Everything posted by Adsibob
No, but I do have a lot of experience of DIY Kitchens and I see that as a barometer. Look at truspilot: DIY Kitchens gets a 4.6 rating based on 4804 reviews, whereas better kitchens only gets a 4.2 based on only 358 reviews. Although this doesn't allow one to compare DIY Kitchens vs Better Kitchens directly, at least not without knowing if they are direct competitors, it does give some guidance as to the number of reviewers who thought each company had the expectations they had formed. So if when you look at DIY Kitchens you like what you see, then there is a 92% chance those expectations will be met when you purchase from them. If you don't like the doors that are available from a company (and you are not going in frame) you could always go bespoke for doors from a joiner or specialist kitchen door manufacturer and then just buy the carcasses from the kitchen company. That's what I'm doing with my kitchen order this time around, simply because I found DIY Kitchen's styling a little bit too limited.
@dpmiller this sounds like a genius idea! I have contacted Schiedel and will report back with their comments. My architect also pointed out that our stove is actually only about 1m across and 2.7m up from the roof of our ground floor extension, so we could vent in the direct air supply from there with just one or possibly two u bends and a much shorter run of pipes. But that does expose my install to a wind direction issue, which as you suggest, the Schiedel would eliminate. Have you installed the Schiedel Swift Air? Any downsides of their system?
I'm about to start on this journey and I'm realising now that I've left it a bit late. I need to finalise exactly where my vent pipe for the direct air is going to go. My first question is: am i right in thinking that the longer the air feed pipe and the more bends in that pipe the worse the draw of the stove? I ask because i have three choice of vent route. My options are: straight out the back of my stove and then an immediate 90 bend taking the flue above the FFL where it will need to be boxed in against the wall, and then out the wall some 5.5m later = one bend plus 5.5m of duct; down into the floor and out again in same position as above = will require at least three bends plus 5.5m of duct; same as 2 but wall is 7.5m away. If number of bends and the addition of an extra 2m doesn't matter, than option 3 is both easier for me to install and aesthetically much more pleasing as the pipe would come out the side of our house to an alley where aesthetics are a low priority because we never really see that elevation of the house. If however option 3 is going to give suboptimal performance, then I may have to consider options 1 and 2, but this really is sub-optimal aesthetically. I hadn't appreciated the pipe needed a diameter of 100mm, that seems really rather big, and will create a real eye sore on my rear elevation, particularly if - as @joe90 says earlier on in this thread - the terminal of the pipe needs to be 600mm above the external floor level. Earlier in this thread @Temp posted a helpful link (http://www.stovesonline.co.uk/direct-air-supply-stoves.html) but I think what would be even more helpful is any reviews of stoves installed (and used) with a direct air supply.
Wren did this "luckily we have a promotion at the moment" scam to me recently! Incredible how these kitchen companies don't have a basic understanding of the law of contractual misrepresentation. Inducing a customer to enter into a contract on the basis of a false representation about the availability of a price is a misrepresentation. Knowledgeable kitchen designer, just shame about the company's ethics.
I have always preferred an extractor that actually extracts, rather than recirculates, but then the MVHR purists on this website gave me the impression that having an extracting hood would unbalance my MVHR system. Have I misunderstood that? I thought @joe90 you had gone for a recirculating hood for this very reason? @Mr Punter do you have MVHR?
Thanks @ryder72. I agree 500mm is too little space. I’m 6 foot and my wife is 5’8”, so 5’10” is our average. If we only had 560mm of space between the induction hob and the bottom of the wall units, are you saying this would be a problem for me! Our wall units are not very deep, only 300 plus 20 for the door. Which re-circulating fan do you recommend? I need it to be recirculating because I will have MVHR. Ideally, the quieter the better.
Maybe the companies I spoke to didn't have the expertise, but at the time I was told that wind issues prevented them from going there. I guess I could just brace the panels with something strong and rigid. We were originally going to get some through the Ikea/Solarcentury scheme, but then the government pulled the subsidies and Ikea pulled out of the joint venture with Solarcentury, which was a shame. Stupid government.
- 46 replies
- overheating
- cooling
We aren't installing a heat pump or PV. In fact I enquired about installing PV on the flat roof and the companies I spoke to said they only install it on pitched roofs.
- 46 replies
- overheating
- cooling
Just reviving this thread in case anybody had an answer to this? I have a fair bit of space in my roof, so trying to work out what is the best combination of build ups to keep it as cool as possible in the summer. Appreciate the comments made by others about importance of mitigating solar gain through glazing, and I am taking the steps I can in respect of that, but need to finalise the build up of my roof and this is quite important as i plan on working out of a home office there most summers.
- 46 replies
- overheating
- cooling
Concealed toilet cisterns: Grohe vs Geberit vs Tece
Adsibob replied to Adsibob's topic in Bathrooms, Ensuites & Wetrooms
Well both actually. For most of our toilets I want them wall hung, but we don’t have the thickness in the wall to do this with one toilet, so for that the pan will be floor mounted, but if possible I’d still like to conceal the cistern. How much wall thickness do I need just to conceal the cistern? -
What’s the difference? I thought to mount on a wall, one needed a frame? -
Prior to commencing my big refurb journey (more of a voyage really), I thought Geberit was the market leader in concealed cisterns. I had no evidence to base that on, it's just what I assumed. Chatting to a friend the other day who is a property developper, he told me to stay clear of Geberit because their design means that there is a greater risk of a mistake being made upon installation as they have a peculiar fitting at one end of the pipe that comes out below the cistern. Apparently, the same junction on the Grohe models is a traditional screw ring fitting which is idiot-proof as you just tighten it to fit it. He said he'd had a few of the Geberit models leak at that problematic fitting and advised going for Grohe cisterns, with any old company for the frame. In the showroom I visited today I asked the salesperson what she thought, and she said there's no difference between the two companies, they are both "just above entry level products" and that she recommends Tece "because that is what Toto specify for their toilets and Toto are the market leaders". No idea if this is evidence based either. Curious as to people's experience with any of these three companies' concealed cisterns. We already touched on this in the other thread on toilets I started, which had some very useful observations (not to mention the banter*), but I thought this merited its own thread. *Thanks @Onoff, @ToughButterCup, @PeterW, @SimonD and even @pocster.
Agreed. At today's showroom visit I managed to get around this my measuring a crucial dimension with my finger. It turns out that German made brands such as Duravit are much more spacious than their Italian equivalents (e.g. Catalano).
@joe90 and the salesperson I met* at a showroom today are at idem on this point. Apparently, i've been exposing myself to all sorts of dangerous fomites by not closing the lid before I flush all these years! Not sure I'll change a habbit of a lifetime now though... *thereby undoing the whole purpose of this thread! Turns out it is still possible to go to some showrooms as long as you make an appointment and cover yourself in protective gear.
Excellent, many thanks @Simon R and Helen!
We are getting a staircase with steel spindles. We were going to go with powder coated stainless steel spindles, but it's cheaper to get bright steel spindles and then finish them with a blacksmith's paste or wax to give them a nice patina, and as it's all internal, the blacksmith's paste will be sufficient protection. This Youtube video suggests making one's own: 1 part bees wax, 1 part turpentine, 1/2 part linseed oil but I would prefer something ready made. Has anyone got any experience with a blacksmith's wax, and can you recommend a brand that gives a nice oiled or rubbed look? @Simon R you mentioned in one thread that your daughter is a blacksmith. Perhaps she would know?
The cabinets are shallow (300mm in depth, plus 20 for the door, makes 320). Not deep ones, so the only way to hit my head whilst cooking would be if I wanted to burn my face on the frying pan or, steam my face whilst steaming some broccoli. It's just not going to happen. We are having slightly deeper worktops , but even with standard depth worktops this wouldn't be an issue.
Because Because i want a straight run of cupboards above the hob, to achieve a certain design aesthetic, rather than one elevated cupboard above the hob that contains the extractor unit, i want all the cupboards on that side to be level (without having to raise them all to meet the 650mm height). I may have answered my own question in that this AEG model specifies the minimum should be 500mm; although many other models don't specify this in the installation manual. I wouldn't go that low, but i would keep it at around 540 or 550.
I know that for a gas hob, the hot zone needs to measure 75cm from the hob surface to the cooker hood, whilst electric hobs this only needs to be 65cm. But a kitchen designer told me that for an induction hob this distance can be even less because of the way it heats the pans (i swear she said something starting with a 5), but I can now not remember the exact amount. Does anybody know?
Thanks @Bitpipe. Unfortunately Velux didn't do the rooflight size I was after, so i've had to go bespoke. Got a good price on the rooflight from Sunsquare, including Sunguard Sn35/70 glass, but the quotes I've got so far on the blind are looking like almost double the cost of the actual rooflight!
@Jeremy Harris I don't suppose these were for a flat rooflight?
