JohnMo
    200
Everything posted by JohnMo
  1. Really you should go 25mm to 22mm stop cock, 22mm double check, then get distributed via 22mm as far as possible.
  2. Why not look at from a slightly different perspective. Instead of an electric energy store why not a water store if you have enough space. An accumulator with a pressure switch to control the pump. The accumulator goes between pump and house can be quite big, reduces pump cycles and provides a reservoir of pressurised water
  3. Not sure how good your figure are, but doesn't relate to my house at all. Same as heating, you do cooling slowly, it keeps the house temperature down and the RH down. I run a target flow of 14.5 and Don get any issues If you run a buffer you really the UFH engaged to provide that function. The floor doesn't need to be many degs below target room temp to get quite a cooling effect.
  4. Bit 1990s. I hate it, except proper plaster coving in proper period properties. Modern stuff used to hide shoddy work from everything I have ever seen. Nice sharp internal corners for me.
  5. I would be careful just fitting a 2 port valve and thermostat as the original functionality of the system is lost a d you then zero means to protect the floor from excessive temperature. Is the grey cone bit just a tamper proof cover, fitted instead of the thermostat knob? Instructions attached AI000086447883en-US0201.pdf
  6. My Myson fan coil has multiple speeds, but just set mine on speed 1 and leave it. Water is always being circulated in either heat or cooling mode. Just use it like a radiator on weather compensation. Find that works best, zero thought.
  7. Just use a fan coil in summer house. 15mm tee'ed into main flow lines from ASHP to house. About 12m of pipe in each direction.
  8. Hi John, what's the floor area and the floor construction inc covering your UFH is in? Was this ground floor only, or upper floors Bungalow so ground floor only. 192m² area, UFH at 300mm centres. 200mm PIR with UFH pipes stapled to insulation. 100mm concrete screed. Summer house also well insulated.
  9. Why pay for system when you already have one for free. Clip pipes to insulation and screed over done. Way more effective, run low and slow, use the depth of screed as a big buffer for the heat. Had a system similar to Wunda, was cr*p, high flow temp required to get any output. Disconnected it in the end. Hook up to a heat pump - no pumps or mixers, single zone, set weather compensation, cheap and effective to run. You get cooling for free.
  10. Under a mortgage, you will be one the keeper of the land and property not really the owner, the mortgage own it in reality, don't pay your mortgage the mortgage company evicts you. Not until you become mortgage free, that you really own it.
  11. I would speak to a decent plasterer. We did up an 1830 house, it had similar damaged cornice and lathe and plaster ceilings. He remoulded the cornice in place and made good everything with the correct materials. Once painted, you couldn't find where he had done any work.
  12. If you aren't really that happy move on to the next house, no point buying a house then fretting over it's safety. You obviously have concerns, enough to for you write about them. Plenty of other houses out there.
  13. All of a sudden we have moved from our cold weather into hot, so flicked the heat pump back into cool mode for awhile yesterday, as the house was starting to get a bit toasty. Over a period of 2.5hrs we pulled 12.5kWh of heat out the house floor and summer house using 2kWh of solar energy. The fan coil decreased summer house by 5 degrees in 2 hrs. Similarly the house temp dropped a similar amount but with a 15 min lag over the fan coil. Cooling in house is via UFH loops only.
  14. Mine are only 200W elements so ok for towels, but not really heating the room, just adding a little heat. But bigger wattage are available. They come with a tee piece to dual fuel. But mine are just electric. I use a Termo TTIR, thermostat and timer.
  15. Convert to dual fuel with Termo One thermostatic heat element
  16. If was doing it again I would do water UFH at 100mm centres in bathrooms AND electric. Water supplies the bulk of the heating in winter, the electric makes the floor feel warm if you want
  17. Just look at a datasheet, they even say they are rubbish, when you apply your airflow rates. Think from memory a typical 200m2 house is going to get a kW of cooling if you are lucky. I was getting a CoP of about 7 doing floor cooling and a fan coil, doing a a cool battery you need to flow at lower temps and CoP is likely to be nearer 4. So rubbish output and higher running costs, what is there to like.
  18. Ours is 70mm thick wood, then the 90mm Frametherm 32 mineral wood (not 140mm) in the walls and plasterboard, 200mm of EPS70 and YBS SuperQuilt in roof and I think 200mm of EPS70 in the floor. We have a fan coil for heating and cooling. But yes it can get hot, because it's angled for the views and the glazed end gets the full sun.
  19. You don't really need to be inside inside. Getting data out of a metal box maybe problematic. Somewhere close ish is fine, I was using Shelly add on to monitor at one point. You need to use either a thermo well or heat conductor paste and aluminium foil tape if externally on the pipe. The only issue is logging data intervals can be quite wide, so ok with a few measured data points. You also really need the electric data and temperatures time point to coincide to get reliable data points.
  20. You need a decent method of cross ventilation, so air is allowed to come in the dry rooms and is sucked out of all wet rooms. Extract - dMEV fans cost almost nothing to run, Greenwood ones come up on eBay quite often for not much money they will react to rising humidity. MEV is a central unit if you have easy access to run ducts. Supply - You have two options retrofit trickle vents to dry room (not wet rooms) windows or through wall. Through wall humidity activated vent something like this https://www.bpdstore.co.uk/glidevale-fresh-99h-humidity-sensitive-wall-ventilator/p/231 Their trickle vents https://www.bpdstore.co.uk/glidevale-energy-saver-humidity-sensitive-trickle-ventilator/p/182 Other makes and models are available. So you need an air inlet in all dry rooms, bedroom, lounge etc An extract fan in all wet rooms, bathrooms, utility, kitchen etc. The fans run at a very low flow rate 24/7.
  21. We did 140mm (I think) mineral wool. With a small building you are getting diminishing returns quite quickly. We only need a kW to heat even when minus lots outside. Adding more wall insulation wouldn't have changed that much.
  22. You actually have volumisers not really a buffer. A2 valve isn't really needed. If A1 closes the flow entering FCU is stopped and so is reverse flow. Why will condensation be an issue, just pump the water around in cooling mode above dew point which will give you plenty of cooling power from the fan coils and no condensation issues. With a heat pump you have a minimum flow requirement, it is very unlikely you will get through a single radiator. My 6kW is 9L/min minimum flow not sure you will squeeze that through a bathroom radiator. From your info on the other thread your heat load is around 2kW, but you are planning 11 radiators and 4 FCUs - seems a lot, plus two volumisers. Think some simplification is needed somewhere. You're well insulated and you really don't need heat in every space or under every window to heat up drafts, that may exist in a more normal house.
  23. So almost operating as a single zone really. Hence no issues.
  24. I did indeed. But then even more reason not to zone. Heat pump you really have too options no zones and super simple, or a big buffer (never a small one), additional pumps to buy and run and zones with controls. I am down the simple route and now only have a switch to change over from heating and cooling and a diverter valve for the cylinder heating to CH change over.
  25. Run a low temp system, then there is no hot air being blown, just air a few degrees warmer than the room. That gets my vote also. It's simple it works, others will come along and say you can't get it to work, but it does. The biggest issue you will have is a strong likelihood of the boiler short cycling if you do zone. This will increase gas consumption dramatically. Ours used double the expected amount of gas, when I had zones. Do the system so everything is a similar design temperature and get rid of any mixers or additional pumps. Big output boiler, low demand of 2.2kW, even lower at 7 degs. I assume the output min should be closer to 5 or 6kW. If that's the case you need a minimum of around 50L engaged water volume at all times to keep the boiler happy and not short cycle. That should give you about 8 to 10 min run time for the boiler.
