They will issue a lot of resin too. If your stove has smoke burning flumes then most should be burnt up....if not then it will coat the flue and dirty the roof.
How does your garden grow?
saveasteading replied to recoveringbuilder's topic in Landscaping, Decking & Patios
Clarify please. Seeds just planted? what for compost.? -
Warm Roof Overhang & Fascia Detail For Rendered Wall
saveasteading replied to HHHAMSTA's topic in Flat Roofs
My dad could saw through 6 x 6 oak with either hand, from above or below. It looked effortless which may be the point. -
Build over agreement- existing drainage info
saveasteading replied to Richard Marin's topic in Waste & Sewerage
Indeed this reminds me of a main contractor client who pinched an idea from me, trustingly offered pre_tender. There were swings and roundabouts and so they way underpriced. To their credit their director admitted this and the naughty surveyor was soon gone. You will need professional input, we only offer advice and ideas -
I always assume that the rubber won't work and the wind will blow water under. Therefore I continue the slope fior about 200mm past the door. Then the wind struggles and the water just runs back. I tried to patent this but was told it was too obvious.
On the phone or email tomorrow Tell us how you get on. It would be great to know ASAP about the depth If you are friendly with the neighbour. All you have to do is lift off the manhole cover. It might need special keys from toolstation screwfix or wickes. You will see the drainage channel Put a piece of timber across the hole, resting on the manhole frame. Then measure down to the bottom of the channel. This is known as the invert. take pictures. Then tell us what you find and see. What is the manhole made of? Brick, concrete or plastic? Put the cover back on. With that info we can look further ahead. -
I'd say don't bother. Relax for now and see how it turns out. It doesn't turn out shiny like diamond, just abraded by fancy carborundum, and at great expense.
- 14 comments
- the windy roost
- icf
(and 3 more)
So we now know that this is a 150mm diameter combined drain (ie carrying both rainwater and sewage. And that in nextdoor's garden there should be a manhole cover The water company will have this same drawing, with additional info. Ask them for the full drawing, and btw isn't this sufficient to deal with their own question? Anyway you need the full drawing from them. It will have a table with all the drain and manhole cover levels -
extreme temps to re coat after 3 hours, so I did that at around 21.00 I know the stuff but only ever used it indoors. There is a small risk of excessive evaporation out of the slab edges, esp once the shutters are off and if it is breezy. You could easily wet them if so inclined.
- 14 comments
- the windy roost
- icf
(and 3 more)
Firstly look at your deeds, just in case Annoyingly the next dource is the drainage company, so it seems they don't know. Maybe phone and ask. Next, you draw it yourself you may need your builder to lift manhole covers, especially if in the road. Come back for more info of what you will have to look for and report. Do you at least have info on the drain you want to build over? Posting it on here would allow more help. -
A like is insufficient. Brilliant rock snd thanks gog thd info. Don't eorrh zbout the visible fibres they zcuff off under the tiniest ftiction eg foot traffic. Also the concrete finish looks fine. Try not to look at it and the appearance will improve. Some of the messier areas are surface laitence or froth marks from the coating. Does your varnish completely seal the surface or do you need to wet it again? The shrinkage cracks will be starting about now. Do not panic if there are any rogue ones. A minor thought.....the shower and bath drains could go to local soakaways as Grey water, if that helps in any way. Brilliant work though. Well done indeed.
- 14 comments
- the windy roost
- icf
(and 3 more)
I mix it at about that but I can't see it can do much harm, especially if from a good mix of plants. It gives me some satisfaction to put nasty weeds through this useful end. -
How will flood have affected under my floor?
saveasteading replied to Pollyanna's topic in Floor Structures
So it has just never dried out. Fresh air should do that esp in summer. Open windows. remove a floor board or more. -
Mould dies when the dampness is removed. You still have to find the source of the water. -
Looks good to me. Diy fertiliser has to be best. When it stinks so badly it must be effective. For new readers. Collect weeds especially the succulent green ones like dandelions and nettles. Place in bucket and compress. Fill with water and weight down with anything 2 weeks or so later it will be brown and stinky. Decant into a large plastic bottle, or lots of small ones. Use slightly diluted. -
Preparing Floor Removing paint off concrete
saveasteading replied to revelation's topic in General Flooring
Carbonrundum stone. Presumably it's negligible thickness so it doesn't really need tp cone off. However an addition to scourers is first to use a scouring block......a carborundum or just a brick its an official way of knocking cement lumps off concrete being less abrasive than a carborundum stone. The latter will do the best job if if has to be clean. Nb the brick sheds dust so have a brush handy. -
Suggestions for garage roof material. DIY.
saveasteading replied to saveasteading's topic in Roofing, Tiling & Slating
Grp sheetstuck down then a painted coating? -
Good info. To me this is better than the average site in the se where we've been building on tips for decades. Founds to 2.2m seems conservative, with firm ground at 1m. This has really got my interest xnd I keep thinking "what would I do". Much as I love innovation I think oois would stick with traditional here. The 50 years life often surprises people. When deciding what load needs to apply, there is a conscious input to make on this because of the increasing possibility of high wind and snow loads. The Romans overdesigned.
Yes. Not just in case though. Essential I'd say.
Hello from an aspiring self-builder
saveasteading replied to selfbuilder91's topic in Introduce Yourself
Welcome. I've been in construction for 50 years, but learn a lot on here, and there are plenty of practical experts. Join in too where you can. -
No seal at stove pipe to logburner collar
saveasteading replied to Hunter7's topic in Stoves, Fires & Fireplaces
Small claims court will appreciate your trying to use the trade body to resolve the issue -
What is the maintenance required
saveasteading replied to CalvinHobbes's topic in Roofing, Tiling & Slating
Well.....the coating is equally vulnerable if damaged. No screws, so the screws won't leak, but they shouldn't anyway. Buy the best screws and the epdm washer twists itself down with the screw and completely seals the hole and protects the metal. I reckon my business did 250,000m2 of roof. = 2.5M screws. Any issues were of untightened or missing screws and apparent at first heavy rainfall....moral use an experienced cladder offering a year's maintenance. What slope?
