Pocster
    29
Everything posted by Pocster
  1. We’ve all been there …
  2. Bro - don’t worry . Take your time , buy lots of tools , enjoy the journey.
  3. Not me mate. Even my SWMBO ( as you can imagine ) as sceptical before. Not only does it allow easy alterations etc at a later date - it actually looks really good. The problem is as I implied most of these ceilings look like shite - because the edging is shite, they've had leaks/cracks/stains and no one fixes them. They stick a big full tile (expletive deleted)ing horrible led square for a light. I'm actually surprised how 'soft' and unobtrusive it is. Let's be honest though; when you live with something it does 'fade' into the background a bit. I think if you saw my ceiling first hand you would not be overwhelmed with "swindon office" style. I *deliberately* have had people in whom would freely give their opinion - and I know they would say exactly what they think regardless of me - yet instead it's always "where is the tv?" or "I don't like those tiles " - clearly they are looking elsewhere. If you choose the correct ceiling tiles; install with care - so NOT the one's in the gym or Jobcentre ceiling - then you can get away from that polystyrene 'cheap' look. Come and take a look!
  4. For that authentic dungeon look!. In your basement it's probably the BEST solution for your ceiling. It allows lighting/speakers to be moved/rewired at will. Makes any cabling and/or pipework from the above floor easily accessible. It's light weight and easy to install. Cheaper than stud/board/skim . BETTER! - not because I did it - but because the pro's outweighs the negatives. Ultimately no-one looks at a ceiling - if you don't copy "the swindon' look i.e. stained tiles, tile size 'office' lights etc etc - it's just a white surface over your head.
  5. Just do metal frame for stud and ceiling - like me 😊 . Easy as pee
  6. Yeah - I’ll try that . Too slow you lot ! 😊
  7. This as it comes with a 90
  8. Hmmm . I can’t take enough blocks out to get the water to fall away . What about an anco type drain here ? . The 90 at the end important as can get water to run away with the fall there rather than settling at the corner . Good plan / bad plan ?
  9. Took out those blocks so the main water escape route is forwards away from the build . Any idea what I could put here ? . A Clark’s drain type cover but with a grill ?
  10. So to put it in context ! If you zoom in you can see the green is shiny I.e damp . Yeah I know it’s minimal - but it’s still there . I’ll try my plan out the front for a few months . I know some of you will say “ (expletive deleted) that just seal the concrete in the upstand “ - what concerns me is where the water goes if it can’t get through there …
  11. So a plan I had before I’m going to try . Remove blocks on this drawn section . So water can’t pool and run along the wall . A way for it to run off away from the wall .Remember with those 4 courses not in I had zero leaks ! . So it’s water running along the wall base and maybe down the lane the issue ….?
  12. Where the cone is now nice toss pot basically put some of my pavers . Can’t possibly have sand on the lane ! Tosser !
  13. Noticed damp in the recess . Went outside to look . Only lite rain today . A neighbor ( aka wanker ) had placed some of the cobble stones back at the end presumably to stop the sand washing out . No idea when they did this - but clearly will cause a dam .So clearly still an issue ( can’t say if their block caused the issue but it doesn’t help me ) . Removed blocks and put cone out now ffs . So still an issue - what a bast !
  14. Paint what ? The underside of a glazing frame sat on an upstand ?
  15. I can’t get to the outside of the foam
  16. I did . I posted on here
  17. Don’t doubt you . But the spec should say something . I did use a soudal one ( so not cheap brand shite ) . I did just 1 glazed unit - I’ll see how it goes ( as the foam is in ) - if I determine the leak is still over the upstands I.e foams doing jack ; I’ll remove the glass next summer scrape out the foam and redo with your suggested weapon of choice .
  18. Back it up Welsh Wizard with facts …. 🤨
  19. But that’s the entire point Uncle Nick . 99% of the (expletive deleted)ing expanding foam spec doesn’t say shit about water resistance. @Mr Punter fault for mentioning it ! 😝 . But that’s bostik one does say closed cell .
  20. https://www.bostik.com/assets/bostik/TDS_SX Professionals Gun Grade Expanding PU Foam_en_GB.pdf actually states closed cell 70%
  21. But the description of that is pretty much like everything else “ air gap sealer “ …. 😕
  22. Can’t get in there - too tight and awkward a gap . If I took the glass out I could from above .
  23. Bit of a mess really ! I.e simple enough requirement yet impossible to tell ! I even looked at the spec sheet for what I used on the Soundal website and it’s basically unhelpful .
  24. How can I tell ? nothing obvious on canister checking and of course most suppliers don’t state ‘open’ or ‘closed ‘ cell - that would be too easy . It would seem it’s almost impossible to purchase with certainty of ‘ closed cell ‘ because most just say water resistant ….
  25. Nothing to really report . Had substantial rain this morning- no leak from the main ‘over the slab ‘ bit . Those small walk on glazing units - no leak , but getting my finger right up in the gap between upstand and glazing can feel its damp . So foamed one window around that ‘weak spot ‘ .
