BMcN
Everything posted by BMcN
Cylinder stat, two immersion heaters and iBoost
BMcN replied to BMcN's topic in Boilers & Hot Water Tanks
As shown here, the ASHP isnt connected to immersion and is using the cylinder stat. So keep this way and let the iBoost do both immersions? (and a timed boost for bug killing duties). -
I did read that in the manual, use the upper as HRT1 and lower as HRT2 and yes I think it was 15min. The manual does show the ASHP going through the separate stat, I have attached the wiring config I am going for (not including the iBoost). The supplied stat looks pretty generic like this. So you would have the ASHP to upper, setting the limit on the immersion itself (around 50 degrees?). iBoost to the lower stat, setting the limit on the immersion (but to say 70degrees?). Then have the stat wired as separate safety device to stop all DHW heating? -
Just started wiring in my ASHP and cylinder. The ASHP came with a boost kit for the immersion but I would like to do away with that and use my iBoost. Now the tank has a middle and a lower immersion and has a stat placed in the middle of these. The stat has a control and a limit set of contacts. My question is what is the best way to wire this? Obviously the ASHP uses the two stat settings in series. My thinking was to use the upper limit through a relay for the iboost on the lower immersion? Any clarification would be good. Thanks
Thanks, did you go for the cut an X out of opening and patch in corners or did you cut a section approx the size of the reveal?
Yeah that isnt cheap stuff! I was lightly scoring the backing paper and taking some off so I could put it on split. I have had another idea, how about if I get some 150mm wide tape and don't bother extending the VCL paper into the reveals at all, I just tape the whole thing?
Had my system delivered from BPC yesterday. Cheapest by a decent margin.
Evening, started doing the VCL and I am looking for some tips on the best way to do the windows. Method one I tried was to cut a piece the same size as each reveal, then tape it to the frame, then cut the wall VCL to the opening size and join the two with tape. Method two was to cut corners at 45degrees and flap in, then try and tape to the window frame. This is pretty tricky with the tape. Method three that I was thinking to try is to first tape the window frame to the PIR insulation on the reveals, then I can be less precise with cutting the VCL at 45 and tape it to the first tape. VCL is Protect Barriair and tape it Tescon Vana.
Forget it, as long as you get what you need for the forum...
As @Declan52 describes, timber midway down the studs to stop them twisting like this. PIR will hopefully do the same job but not normal not to have some.
No midheight dwangs?
There is also this option from Manthorpe however it isnt the sleekest design.
Looking for suggestions for a loft hatch. Ideally want something quite airtight with a half decent level of insulation. Been looking at the airtight Jupiter Blue range which seem to fit the bill but they are tiny. Saw previous suggestions for the Keylite all in one solution but it doesnt seem that well insulated nor airtight. Anyone come up with any better solutions that would allow a larger opening? Happy to have separate ladder set.
I'd leave it. Even if you just levelled with sand and no cement once the boards are on top it will be fine.
That will be a layer or laitance, caused by excess water or over floating normally. No I wouldnt bother, as long as its roughly flat so the boards done rock around. On my sub floor it was quite uneven so before laying the insulation I put down between 5-40mm of a sand cement screed so I had the correct depth on top for my flowing screed. Far cheaper than maybe for 2 or 3 extra cubic meters of screed.
Mix up some sand and cement at 8:1 and a splash of water so it clumps together and roughly level.
Evening, quick one - I had some 150mm PIR insulation delivered today and it looks like it has been outside for a while. There is water inside the polythene and some blackness. Should it be replaced or safe to use?
Thanks, so general consensus would be stick with Barriair unless I could strap over the joints on the polythene maybe.
Yeah I had a test with it, no way I'm trusting that alone to seal. Would probably still go Butyl and then a top tape on the lap. Thanks Jeremy, I'll have a think. I could probably make the joints on polythene under the service batten strapping at top and bottom.
I'm looking for some advice on what VCL to use. I picked up some Protect Barriair stuff second hand, although I would probably need more to do the whole house. My question is, in terms or performance, is something like Barriair any better than say a 200mu polythene like THIS from Baufol or maybe a 125mu like THIS from Novia? I ask because the Barriair is 1.5m, so it will require a joint on every wall (2.4m and 1.8m high). This will cost a lot more in tapes, increase wastage and give many more potential leak points. The polythene can be ordered on 2.7 or 3m widths.
I managed to find a manual online saying 41mm for Parkside one and 55mm for ds50. I might just have to go for 55mm screws and hope the senco is powerful enough
Just a quick one, I am at home so I can't check for myself. I have a Parkside mains collated gun like this https://www.ninefdshop.com/index.php?main_page=product_info&products_id=316824 I also have a Duraspin DS 50 battery one. Would either or both of these work with flooring screws like these, if I bought a SQ2 150mm driver? https://www.ffx.co.uk/tools/product/Senco-45W65My-0074147420878-Duraspin-Collated-Screws-Flooring--Wood-Sq2-4.5-X-65Mm-1000Pk
At design stage for the trusses. Regardless of whether or not you choose to make it a room, I would be speccing attic trusses so you can make use of the space for storage. I for my double garage it was approx £400 extra.
There is no need for cavity walls. With attic trusses the room will be within the inside space of the garage anyway and easily insulated.
Its only for the floor temp sensors so I am not sure it will be worth the risk. Might be as well just drilling in the 4inch gap I left near the partitions and walls.
