Everything posted by Pocster
You want to visit ? Hear my tales of woe and greatness ?
Get the (expletive deleted)ing cinema system in ! Fannying around on metal frame stuff !
Shame - bodge . I’d never do anything like that . Bet it’s leaking now ; go check ! 😉
Yeah @ToughButterCup should know this . CT1 and expanding foam fix 99% of all problems
It’s having a wee !
Sum it up in one sentence then... Go on.
Pocster replied to ToughButterCup's topic in General Self Build & DIY Discussion
(expletive deleted)ing legend status and no skills required by my bollocks . -
What does this architectural symbol mean?
Pocster replied to Tony L's topic in Surveyors & Architects
Glad it’s not just me . But checking 10 times a day when raining probably means I need counselling . Storm tomorrow- torch ready !!
Looks like Sputnik 1 has landed . But it’s unlikely to be an architectural requirement for plans . -
So far …..
I still check 10 times a day and probably will forever 🤣🤣🤣
Nothing to report sir
Not sure what you need a plumber for . But! Assuming it’s not gas I.e boiler install etc you can do it . I know you can . Because I did it . As mentioned hep2O is Lego for “ plumbers “ . I’d explain your exact issue / what you want done up here .You’ll get tons of help . Save you a fortune ! . Then when it leaks you can blame yourself but also fix it 😊
In all the movies I’ve watched it’s easy to find a good plumber . You must have long legs , tight short skirt , large breasts ( but covered ) and be in desperate need of plumbing …
Mvhr new noises
Pocster replied to Pocster's topic in Mechanical Ventilation with Heat Recovery (MVHR)
Can I find replacement fans …. 🙄 maybe … but how (expletive deleted)ing much !!! -
Mvhr new noises
Mvhr new noises
lol ! Nearly shit myself . Decided to turn it on whilst holding the arm in the slot soots. It took the (expletive deleted)er ! if I just permanently turn off summer bypass then I need not care ? ( obviously at the moment can’t get arm to fix to panel ) -
Mvhr new noises
Mvhr new noises
Found manual online . Vent axia kinetic advance sx . Doesn’t even show this internal panel and arm -
Mvhr new noises
I can get the bottom clips in that’s okay . But as that arm goes in the slot- it gets stopped before I can get the panel closed - like it’s hitting something -
Mvhr new noises
Ok I’m confused . Powering it on causes a whirling noise presumably for this arm . But I can’t get the arm in and close the flap -
Mvhr new noises
Mvhr new noises
I built the (expletive deleted)ing house so need a break 🤣🤣🤣🤣 -
Mvhr new noises
My plan was simply replace the entire fan so less (expletive deleted)ing about
