tonyshouse
Personal Information
  • About Me
    Loves reducing energy use, saving energy, hates waste in all its forms.
  • Location
    Thames Valley
tonyshouse's Achievements
Advanced Member
Advanced Member (5/5)
368
  1. I think that you may well need planning permission for PV panels on a garage
  2. It is called belt and braces, the evidence is there for not needing to do this, North America and I did see a paper that referenced constant 50 C doing sufficient sterilisation against Legionella.
  3. OSB is not dimensionally stable, it can expand if it gets damp. why use plasterboard at all, that doesn’t like getting damp either.
  4. Nearly all of North America and Canada set at 50C, I have been keeping mine at 50C most of my life lower the better as less heat loss, you don’t want extra heat in the house if we get a summer.
  5. Design out thermal bridges, design in insulation, ducts MVHR, solar, shading
  6. I would start with target u-values, for me less than 0.1 for walls, floor and ceilings 0.7 for windows you may then find that you can design out heating, heating bills, servicing costs, repair costs replacement costs 1, Gshp better cop, 2 good idea, 3, 4 &5 pass
  7. Between the beam and wall or between beam and block and sub structure?
  8. I like to sit the window board on the ledge formed by the top of the back of the sill like to fill the cavity with platinum EPS beads like biscuit joints in the mitres, love gorilla glue and packing to perfect position weighting it all in place and foaming in all the gaps
  9. How many doors to get to outside?
  10. Yes but it shouldn’t be, windows often on packers should get sealant on the outside as a minimum door sills should not be unsupported
  11. I wouldn’t but you can, we will never know
  12. Mortar for me
  13. Or diagonal noggins under where the battens land
