Everything posted by Adsibob
The calculator cited was this one I think, but it is designed for shelves: https://woodbin.com/calcs/sagulator/ but I guess if you have support from above every 400mm, it’s perhaps similar in principle to a 400mm depth shelf. Either way, I think 6mm would just about be okay, as long as you added additional bracing for any pendants. But why are you using plywood as your ceiling? You can’t plaster plywood.
I need to change my driveway lighting. Currently we have Phillips Hue GU10s in some wall lights, which are surface mounted onto the wall. It works well. Some of those wall lights will need to go however, and only in ground spots (uplighting the wall) or in wall spots will work. In either scenario, the fitting will effectively be incased in concrete. The fitting looks something like this: Will the concrete wall/floor all around it interfere too much with the signal, such that I won't be able to control it with the Hue app? There will be other Hue lights in the driveway that won't be encased in concrete, so they will create a fairly decent mesh, but probably nothing within 3m or so of the ones encased in concrete.
A year after our main build finished, the builders are due back next week to do snagging. In this photo of our kitchen, there are two joins between the carcass end panel on the left and: 1) the back splash tiles - which has been jointed/filled with regular tile grout 2) the worktop, which hasn’t been jointed/filled at all - there is a small gap, about 0.5mm to 1mm thick. The grout join on number 1 has started to crack. Suggestions for filling number 2. Should I get them to redo number 1 with something else? What?
InitiallyI was starting with a 45 degree dud, and then shaving that to see if I could get it to work. This was far to iterative, so I abandoned that method in favour of using trigonometry to “design” the right angle, from then on, I pretty much got all of them correct except for two where I forgot that a line I was working from wasn’t actually perpendicular to the wall. The floor plan definitely shows a perfect rectangle, but my builder didn’t build three room that way.
Right, I’ve googled a mitre saw. Can’t believe such a thing exists. If it can cut a 47 degree angle, it would have saved me quite a bit of time.
A more experienced DIYer and family member came over and had a look at my half finished project. He pointed out a mistake I’d made. He’s coming back tomorrow with a “mitre saw” so we can fix it. I will need to Google what type of saw that is. And tidy up my workspace!
So I’m building a cupboard in my converted loft. There is a sloping ceiling coming down on one side of the room, and I’m installing some vertical wooden posts from the sloping ceiling down to the floor, so that I can then hang some cupboard doors from those verticals. Each door will be about 135cm high. I thought this would be a very straightforward task. I ordered some tulipwood posts that were 2.7m long, ready planed and the right dimensions so that all I would have to do was cut them diagonally to match the diagonal of the ceiling slope. Turns out that instead of a perfect 45 degree angle, my ceiling is 46.7 degrees. It also turns out that the walls either side of this cupboard area are not perfectly square. So there has been quite a bit of swearing and trial and error to try and get the angles right, and to try and mitigate the non-squareness of the walls. Also a few trips to screwfix to get things that I didn’t realise I needed until midway through (such as knee pads, plasterboard fixings and a countersink bit). I’ve probably spent 3 x 3hr sessions on this job, and still only finished half of it! Is this complete underestimation of the task normal??? Part of the problem is I am trying to achieve perfection, when it really is not required.
Outdoor tap splitters and irrigation systems
Adsibob replied to Adsibob's topic in Landscaping, Decking & Patios
I’m sure you are right, but would be helpful to understand what makes the Geka Plus 4 way better? Is it simply that metal is more durable than plastic? Or is there some other advantage of the one you’ve proposed? -
This looks quite good, though wonder if I will have enough water pressure for it: -
Adsibob posted a topic in Landscaping, Decking & Patios
Looking at the weather for the next 10 days and can’t see any rain. Need to sort my irrigation system out. I didn’t lay an underground sprinkler system prior to laying turf, so I’m limited to a simple hose sprinkler. But my grass area isn’t huge, so two sprinklers is enough. There appear to be a multitude of splitters available: made of brass, plastic, in a simple Y shape, or a sort of T bar looking arrangement. Also wondering about whether I should get a three-way splitter so that I can have a spare outlet for general hosing. What have others implemented, and are you happy? -
Yep. Commonly known as a genie lift, although other brands are also available.
Did you ask for alternatives? Otherwise, it’s like calling a car dealership, asking for a car, and being sent one you didn’t want. If you want a BMW you need to ask for one. Otherwise you might get a Dacia. Trying to be more constructive, it’s worth noting that RSJs typically aren’t that expensive. Once you get a new design from a new SE, you might find that the RSj supplier is willing to deliver the new beam and take the old beam away at the same time, and that it won’t cost more than a few hundred pounds for the supplier’s trouble. Find out who the supplier is, call them directly and see if they are amenable to helping you (once you have the spec for the new beam of course).
Difficult planning application for loft conversion
Adsibob replied to Ernie's topic in Planning Permission
I would try to do what you can to comply with the request. If you cannot comply by the deadline, explain that you need an extra few days and ask them to delay the decision until you’ve had the opportunity to comply. -
We have a Ring video doorbell, and four Alexa devices (an Echo Show, an Echo and an Echo Dot and an Echo Plug). It’s currently set up so that when the ring doorbell button is pressed, each Echo sounds the bell, and the Echo Show displays the video feed from the bell. In theory, this is a very good thing. In practice, there are two issues: 1) the video free on the Echo Show does not display for long enough. We have that Echo va Show by the front door, but if you are on the loft floor, by the time you get downstairs to the front door, the video feed has stopped, so you can’t use it to see who is there. 2) It would be great if the doorbell sound on the Echo Plug only sounded between 7am and 7pm, so that it doesn’t wake the kids. I could put a timer on that plug, but the additional hardware will look quite unsightly, and I was hoping there would be a “smarter” solution can either of these issues be solved? if so, how?
MVHR loft install help
Adsibob replied to richo106's topic in Mechanical Ventilation with Heat Recovery (MVHR)
The photo is not the OP’s. -
I doubt it. We laid about 9 or 10 tonne bags of top soil/soil improver and watered it thoroughly for the first month. Something went wrong in the second month I guess. I think I let it grow too high.
We had new turf laid about 2 months ago. Lawn is now fairly well established, but this last 3 weeks I didn’t cut it regularly enough and now it’s a bit patchy in places, and I’m other places the bottom of the grass looks a bit brown. Found various products made by Westland which claim to thicken and/or darken the lawn. Branded “aftercut”. Anyone have any experience with these?
Hi, not too happy with my 9 year old plastic Bosch rotary lawnmower. Thinking of upgrading to a cylindrical one, as apparently they “stress” the grass less, but just wondering what other’s experiences are like.
MK Masterseal vs British General vs Knightsbridge
Adsibob replied to Adsibob's topic in Power Circuits
Thanks guys, you’ve saved me a lot of money! -
The socket will mainly be used for lawn mower and other tools. I naively assumed that to be safe, I needed RCD protection in case I cut the power cable for the lawn mower. But the house was just rewired from scratch, so does that mean we will have RCD integrated on all power sockets at the consumer unit? -
I’m afraid that doesn’t mean much to me. What does the extra pole mean in tens of cost benefit analysis? -
So it’s clear that the MK Masterseal has a higher impact resistance rating, but is that worth spending an extra £61.40 for? -
My sparky installed an external socket made by British General. It didn’t survive long enough for me to use it. Maybe somebody knocked into it, or maybe the outdoor temperature changes cracked the plastic, but it died. Screwfix refunded me the £9.95 purchase price but have refused to pay towards the electrician’s charges to replace the unit. Lesson learnt: don’t buy cheap! The next cheapest unit (at about £26) is Knightsbridge but I’ve never been happy with any sockets I’ve bought from them. They have all had some aesthetic design flaw or make an annoying noise when in use that just smacks of poor engineering. The next price up (at least in Screwfix’s catalogue) is MK Masterseal. Expensive, about £42! Wondered on people’s thoughts of these brands? was I just unlucky with BG, or is this a genuinely sh*t brand? Thoughts on Knightsbridge and MK?
