Everything posted by JohnMo
Didn't really ask, just said that was what I wanted, only have double glazed in a set of french doors and three other single doors, the rest is triple glazed.
Couple things spring to mind, assuming hot and cold are connected correctly. If you have moved from an oil or gas boiler, the mixers maybe set up for high temperature hot water, so they are mixing in lots of cold. A lot of shower mixers have an adjustable mixer setting, inside the handle. You are trying to store water at a temperature not suitable for mixers. You need water above 45 for many to work acceptably. (ours were not much use until over 47)
Pozi rafters and anything manually fitted for installation would be a utter pain. To get it done well expensive and not likely to happen. Blown in gets everywhere (when done well - will slump over time, when not done well). We did spray foam, really quick hardly any mess, vapour stop membrane below, breather membrane above. Not the same job as a cowboy installer spraying under a vapour stop old membrane in a cold roof.
We have 100mm concrete above insulation and pipes are stapled to insulation. Slow response (but that is mostly down to 300mm pipe spacing), but that's fine. It gives a steady consistent house temperature. You can charge floor on cheap rate, with excess PV energy via heat pump, no issues. You use it like a big storage heater. You can do straight Weather compensation. Zones and setback times are a bit of waste of time, so keep it simple. We have a sunny 10 Deg day, with 2 degs expected overnight. Plenty of excess PV today, floor charged up for free, heating done until tomorrow. No house over heating.
The GSE trays have flashing at the side and top and it's all interconnected to stop water getting where it shouldn't be. While maintaining air movement. Omit the side flashing and your own thing at your risk is what GSE would say. Perhaps put one panel less on the roof to get space to do things correctly? move SVP, then go velux? Dump the roof light?
Or just go for an already engineered solution. VELUX Solar Integrator ODL The VELUX Solar Integrator ODL is a flashing solution designed especially for solar panels. The solution enables a seamless installation of VELUX roof windows with a GSE IN-ROOF system. The low-profile flashing design ensures.... Your plan misses out the side flashing which stops water ingress under side of GSE trays, from top or by wind driven from underneath. Any flashing would need to tie everything together to stop leaks.
Just fix as if it's wood, any adhesive treat as eps. Gorilla glue works well. Long screws and rawlplugs also
Geography lesson United Kingdom, made up of England, Scotland, Wales and Northern Ireland. UK I take it you mean England? No you can't. But as I said the roof build up is vague at best, at the wood fibre layer, there seems to be 3 options (OSB, wood fibre or sarking boards), which is pretty poor, there should be no options, it should state what is expected.
The plan is vague stating slate or concrete tiles. But they both have a different roof build up. Concrete Tiles need the battens and counter battens on sarking boards, natural slate on the other hand, just needs the breather membrane on sarking boards and then the slates directly attached to sarking boards.
Our pipes were below everything (at hardcore level, so about 450mm below FFL. We took 110mm pipe to the shower tray and then stopped screed / concrete with additional insulation, to act a mould. Once I was ready the insulation was removed, to leave a void to work with. The drainage fully completed for the shower tray, I back filled the space with concrete, then did flush fit shower tray.
You can get blown mineral wool also, so may be another option
Should be free, they f*cked up and did it incorrectly - if not just with hold £xxxx from final bill, and issue them a bill if you fix it
- 10 replies
- floor joists
- loft conversion
- (and 10 more)
Wouldn't the simple answer be to get builder, to add packers to the existing joists to bring up to level needed? Your solution looks complex and maybe needlessly so, and maybe more costly than it needs to be. The above assumes the joists are per drawing spec.
- 10 replies
- floor joists
- loft conversion
- (and 10 more)
Walk in wardrobe, supply or extract
JohnMo replied to phatboy's topic in Mechanical Ventilation with Heat Recovery (MVHR)
Mine is a slightly different answer to the above. You really need to map where your air comes and goes. What directions does it travel. We did supply, so we slightly over ventilate the main bedroom, air then moves to ensuite and excess air goes under door and down a corridor to make sure hall is ventilated also. It all about balance and getting best ventilation for buck. One solution doesn't suit all. But saying above - is the dressing room a wet room? no, so you do supply, not extract. -
Lime only mortar? (i.e. no cement)
JohnMo replied to Gibdog's topic in Bricklaying, Blockwork & Mortar
But what does your structural engineer say - he will have a view based on bond strength and wind loads etc. -
Just go double with krypton gas, instead of argon. Look the same as argon, should be getting a Uw of 1.1 with good frame design.
What ever you do make sure boxes are ticked Permitted development doesn't apply, so you need planning AND listed approval - they are different and the two departments do not/ may not generally communicate with each other. I once assumed they did and got bitten.
ASHP - how noisy are they in reality
JohnMo replied to Walshie's topic in Air Source Heat Pumps (ASHP)
No thanks, I'll stick with converting my excess PV electricity into either heat or cold for the house. Way better value, than anything a commercial project could offer. -
Not sure they are correct, You can do de-superheat on the chillers to get continuous high temp heat source. A heat pump on chilling mode, is blowing heat out the condenser fan (heat taken out of the cold space). Pretty sure that heat could be used, even another heat pump, in front taking some warmed air, would get a decent CoP all year round. -
Slightly issue - you can have all the capacity you want, but if industry and general public aren't using all that capacity available, you will still get curtailment at the generation end. You can put in high voltage DC interlinks to move the renewable energy further away and expand the market. You don't need to understand any thermodynamics for that. That is then reflected in the price you sell it for. And there is a big market for it. Again no need to understand thermodynamics, it just a marketable product for a given price. -
ASHP - Weather Compensation AND Zoning?
JohnMo replied to SBMS's topic in Air Source Heat Pumps (ASHP)
That doesn't help flow, it just adds system volume. One zone open equals one zones flow rate. You could add a bypass and big volumiser, so you can run one zone, but why? -
Also sorry for hijack That arguement is sound BUT, if the wind turbine or whole wind farm is being physically switched off and the wind farm being paid to do so (as happens quite regularly), then renewable to hydrogen makes perfect sense. It's excess electricity being stored instead of having been switched off. Hydro storage is part of that mix also. The BEV makes sense also, but if wind power is being switched off even when the BEV is charging, hydro storage is being pump up the hill, hydrogen makes sense. -
Sorry that is just nonsense. Don't think any understanding of thermodynamics is required to get a coherent energy policies. Certainly don't think a working knowledge of Enthalpy is a prerequisite, for any politician or even their advisor.
