Alan Ambrose
Everything posted by Alan Ambrose
Thanks for that. BTW your install looks v neat.
@Beelbeebub - I know this is a while ago, but I'm planning something similar, but portrait-style. Can I ask - did you use long rails, and if so which ones? The go to, Renusol, seems to advocate their short rails for profile roof.
If were me, I might replace any v dodgy wood like for like and maybe consider a coat of Bedec barn paint. Maybe I’m biased as we’re just about to clad our place with oak featheredge. What’s your overall objective - aesthetics? Better insulation? Reduced maintenance?
I don’t think there’s that much difference. About the same U-value, both have basic fire retardant. Mostly installed by the same crews with the same equipment. We went wood fibre, from memory slightly more expensive. Mainly because ‘wood’ rather than ‘paper’ - the wood fibre resembles the stuff that mdf is made of. The installation for both needs to be done well. I’ll write up our unfortunate experience and some recommendations when I get some time.
Insulation layer for shorter time constant?
Alan Ambrose replied to Alan Ambrose's topic in Underfloor Heating
@-rick- you couldn't achieve the same with MVHR or wouldn't it have enough throughput? -
I remember working in a very air-condition building in Bahrain. I used to open the windows to warm the place up. Luckily we could. Sometimes, I think, you just want to control the temperature rather than living in a isolated machine-controlled cocoon. Maybe you're cooking Xmas dinner for the family and want to stop it getting too stifling. Yeah open the windows but you would like to stop heating the place too. -
Is there an advantage to putting an intermediate thin-ish insulation layer under UFH screed in a PH-style house? We have 300mm XPS with a 150mm slab on top and we plan to have 100m screed with UFH. But I’m wondering whether, say, a 30mm insulation layer and then 70mm screed would provide a shorter time constant for more rapid heating & cooling. I know some peeps subscribe to always heating to 20/21 degrees and cooling to 25 degrees 24/365 using the slab as a big heat reservoir. But that assumes you never want to change the temperature any, and if ever you do, then it’s going to take days i.e. a v long time-constant.
Glulam (inc. service class)
Alan Ambrose replied to MortarThePoint's topic in General Construction Issues
re: Cascamite Fairly obvious when you think about it, but proper structural glues have proper datasheets with glue strength under tension, shear etc. All the consumer glues just say 'super-strong' or some other unquantified nonsense. Having said all that, I can't see strength numbers for Cascamite. Strict prep, thickness, temperatures, application methods etc if you want to get the manufacturer's results. Worth bearing in mind that a lot of reactions are exponential with temperature and you can cheat the weather a bit by maybe using a fridge or a bucket of hot water. Also watch for peel strength when handling - may be not so strong even if the shear strength looks good in situ. Fill your boots -
Err, CVC was what Nick recommended. @JohnMo interesting on your use of co2 monitor, I expect I'll need to do similar. Is it possible to post your link again for the eBay sensor - it just gives me 'error page'. BTW CVC quoted an extra £190 for the humidity sensor, which makes the total about £680 more than the Zehnder unit. I'd love to see what's in the sensor - I bet there's less than £10 of parts there. I've got the unfortunately named SHT35 humidity sensor in other parts of the build - the chip is about £6.
Hot water return in Hep2O? is this really a problem?
Alan Ambrose replied to Great_scot_selfbuild's topic in General Plumbing
Curious - I can't think why it's ok for hot feeds but not for recirculating. -
Ah interesting, I hadn't clocked the bit about the humidity sensor - a bit dumb that it wouldn't have. BTW cheapest places I could find were TradeSparky for the Zehnder and CVC for the Brink. This thing? https://www.ventilationland.co.uk/en_GB/p/brink-excellent-rv-humidity-sensor/5791/ Seems expensive. I was planning boost in the bathrooms and kitchen and maybe a co2 sensor in our bedroom as I think my other half is very sensitive to this - she wants the bedroom window open all year round - even in minus degrees.
Congrats, looks v tidy. >>> My understanding is that a female port (where a rubber seal and seat for that seal is absent) requires the mating male to be tapered thread (BSPT) and wrapped with thread sealer to make the joint I don't think that's right. My understanding is not to mix parallel and tapered unless you need a temporary bodge. I think most threads used in residential are parallel. Both parallel and tapered will need good thread sealer and I've used some cheap parts in the past that needed a bunch of thread sealer to work. That's all consistent with the instructions you quoted which said, in effect, 'don't use tapered parts here'.
OK for anyone 'following along at home' I decided on the Brink unit. I was leaning towards Zehnder but the physical size was an important factor considering the slopey attic it needs to fit into. I figured I needed 30cm above the unit to cope with the ducting. Not yet sure what I'll do re controls - the branded controls are stupidly expensive imo. I'll probably run CAT6 to the places where we want controls and/or sensors and assume I'll figure out the wiring later.
Ah thanks Mike. For anyone following along in future, this is what Gemini thinks, but having looked more closely at Ubbink's offering, I don't see any reason why it can't be shortened - it looks just like a bit of flexible insulated pipe that has some ends formed in it - and I think you could do that forming by hand without a problem.
Was going to use these to connect my MVHR box to the ducting (either 180mm foam ducts for external or the 180mm connectors on the plenums): Ubbink Aerfoam Insulated Mass Flow Ductwork Sound Attenuator 180mm These are nominal 1m and stretchy of course. The best connections I can see would bend to about 0.5m long - can I shorten them OK by cutting and forming something a bit like the factory ends?
Anyone gone down the max self consumption route?
Alan Ambrose replied to Alan Ambrose's topic in Photovoltaics (PV)
>>> why are you limited to export volume? Well the DNO will always limit, even if it's only to 17kW on single phase - it's a risk thing with local voltages apparently. And we have planning permission to cover one roof and the 'cartlodge' with panels. -
@Beelbeebub Yeah, that's pretty much what I want to do for similar reasons. Presumably you had to limit the export in software but had a much larger inverter? -
So, am I right in thinking that the old way of looking at the problem was to optimise for max summer output i.e. S facing and make the most of the panels you’ve got. And the max self consumption route is: panels are cheap, spread panels east-west for long output during the day; have max panels for usable output in the shoulder seasons; and then a bit of battery to cope with occasional dull days and to keep the heat pump running overnight. Almost ‘off grid’ for 3 seasons, with a bit of backup help from the grid in winter? -
Is there ever a problem where you would like to have more panels but your DNO-agreed inverter size and the max oversize of panel capacity for your mppts limits your shoulder seasons generation?
