, UFH in between filled with biscuit mix Thanks, 19mm, 25mm batten? OSB over joist thickness? I think I shall go this route Dave, so I need to workout my floor makeup - my joists are sitting in, loosely, to give me my temp working floor - with 11mm OSB on top for now - at that I am am about 10mm lower than the floor level of the rest of the house - minus any floor covering - so I will need to reduce the plate the joists currently sit on by 19/25mm so that my FFL works out. Edited July 12, 2019 by Carrerahill
Carrerahill Posted July 31, 2019 Posted July 31, 2019 On 11/07/2019 at 19:01, ProDave said: OSB over the joists, battens on top following the joists, UFH in between filled with biscuit mix What clips did you use to attach UFH pipe to the OSB? The ones in the kit I am about to order look like they are designed to be pushed into PIR.
ProDave Posted July 31, 2019 Posted July 31, 2019 39 minutes ago, Carrerahill said: What clips did you use to attach UFH pipe to the OSB? The ones in the kit I am about to order look like they are designed to be pushed into PIR. I bought some P clips from CPC, and a box of short but fat wood screws that would screw the P clips down to the OSB without the heads bursting through the P clip. Very cheap and worked well. 1
Bitpipe Posted July 31, 2019 Posted July 31, 2019 On 27/06/2019 at 13:44, ProDave said: Your proposed idea gives you one MAJOR problem. How will the UFH pipes cross over a joist, which they will to at one end, crossing over every joist. You cannot notch a posi joist. I did it this way on a very small section of floor under the bathroom, and I threaded the pipe between the top and bottom chord at one end, but it was VERY hard work with only a short run of pipe to keep threading through. If you are going to be doing anything like a normal sized room, you could be having many tens of metres of UFH pipe and threading it through again and again is going to be somewhere between extremely hard, and impossible. Battens along the top with a small gap at one end for the pipes to pass solve all this. Set the celotex level with the top of the joists. We had this issue on our GF - used spreader plates sitting on top of the Pozis with 22mm ODB deck. After some head scratching, solution was to take a strip out of the OSB where the pipe needed to hop over the pozi - it is impossible to thread the UFH under the chord as you'd need to pull through the entire run of pipe each time so kinks & other damage would be inevitable. Worked for us as we were covering the OSB with two layers of ply (12mm and 9mm) and then resin on top.
Carrerahill Posted July 31, 2019 Posted July 31, 2019 (edited) Thanks. Next question. I know Dave, you used wooden flooring over yours, I would like tile in the kitchen, but may use a laminate product - if I go tile - how do you make up the floor above without the tile grout cracking and tiles lifting from expansion cycles? I am setting the joist height this weekend (i.e. building the dwarf walls etc.) so I need to bottom out my full makeup or I may end up higher than the rest of the house. Edited July 31, 2019 by Carrerahill
