Eric
7502 profile views
Eric's Achievements
Regular Member
Regular Member (4/5)
58
  1. They are still in the attic of the house when I sold it 😉 Worth asking if they would keep some for you. I have tiled 2 houses and could never get the same ones that’s why I don’t mind having spares just in case.
  2. 10% as above, I think it’s better to have a couple of boxes stashed for future as they end up obsolete so fast, in case of damage etc.
  3. Plus 1 for the Huepar, certainly good value for money.
  4. Could you remove the airtight board and fit 25mm celotex? Roof colour looks nice 👍🏻
  5. I worked on the demob of Strangford.
  6. Always nice to get a before & after photo, looks very impressive! We have to be finished this year, gearing up for a final push but I think it’s actually harder now than ever…
  7. I use the multitool to notch the plasterboard where the brackets/hangers are.
  8. You wouldn’t see them then though…… 👀
  9. Your approved drawings will state what is required for fire regs, for other walls as above just plasterboard or osb/ply then plasterboard means there is always material behind the plasterboard for fixing items in the future.
  10. Is it possible to get a closer picture where the pitched roof meets the neighbours extension? it may need a better valley made against the extension, possibly with fall to keep the water moving. Others will chime in
  11. Hammer 🔨😬
  12. You could get a job as a narrator for The Curse Of Oak Island, they drone on about finding mysterious bits of wood and nails.
  13. I think the lampshade is the problem, it’s too heavy causing the cracking 😉
  14. I am looking for a supplier for 180mm dia plastic duct - just for the through the wall section on my MVHR install. Does anyone know of a company that sells 180mm, can find everything apart from that size 🤔
  15. Are you going to look for the treasure in the Rockies?
