Pocster
    29
Everything posted by Pocster
  1. Not a chance . These were bomb proof
  2. New (expletive deleted)er . No screw heads visible . Seems very zigbee compliant . Best of all a neutral !!
  3. (expletive deleted) me ! Got to find the appropriate file . Set the printer up . Print the (expletive deleted)er . Can’t be arsed ! . Had to replace the switch with one that has no screws showing ( replaced it not because of this issue though ) .
  4. I agree . I suspect billions of these little bitches end up in our oceans . Consumed by dolphins no doubt .
  5. I tried that . Or the tiny tiny flat head screwdriver. I tried patience , trying not to scratch or dig the quality plastic . Then I got (expletive deleted)ed off
  6. I (expletive deleted)ed them in the bin . Swore . Replaced the socket and did not install them . Bastard plastic shite
  7. These little (expletive deleted)ers . Nice little caps to hide the screws . Go in easy enough . Removing them though …..
  8. You can submit vat reclaim within 6 months of sign off . Can you still claim after sign off - don’t know . Scares me too much so I delayed sign off until I had spent on pretty much everything . Plus I don’t trust Hmrc …..
  9. I think it’s stands for what A (expletive deleted)
  10. Since tipping the unit back a bit and wedging the heat exchanger up at the front no water has come through the front panel . Water still pools in the non drained side though . New water free trap turned up today so will look at linking them together into the outlet .
  11. It’s a bit like my HMO’s . The emergency lighting has to last 3 hours …. In an emergency e.g fire - I reckon most people would be out in a bit less than 3 hours . Why 3 hours ? Who knows … more overkill I think .
  12. 🤣 - it it’s changed as you suggest then yep I could be very well incorrect . The annual email I get has info in it about the scheme in general - never seen a mention of any changes .
  13. Oh ! Don’t know now !!
  14. Wife Appreciation Factor
  15. Didn’t know it had changed !!!! So could be !!!!
  16. Don’t think you can ‘cat’ a light switch . But you want cat’s everywhere . I have over 80 in and ( of course ) always have the situation where I need another . There are solutions to that of course - such as another router etc . With lighting most switches are WiFi ( Shelly for example ) , zigbee , z wave , matter ( too new imho ) or custom . I had mixed issues with z wave - mainly delays . I.e walk in bathroom light comes on in 1 second or light comes on in 10 seconds . Zigbee ( apart from the odd dead spot ) has even been awarded SWMBO WAF ! . Except when it fails 🙄
  17. Hey I’ve got a Shelly rgbw and mini 1 you can have if you like ? . Not exactly what you need but will allow you to PLAY 😊
  18. Maybe not . As he was the mcs installer and set me up for eligibility for the scheme I saw no reason to query it . From the scheme now I just get the annual confirmation that nothing has changed so that I am still eligible. My mcs installer for the record was recommended on this forum .
  19. Just be careful with the direct from China ones . Can be hit or miss . But considerably cheaper . Now though I buy from Amazon deliberately so I can return it with reason for return as “ is crap “
  20. I had to supply an epc to my mcs accreditation installer . It was a requirement. Which I assume the installer sends something into the grant scheme . Installer said it was required for the grant so didn’t query it
  21. Actually just googled it - for boiler upgrades it is 7.5k . I was referring to new builds I think
  22. Unless it’s changed . Plenty of posts on here where we all got different amounts based on how ‘bad’ our epc was .
  23. I meant you’ll need an epc to qualify for the grant . The lower the epc the more the grant will be . But yes must obviously meet min regs .
  24. You’ll need an epc also . Best to get this as low a score as you can 😉
  25. Ups for home assistant is a good idea . Also as you say if a device fails I.e becomes unresponsive you can get your automation to do something else ; at least send a notification of the issue .
