vala
Everything posted by vala
  1. Thought on losing screed to save on how much to dig up. Current potential build up is as per @JohnMo's reply above. Then with tiles on top.
  2. Hi, the pipes in trays, and screeded over was mentioned to me by the tiler. But I would much rather lose the screed if possible, maybe have to have a latex poured in case if the concrete isn't flat enough for the tiler but I'll let them deal with that. I just wasn't aware whether the different options would suit different house make ups? But yes, if the above is suited for the house then I'd rather go with that.
  3. So looks like polished concrete may off be table now, so the back up option is to go tiles. Spoke to my tiler who noted that if the UFH pipes were installed above the slab, on clips or in trays, they could lay a 60-65mm screed and then tile on this (with the use of a decoupling mat). However also seen I could install the pipes on the insulation, have the slab poured, then look to have the tiling done. Is there any benefit to either option and would one be suited more depending on house make up? For reference its a 70's built semi detached with ~65mm cavities which will be filled with beads. Aside from the 200mm PIR which will be under the ground slab, first floor has UFH in a pug mix, and loft has ~250-300mm insulation.
  4. We're looking for someone to pour the slab and polish it so it's then the finished floor. looking at terms for this the finish we like is 'cream'. From what I have read this is where they don't remove any materials but more so polish up the top layer.
  5. Does anyone here have any recommendations for contractors to complete a polished concrete floor? I'm based in Milton Keynes. Thanks
  6. yeah, it'll be the same builder so sure he'll some idea when he does the first part. Tiny, 9sqm. Literally just for a downstairs loo.
  7. no idea on this yet. first thing is to get the shell of the extension done. Hopefully he fits us in this year, then once the weather warms up next year we'll have the slab in the house sorted.
  8. builder mentioned it when we were discussing floor build up due to the UFH. not set on using it, just looking at other option and then will discuss with him. if we can lose the mesh then great, and can then just clip the pipe work to the PIR. slab is only circa 55sqm.
  9. Should be starting a little extension which will form part of the UFH on the ground floor. Plan is to have the existing slab taken up, dug down, insulation and a new slab with UFH within. Plan is for the finished floor to be polished concrete but just the 'cream' standard. I need to discuss with the builder but from info I've read on here and other sources, I thinking of a baseline to be: hardcore compacted, sand binding, 200mm PIR, UFH on mesh, 100mm concrete slab. Would this be ok? Or should I be looking into other thicknesses of concrete, different amount of insulation, different insulation, UFH clipped onto PIR instead of tied to mesh, etc etc? Any help would be much appreciated.
  10. vala
    CWI options
    Had the existing CWI surveyed after being in touch with CIGA. Did suffer a bit of mould in the corner of a room and the house didn't ever get to its targeted temp. Assumption was that as the heat was rising is was leaking quicker. The survey highlighted a few areas where the mineral wool wasn't in place and also when I have changed the windows on the first floor the cavities were quite sparse. And yes apologies, I meant R values. I'm not as clued up with the impact of R values so although it may appear to be a minor increase it may actually be quite something, again though I have little knowledge on whether this is true. I spoke to Polypearl regarding the difference and they didn't give a reason or advise on what product due to the make up of the house. And the 2 installers they recommended, one only installs Plus, the other only Platinum.
  11. vala
    CWI options
    Hi all. Had some quotes for CWI. Polypearl plus is £2700, Polypearl platinum is £4300. Both quotes include extraction of the old mineral wall. Can anyone advise if the platinum is worth the extra £1600? The difference between the 2 u value's is 0.005.
  12. Had an inspector out to check if we had CWI and if so what's state its in to know whether to change it or not. From his report back, he notes our cavities are in the region of 70mm, yet he did mention on the inspection day some areas were down closer to 55-60mm. The type we currently have is Insta fibre/white wool. He notes that there are a few voids and I've seen first hand there are gaps/voids when I installed the first floor windows. So think we'll need to have the lot replaced. Have spoken to Polypearl who recommended an installer who has offered Polypearl Plus, didn't really give any real reason as to why not go with Platinum even though he does offer it. Also spoke to Polypearl who have said there Platinum offers 25-30% improvement over Plus. He didn't give any details as to what effects the extra performance, I assume bigger cavities would help. With my home having between 55-70mm, would I really benefit?
  13. Apologies for the delay I’m replying. No still not sorted. Have resorted to just using the manual actuators for now. Tbh when we had that cold snap in December it highlighted the CWI that apparently has been fitted (says so on the last 2 EPC reports) is not very good. This has resorted in one room in particular that struggles to get up to temp when the cold weather is present (1-2° and colder temps). So looking into getting that sorted along with the ground floor works which will include wet UFH throughout. Then we’ll get back onto trying to use the ABA’s.
  14. We used Wilson ThermalStream. It’s 10mm thick.
  15. I recently spoke to PolyPearl who put me in touch with an installer for CWI. The installer noted that there may be a grant being available in the near future for this? Has anyone else heard of this? I done a google and the only grants I could find were relating to those being available a while ago.
  16. No problem. I'll leave it then pump set to 1 then. Opened up to 2l/min. This looks like the maximum for this pump speed. Any higher and I'll need to go to speed 2. Yes just the 1 room running at the moment, and door is kept closed. Floor covering is indeed carpets (tog for carpet and underlay comes to 2), in the bedrooms and landing. Tiled in the bathroom.
  17. Thanks for the repliy. Have got it currently set to 45° flow and 1.5 l/min. In the last 4hrs we’re still in the low 18’s. Would upping to pump speed 2 be a sensible option? At present although I’m not focusing on it, the delta T is circa 4-5°.
  18. Hi @JohnMo, thanks for the reply. Would you suggest upping the flow rate to what it should be based on loop length or just going in 0.5 l/min increments? Insulation under the floor is 100mm PIR between the joists.
  19. Just bringing this thread back up as we're now back to using the UFH and still struggle to get this 7° delta T. After much purging I'm confident now that all air is expelled. And following @Nickfromwales suggestion of opening up the manifold pump I did indeed find a tiny piece of metal. Wunda sent me out some manual actuators and have suggested to use these to achieve the correct delta T before sending me out new Salus ABA's. I'm going to set 1 loop at a time and the system was cold, as had been off for a few days, prior to restarting. The loop length I'm working on is 80m and flow rate should be 2 l/min, however I'm currently at 0.6 l/min and achieving delta T of 7°. Strange this is flow temp was set at 45°, and has been constant since I started this yesterday morning however now it's suddenly creeping up to 47°. Will see if that settles in the next hour or so. Temp of the room in question is gaining heat but extremely slowly, up from 14.5° to 18.5° since 1300hrs yesterday. Am I wrong in expecting the temp in the room to be up higher by now?
  20. *Update* So pump has been silent since the 11th however I have noticed the flow rates have been between 0 and 1 (have checked with the loop lengths installed and 1 zone in particular should have a flow rate of 2 l/min). Spoke to Wunda about this and they are now suggesting trying out the standard actuators so have sent some out in the post (may arrive next week). I also spoke to Salus today who noted these actuators are very much fit and forget and have suggested upping the pump speed to 2 (was previously set at 1 due to only 4 ports on the manifold). Once I changed the speed back again came a whole host of noises (sounded much like air) and the green and red flashing light on the pump. One reasoning for this according to the Wilo manual is air in the system. So I entered the venting mode, its done its thing and back to being silent on speed 2. But I did notice some movement at the flow meters during this venting mode and in particular little movement from one of the meters as shown in the video below. The zone for that flow meter also has been the one with little to no flow through it, yet is also the largest of all the loops. Plan is now over the weekend at some point to get a hose pipe on it and see if there's any air in the whole system again. But whilst I'm doing work to the system am thinking probably best to open up the pump and check for debris as per @Nickfromwales suggestion. Can anyone confirm its just the 4 bolts on the front to be undone to view the impeller?
  21. So situation first thing this morning with 1 zone calling for heat......silence! 🤯 Will get someone to monitor it during the course of the day, and then I'll do the same over the weekend. Assume if I remove the 4 bolts on the front of the housing that will give me access to the impeller to check for any debris lodged in there?
  22. Thanks all for the replies. Got back home this evening, UFH is on and pump is back to being silent🤯🤯🤯 I'll check it again tomorrow morning to see if this may just be happening in the morning. Assume this either now means it's not a damaged pump, or the piece which was causing problems has been forced around a loop???
  23. @SteamyTea the system was making this noise late last week/over the weekend. So on Monday the system was bled using a hose through the fill valve. No bits of pump came out during this process (I had the hose on the return go into the bath). Wunda have messaged back and said the green light at the top denotes the system is in air purge mode but I don't think that's correct. I believe that just tells you the pump is running. The air venting mode it has is indicated by a series of flashing light on the pump setting and pump speed lights.
  24. @ProDave @PeterW thanks for your replies. Pump along with the whole system was first commissioned around Jan/Feb this year.
  25. Up until a few days ago my UFH system has been working as intended and silent. Then suddenly I started to notice a lot of noise coming from it, sounds more like at the pump end. Spoke to Wunda and they expected this noise to be air related so I set about a couple of days ago and bled the system. A little bit of air came out, and upon restarting the pump and system is back to working, as far as I'm aware, correctly and silently. Then this morning it's back to being noisy, I've attached a video in case anyone can offer any suggestions. https://vimeo.com/769310848
