crispy_wafer
Everything posted by crispy_wafer
  1. Floor scraper? Never used one mind but they look ideal if they can get purchase into the adhesive. Or go at it with a floor grinder and create a load of dust!
  2. Suggesting the ashp for heating only and have the immersion on a timer or some form of solar diverter to utilise excess?
  3. Mira/Aqualisa digital shower could be a saviour. The control can be located outside the shower if you wish? But they are expensive in comparison to mixer valves.
  4. Or hunt out ducovent. I’ve got these, as i was a bit late with ergovent hobbies.
  5. inside my grohe concealed cisterns the flexi from the twist stop to filler valve is narrow bore, probably 8mm I’d guess so bottleneck there too.
  6. Going to post this as could be helpful to visitors in future. For a Basin I have 10mm Hep20 and the tap tails with 1/2” connector. Because I’m working upstairs and I cannot be bothered running down and back up to isolate at the manifold, I feel I could do with some local isolation to the basin to make life a little simpler. What to do? I used the shopping list below https://www.screwfix.com/p/hep2o-plastic-push-fit-stem-coupler-f-10mm-x-m-15mm/7947f https://www.screwfix.com/p/hep2o-hx37-15ws-shut-off-valve-hot-cold-15mm/8473f https://www.screwfix.com/p/hep2o-brass-push-fit-adapting-male-coupler-15mm-x-1-2-/422fj
  7. Almost, but I think the problem I’d then have would be, a shower hose with the 3/8 female connector wont fit through the chrome deck mount, 3/8 male no problems. This plumbing lark and all these connections, well you need to have a mind of a contortionist. It’s a Problem solving bonanza. Almost like this company who manufactured this mixer from has some kind of protectionist thing going on, it’s all odd sizes. Firstly, the valve didnt have a backnut (must be lost somewhere), tried 3/4” too small, 1” too big, took it to work so the inspection team could measure it up for me, turns out M30, 1.5 threads, thankfully a chap on the machine shop floor found a large nut and recut the threads for me.
  8. Scolmore click mode is what I’ve put in also, put them A and C sockets in most rooms, next to bedside tables, next to lounge seating, and near media points, and a couple near some large windows just in case i may need to charge a blind or two. Works out to 2 or 3 per room mostly. Think I paid about £9 a pop, bought from someone like me who orders in bulk (too many for project) to get the price breaks then flogs the rest.
  9. Want to replace a through deck shower hose to a longer one, valve body has one of these adapters with it, bought a replacement hose but the 3/8” male wont fit the narrow end of this adapter, the valve outlet is 1/2”. I guess I’m asking if there is such a thing as a 1/2” to 3/8” adapter, or is there another way?
  10. That’s first job tomorrow sorted out. Thanks.
  11. One of these fits, would that be the right type of fitting to use?
  12. slowly getting dizzy from going round the bend... Seem to have an array of fittings except the one i need grrr! What do i need to attach to a copper pipe to allow this to connect please? I can solder, but compression, or push would do me equally as well. Got some lovely Hep20 tails, but the connector doesn’t fit my bath mixer controller. Thin hep is 10mm and the mixer is 8mm. Ta.
  13. Maybe a bit of 25*25mm angle drilled and screwed to each stud, bit of 15mm ply/osb spanning between them screwed to the angle. Might need to experiment with screw lengths…. Or dry lining boxes!
  14. If push comes to shove (last resort type stuff) and you don’t have enough clearance room and you don’t want to mess with the strong back then you can transition to oval mvhr ducting.
  15. Currently stuffed with pir and slc to smooth it out! Was trying to at least look at alternatives to a newel and balustrading. However If we do go the newel and balustrade route then this would be connected to the stringer and fixed onto the trimmer with a short L return into the block wall. I wouldnt need to try and do anything with the steel other than fix some timber/ply to which the flooring and balustrade channel would attach to.
  16. @Gus Potter this is what BC signed off... Drawing without protection to the top 2.5 treads... I'll admit I haven't read the regs and I assumed I need guarding. If I need guarding in place, then I would like something that gives a solid wall effect, but only to 1m tall. I'll give your suggestion a go, nothing to lose in trying.
  17. Xscuse the mess, while I'm thinking out loud, I'm thinking of building up a block wall at the top of this stair opening, instead of a timber balustrade and newels when I put in the finished staircase. I can cut and tie into the blockwork behind the plasterboard and mortar onto the short bit of block at the end of the steels, but I need to carry on the block to at least the end of the trimmer about 450mm that the staircase will bear onto, so it will carry on over the two steels a little. What I don't know is if this blockwork would be structurally sound enough to satisfy BC, and whether it will stand up to being leant on etc, . Height wise I'll build to 1m. What options would there be for anchoring the block over the steels? Would welding rebar onto the steels and using hollow blocks over with concrete fill be an option or is that bit overkill?
  18. I’d get in touch with the supplier, they should be helpful in advising your options with your specific joist layout/size/depth..
  19. Aico are about 150mm Dia, so a 50-60mm hole for hiding/retrieving a driver should give you room for fitting the smoke alarm base, if you cant use the manufacturers holes then I doubt you’ll get shot for making your own fixing holes.
  20. As my MVHR unit is loft based, I constructed a small floor to ceiling cupboard in my sons room for shoes and the like. At the back of this is a 300mm*500mm void which I pass a bunch of ducts and an SVP stuffed with sound insulation as best i could. All through egger ontop of posi's. Personally I wouldn't cut each hole individually. Edit, All this is within the heated envelope of the house.
  21. I’ve not seen a base like that one tbf, being pragmatic about it, if it’s grey water and it flows without stalling then I don’t see a reason to change. Don’t understand why you’d need a swept bend, the chamber is fine as that provides a bend between in and out.
  22. Just trying to figure something out and could do with some confirmation. I have an island and it will have a worktop downturn at both ends. Do I still need end panels? I'm thinking not. But I've been sent a couple, and am trying to work out whether to raise a return or not...
  23. used 22*100 rough sawn here, 22*75 may have been better, but it gave plenty of scope for board ends... Other thing I'd note would be working out lamp, mvhr duct, aircon, speaker placement beforehand to eliminate any potential clashes.
  24. Trimmed some end panels and have some non faced edges that I’d like to protect. once upon a time it used to be pva that was used to protect them. But since times have moved on and it’s been shown that pva is no good around moisture could I paint on sbr instead? I’m guessing at this point so please put me straight 👍. ta, marek
  25. Cheers, I'll have a go at that...
