Everything posted by Adsibob
We have planned to use chains as a decorative way of transmitting rainwater down from the gutter to the ground (about 2.3m). However, saw this somewhere else, and it failed horribly. Have a look at the video: ec24ac23-1c5c-4276-bd58-f4cf9b0b8650.mp4 Mentioned this to the designer, who said several chains will work better than one, and the trick is to fill the hole with the chains as much as possible. Our hole has a diameter of 52mm, so wondering which chain size to get and how many lengths of chain to try and implement. Anyone have experience of this?
I have an imist system. The unit is bleeping a rather loud intermittent bleep every 20 minutes. I suspect it is some sort of alarm to warn the user that it needs its annual service (which is booked in two weeks) but I don’t know. Does anybody have an imist? I tried locating the manual online, but the imist website is down. We could flick the switch at the main consumer board, but I have a feeling that may shut the water off (there is a priority demand valve that diverts water to only the imist in the event of a power cut - stupid, I know).
Anyone know where I can find jumbo sized MDF shelves
Adsibob replied to Adsibob's topic in General Joinery
Just wondering So I’m exploring the idea of splitting them up into sections. For a 140cm width, will two x 70cm be okay, or am I best to split into three. I’d like the left hand side to have the ability to store records, so I could have two times 35cm wide sections, plus one 70cm section for books. Although storage areas will actually be less than this, as need to allow for the width of the uprights. -
So this works out at 45mm thick shelves. What if I wanted to u use this technique, but make it thinner? Would the same principle work with 12mm ply either side of 15mm battens? -
I have these already. What would this be useful for? -
Yeah, I guess it’s not too difficult to do this - certainly within my capability. But I will be sawing by hand as I don’t have a circular saw. I’m also not that keen on the chunkiness of these floating shelves. Ultimately the nook these are going in is in the corner of my room, and the shelves will be painted same colour as wall (a darkish green). So I don’t think the battens would be that visible once books are in. -
So the new plan is to use a different alcove in the room altogether, with the result that most of the shelves will be much shorter, at 1405mm long, rather than the silly 2.57m length I was working with before. I’m also not that bothered about making them “floating”, particularly if I can get away with installing three battens along the three sides that come into contact with the wall as supports, though I would make the two end battens slightly shorter than the width of the shelf so they aren’t so visible. So with this in mind: 1) is 25mm thick pre-primed MDF thick enough, or do I need to go thicker at 30mm? 2) should I abandone MDF altogether, like I think some on this thread favoured? 3) what thickness should the battens be? Thanks all! -
Two months later I still haven’t ordered anything. But I have rethought the plan… should hopefully be easier… -
Your situation sounds very similar to mine. We were converting and extending a 1930s semi, but council limited the height of our full width extension and so to make it “nicer” to live in we dropped the internal floor level of the whole house (not just the extension). But in our case we took the opportunity to install a slab floor, instead of the ventilated timber subfloor that was there previously. To do this, we had a DP membrane cover the whole floor (over the slab) and then come up the sides, past the house’s original DPC. The build up looked something like this (there is some info missing, like sand blinding, which in think was in a separate drawing): And before anybody tells me 100mm insulation isn’t enough, this wasn’t a passive build and I was starting with a 1930s house and a council that wanted to limit parts of our extension to only 2.4m high!
Court Judgments like this make me happy
Adsibob replied to Adsibob's topic in Party Wall & Property Legal Issues
You are assuming there was an architect. Also, what does “builder” mean these days? Any cowboy can call himself that, even us lot on here. -
So let’s just ignore legal precedent and do what we like. Property rights are sacrosanct. Full stop. -
Seems pretty clear from the report of the judgment that the offending neighbours were told part way through the project that they were trespassing: The judge found that, by April 2019, Mr and Mrs Ashraf 'were on notice that they would be encroaching and that there would be a trespass', but carried on with their project regardless. -
By your logic, anybody could just land grab to their heart’s content, so long as they paid the going rate. Makes a complete mockery of property rights and property rights are the foundation of the rule of law. -
Yes, because it shows the justice system working, and idiots getting what they deserve. My reading of the article is that they were told to stop during the building process and ignored the requests. It’s not a question of a settlement, the encroachment was causing ongoing damp issues, so an injunction is a suitable remedy. -
Adsibob posted a topic in Party Wall & Property Legal Issues
https://www.standard.co.uk/news/london/neighbours-at-war-extension-redbridge-london-shabaz-ashraf-avtar-dhinjan-b1077637.html -
A family member has asked me to post this on their behalf: Victorian end of terrace house in Cardiff. Has had various damp problems, which have been “fixed” but the humidity levels rarely fall much below 60%. Kitchen is currently being redone and is being plastered. The owner of the house has a dehumidifier on site to aid with drying everything out. Got about two buckets of water out of the air today . He’s worried that the dehumidifier might cause the plaster to crack as it dries. But at the same time, he doesn’t want the 60% humidity in the house to slow the plaster drying as he’s in a hurry to paint. He asked his plasterer who said the dehumidifier won’t crack the plaster. Does everyone here agree?
You keep mixing legal personalities here. The director and the company of which he was a director are separate legal persons. He can only be liable for the debts of the company in certain limited circumstances, such as if he committed wrongful trading, by allowing or authorising the company to continue to trade, after he knew or should have known that it was insolvent. It’sa fairly complicated areas of law, but worth reading up on before going off on some crusade against the director, when he actually might not have any liability to you because your contract was with the company.
incredible. On most days recently, it has felt like it's not stopped raining here in the last month...
https://www.telegraph.co.uk/news/2023/04/25/hosepipe-ban-south-west-water-devon-plymouth/
